2003 GLX 2.0 Passat Wagon Starting to Idle Rough
  1. Welcome to VW Passat Forums : Volkswagen Passat Forum ‚Äď General discussion forum for Volkswagen Passat
Results 1 to 10 of 10
Like Tree3Likes
  • 1 Post By axenstar
  • 1 Post By passatglxian2
  • 1 Post By PZ
Thread: 2003 GLX 2.0 Passat Wagon Starting to Idle Rough
    Jan 2018
    seattle
    20
    I bought this car (second 2003 GLX 2.8 [typo in title and canít change] wagon) last year with 90k miles. Itís run well, but has been using oil. I just changed my oil last week and have heard a loud clunky sound twice when trying to start. Itís a horrible sound, but then the car starts easily the second try. My dad said this is because Iím starting on the compression stroke. Now the car is starting to idle rough. Itís always had an Evap code, but nothing else. Timing belt was changed at 80k and Iím just about to hit 100k. Wondering if I have bad rings...
    3rd Gear axenstar's Avatar
    Mar 2011
    CharlestonSC/Atlanta
    1,646
    More than likely cam chain tensioner(s).
    cchief22 likes this.
    Jan 2018
    seattle
    20
    Quote Originally Posted by axenstar View Post
    Thanks. Just pulled codes and got
  5. Remove Advertisements
  6. #4
    Mar 2011
    1,646
    I would read this entire thread.
    https://www.passatworld.com/forums/b...on-system.html
  7. #5
    Jan 2018
    seattle
    20
    On it. Thanks!
    axenstar likes this.
  8. #6
    Jan 2018
    seattle
    20
    It seems like that thread refers to the codes, but nothing about the rough idle. Thatís what Iím really concerned about. Iíve always had a check engine lights for Evap leaks and vacuum leaks. Never really concerned about that. But it definitely seems like the car is running rough right now.
    My try throwing some seafoam in the engine to see if it helps.
  9. #7
    PZ
    PZ is online now
    Redline
    May 2002
    Grapevine TX. 01 4M
    55
    25,700
    Vac leaks will cause a rough idle. Cleaning the throttle body will usually do a lot more than Seafoam. As for oil, make sure all of the leaks are repaired, if it's still a problem, the valve seals are more likely to be an issue than rings at that mileage. I did valve seals as part of a head rebuild at 92K and it drastically cut my oil usage on my V6.
    passatglxian2 likes this.
  10. #8
    Jan 2018
    seattle
    20
    Cool. Iíve got some throttle body cleaner and will give it a go. Any tips on telling of the valve seals need to be replaced?
  11. #9
    PZ
    PZ is online now
    Redline
    May 2002
    Grapevine TX. 01 4M
    55
    25,700
    Unbolting the throttle body is the best way to clean it (it's also a pita). A good clean and working PCV might reduce some of the oil burning. I did not notice any symptoms from the valve seals, I burned oil on long highway trips (1L every 1000-1500mi). I suspect the cats burned it all off as there was no smoke or smell. In local driving, it might have burned 1L in 5K. I only had the heads rebuilt after a idler roller failed after 18months/22K. The oil burning on trips dropped to 1L per 3K or less and locally to .5L per 5K.
  12. #10
    Feb 2019
    Vermont
    74
    rough idle could also be from leaking valve cover gaskets, and misfires because of it, but you would normally get codes for the misfires.
    If its plowing through oil you could be losing oil via the VCGs, you could also be losing oil through camshaft / camshaft sensor seals.
    Quote Originally Posted by passatglxian2 View Post
    Check your spark plug tubes and see if there is any oil in there.
    PCV "hoses" may also be clogged.
  13. Remove Advertisements
There are currently 3 users browsing this thread. (1 members and 2 guests)
  1. maxeymum
Similar Threads
  1. Rough Idle when starting cold
    By Jakobw5 in forum B5 Garage
    Last Post: 08-13-2015, 08:01 AM
  2. Rough idle on Passat 1.8T 2003 engine code AWM
    By hatman in forum Volkswagen Passat B5 Discussion
    Last Post: 09-26-2013, 08:04 PM
  3. 2003 Passat rough idle
    By nitefamily in forum Volkswagen Passat B5 Discussion
    Last Post: 03-23-2012, 06:36 PM
  4. Rough Idle, Misfire Codes, 2003 Passat 1.8T Auto
    By faroodi in forum Volkswagen Passat B5 Discussion
    Last Post: 03-11-2012, 04:39 PM
  5. Rough idle / poor starting after pothole impact
    By Douglas in forum B6 Garage
    Last Post: 04-11-2010, 09:50 AM
