2003 Passat V6 Climactic A/C Fan Power
Results 1 to 3 of 3
    Jan 2013
    Wisconsin
    4
    My 2003 Passat V6 over-heats when in stalled traffic with the A/C turned ON. The secondary small fan has no power. My independent mechanic has checked the fuses and replaced the fan control relay, but still no power. What next?
    Aug 2011
    Westerville, Ohio
    1,017
    The auxiliary coolant (radiator) fan is controlled differently depending on the engine.
    The 1.8T uses two relays under the dash.
    The V6 uses a fan control module, which is under the hood on the left frame rail. It depends on two fuses:
    > The 40 amp fan motor fuse on the aux relay panel
    > The 5 amp control power fuse, which I think is also on the aux relay panel.
    EDIT: The fan control module also powers and controls the afterrun coolant pump (only present in the V6, hence the difference). I think it's powered from the 5A fuse, so a failed afterrun coolant pump could blow the control fuse and thus disable the aux coolant fan.
    In all cases, the fuses are not in the main fuse panel.
    Last edited by FrescoGreen01.5; 04-11-2019 at 06:49 PM. Reason: Added info at end of post
    Feb 2019
    Vermont
    84
    I have a lot of info on where everything is inside the relay panels in this thread
    https://www.passatworld.com/forums/b...obd-codes.html
  5. Remove Advertisements
    Similar Threads
    1. Behr fan vs Siemens fan for 2008 passat
      By Mercerjimmy in forum Volkswagen Passat B6 Discussion
      Last Post: 06-29-2012, 08:37 PM
    2. Replacing the fan/fan clutch with an electric fan? Has anyone done this?
      By jimmye4golf in forum Volkswagen Passat B5 Discussion
      Last Post: 06-26-2012, 03:34 PM
    3. Replies: 9
      Last Post: 02-10-2011, 11:40 AM
    4. WTB: V6 fan clutch & fan
      By loach1 in forum Classified Archive
      Last Post: 05-31-2008, 04:05 PM
