Error code help
Results 1 to 20 of 20
Thread: Error code help
    Jun 2001
    Grovetown, GA
    44
    1,929
    I got the bellow error codes is it possible my timing is off? I ask b/c it’s on a car I recently replaced the cylinder head, timing belt (and tensioner) and all accessory belts.
    P0102 mass airflow circuit Dash G 70: low input
    P0140 02 sensor circuit, bank one sensor 2: no activity detected
    P0300 Random/multiple cylinder: misfire detected
    P0301 cylinder one: misfire detected
    P0302 Cylinder two: misfire detected
    P0303 Cylinder three: misfire detected
    P0304 cylinder forcolon misfire detected
    P1114 bank 1 sensor 2:Internal resistance to large
    P1136 Bank one mixture adaptation (add): system to lean
    P1517 main relay = >Dash J271: electrical malfunction
    P1602 Power supply (B +) terminal 30: low-voltage
    P1626 Data – bus powertrain: missing message from transmission control
    Aug 2011
    Westerville, Ohio
    1,018
    What engine/engine code/year?
    Is everything buttoned up and all connectors plugged back in? The MAF code says there's either a huge intake air leak or a MAF issue. That could explain the lean code and all the misfires. (I'm guessing air leak.)
    P0140 and P1114 make me suspect that sensor (downstream of the CAT) isn't plugged in. That would not explain performance issues.
    Jun 2001
    Grovetown, GA
    44
    1,929
    Quote Originally Posted by FrescoGreen01.5 View Post
    Yes everything (timing cover, engine cover, air box cover...etc) the car is fully put back together,but I will double check the MAF sensor. When you say “downstream of the cat” where are you referring between the two o2 sensors? Also I pulled all of my codes with a V-Checker 202...just some FYI in case that makes a difference. Lastly I pulled all those codes on an OEM ECU because on my ECU with the GIAC tune the car only gives me the circle around a triangle with an exclamation point inside light and won’t even start.
    I’ll grab the engine code in the a.m. as well.
  5. Remove Advertisements
  6. #4
    Jun 2001
    Grovetown, GA
    44
    1,929
    ATW engine code
  7. #5
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    55
    25,726
    Does the car run better with the MAF unplugged?
    As for timing, it would usually throw a code if the timing was off. The only way it would not, is if the intake cam is off, but the exhaust cam was not. This generally does not occur as the intake timing is easy to confirm on the 1.8T.
  8. #6
    Jun 2001
    Grovetown, GA
    44
    1,929
    I’m headed outside to check the car right now. I’ll unplug the MAF and see what codes it throws. Should I clear all the codes first?
  9. #7
    Jun 2001
    Grovetown, GA
    44
    1,929
    Unplugged MAF, cleared codes. Started the car and the CEL came back on with these two codes. Side note the circle/triangle/exclamation mark never disappeared during the process.
  10. #8
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    55
    25,726
    I can't read the 2nd code. Does the car run better without the MAF plugged in? Apart from an intake leak somewhere, it's likely that the MAF has failed.
  11. #9
    Aug 2011
    Westerville, Ohio
    1,018
    2x what PZ said. Other than damaged wiring, a failed MAF is about the only thing that would cause the first code.
    The ! triangle with the circle is "traction control off" or something similar.
  12. #10
    Jun 2001
    Grovetown, GA
    44
    1,929
    P1626 Data-bus powertrain: missing message from transmission control
    P0102 Mass air flow circuit-G70: low input
    Yeah it runs better but the traction control light stays on.
  13. #11
    Jun 2001
    Grovetown, GA
    44
    1,929
    The traction control light stays on whether I press the button or not but it wasn’t on before I started having issues so IDK what’s up.
  14. #12
    Jun 2001
    Grovetown, GA
    44
    1,929
    I cleaned the MAF with electrical parts cleaner and reinstalled it. I then cleared the codes and started it and the codes, the last 2 I posted, popped back up. The traction light stays lit as well.
  15. #13
    Feb 2019
    Vermont
    85
    Quote Originally Posted by passatevos View Post
    Did you clean the sensor or the sensor contacts?
  16. #14
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    55
    25,726
    If there are no leaks, I would replace the MAF.
    Has it been manual swapped or is it still a Tip trans? If it's a manual, the cluster and ABS is not coded for a manual trans. If it's a Tip, check the TCM for water damage.
  17. #15
    Jun 2001
    Grovetown, GA
    44
    1,929
    Quote Originally Posted by ar393 View Post
    The sensor that’s inside the round tube inside the top half of the air box. Not the connection that clips into the top of the MAF from the top of the air box.
  18. #16
    Jun 2001
    Grovetown, GA
    44
    1,929
    Is an OEM Manual tranny. However the ECU is a refurbished one I bought from online with the same ECU code so I don’t know if came from a tiptronic previously but when I paid for it I let them know my ECU code as well as engine size and transmission.
  19. #17
    Feb 2019
    Vermont
    85
    check and, if needed, clean the actual contacts at the connection as well.
  20. #18
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    55
    25,726
    Is the Brake light warning always on? The Tip version of the 2000 ATW 1.8T had ASR, which is the circle that is lit. I don't recall if the manual trans also had ASR. The ECU can use the same code for manual or Tip trans. I suspect it's coded to a Tip trans as that would throw off the ASR and call for communication with the TCM.
    You will need to go into Coding section of VCDS and check the ECU, ABS and Cluster coding. It's been a few years since I did mine, but it was pretty easy to figure out.
  21. #19
    Jun 2001
    Grovetown, GA
    44
    1,929
    The brake light is lit b/c I have the E-brake engaged. I’ll try to do some research on how to do that with my V-Checker 202 b/c that’s all I have.
  22. #20
    Jun 2001
    Grovetown, GA
    44
    1,929
    I’ll clean ‘em in the a.m. if no luck I’ll guess I’ll be getting a new MAF sensor.
  23. Remove Advertisements
    Similar Threads
    1. PLEASE HELP!!! Any HID Conversion Kit with NO Error Code or No "Bulb Out" Light???
      By yehudah72 in forum Volkswagen Passat B6 Discussion
      Last Post: 10-28-2009, 08:03 PM
    2. Help: Coolant Error Code
      By dogg in forum Volkswagen Passat B5 Discussion
      Last Post: 04-30-2009, 08:52 AM
    3. Error code 3 on Monsoon HU - help!
      By Ehren in forum Mobile Electronics
      Last Post: 07-06-2006, 09:21 AM
    4. Error code help
      By tonality in forum Volkswagen Passat B5 Discussion
      Last Post: 07-15-2004, 12:50 PM
