2002 4motion glx wagon, 2.8l atq, 125k miles - p0150 vs p0155 issue
Results 1 to 13 of 13
Like Tree1Likes
  • 1 Post By ar393
Thread: 2002 4motion glx wagon, 2.8l atq, 125k miles - p0150 vs p0155 issue
    Feb 2019
    Vermont
    84
    Question 2002 4motion glx wagon, 2.8l atq, 125k miles - p0150 vs p0155 issue
    Hey there all.
    I am a noob, but a relatively fast learner and pretty handy.
    This is my intro post:
    https://www.passatworld.com/forums/n...ml#post4510377
    That gives a good intro to why I am here without retyping everything.
    Anyways, I did a bunch of work to fix the following codes:
    P0117 Engine Coolant Temp.Circ Low Input
    P0155 O2 Sensor Heater Circ.,Bank2-Sensor1 Malfunction
    P0300 Random/Multiple Cylinder Misfire Detected
    P0301 Cyl.1 Misfire Detected
    P0302 Cyl.2 Misfire Detected
    P0348 Camshaft position sensor
    P0441 EVAP Emission Contr.Sys.Incorrect Purge Flow
    P2096 Fuel system too lean
    No Heat
    ECT sensor, o2 sensor, all spark plugs, all spark plug wires, valve cover gaskets, camshaft position sensor and purge valve were all replaced.
    Engine put back together, oil added, coolant added. Took it a bit initially but fired up and since then its fired up on the first try each time, but temps haven't been too too cold (32F or so, not like -10F).
    All codes were cleared and it was driven around for a while. None of those codes have come back. for a quick minute got two different cyl. misfire codes but then self cleared. Right now I am getting a p0150 code O2 Sensor Circ.,Bank2-Sensor1 Malfunction
    The only difference is the word heater in the codes. but same side and sensor.....the sensor is new.
    My plan is to try swap the connections between banks one and two, and see if the code switches sides or not. If it doesn't switch sides I gotta think that its a wiring issue between the sensor (I will check the contacts too) and the computer.
    so again I went from
    to
    P0150 O2 Sensor Circ.,Bank2-Sensor1 Malfunction
    after replacing the sensor
    any thoughts?
    I plan on doing a heater core flush this weekend to see if that fixes the heat problem before trying to take the dash apart.
    Thanks in advance. hopefully I didnt make many posting/noob mistakes.
    Feb 2019
    Vermont
    84
    Mods, don't know why it double posted. Please delete. Thank you.
    Sep 2015
    Raleigh, NC
    48
    1,783
    Not sure about the codes but have you serviced the PCV system? They get clogged and will make your valve covers leak again. The plastic hoses (along with the tiny vacuum hoses) are brittle also. It's best to replace them with silicon. Both systems can create rough idle and codes if broken.
    As far as not having heat. The system needs to be bled to remove any air pockets. Reverse (or back) flushing the heater core is recommended. Make sure you use the pink coolant and water ratio. Never mix different coolants and always make sure it's G12.
  5. Remove Advertisements
  6. #4
    Feb 2019
    Vermont
    84
    Thanks. In my post I said I fixed all the sensors/problems associated with all the codes that were present at the time of my adoption of this car.
    I'm not worried about bleeding the system and a back flushing the heater core because of these two threads:
    https://www.passatworld.com/forums/b...eat-blues.html
    https://www.passatworld.com/forums/b...flush-diy.html
    So the TLR version of my OP:
    I went from
    to
    after replacing the sensor (drivers side, upstream)....do these two codes not point to the same sensor?
  7. #5
    Overdrive
    Feb 2007
    Lehigh County, Pa.
    64
    12,045
    If you replace a part and still get errors, the first question is what brand, model, and source of the replacement part? Sounds like the system can't "see" the heater on the new sensor.
  8. #6
    Feb 2019
    Vermont
    84
    Quote Originally Posted by scotts13 View Post
    30 dollar o2 sensor from amazon. https://www.amazon.com/gp/product/B07DHLT3GL
    I am going to swap the connections this weekend for the Bank1 and Bank2 sensors (way easier than swapping the sensors) and see if the error moves sides or stays put.
  9. #7
    Overdrive
    Feb 2007
    Lehigh County, Pa.
    64
    12,045
    I've always preferred the Bosch direct-fit sensors. Quite a bit more money, but cheaper than VW original. And, no question of them working.
  10. #8
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    55
    25,726
    I would look at the connections on the O2 sensors. There may be corrosion preventing a good circuit.
  11. #9
    Feb 2019
    Vermont
    84
    hit all the contacts with some MAF cleaner since I had bought some to do the MAF sensor. Much happier motor now.
    PCV check valve (not purge valve) should be in today and that should knock out the only remaining issue of both sides running too lean, unless something broke - at which point, junk yard trip in my future.
  12. #10
    Feb 2019
    Vermont
    84
    Quote Originally Posted by ar393 View Post
    Took way longer than I wanted it to. Also couldn't get the hard hose bleed valves to bleed, but bled it from the hose bleed hole.
    She now has heat!
    PZ likes this.
  13. #11
    Feb 2019
    Vermont
    84
    I think now because she has heat, I have a the CCM grounding problem because the snow actually melted.
    I have plenty of DC power from the battery , but nothing but one click when you turn the key. From what I have read its a grounding problem in one of a couple places:
    1) Main battery to chassis ground
    2) Engine to chassis ground
    3) CCM ground to chassis ground
    4) or other water in CCM issues
    I just wish it wasnt below 15 degrees when I have to do this.
  14. #12
    Feb 2019
    Vermont
    84
    So I cleaned up some grounds and life is good....almost.
    When i flushed the heater core i broke the outlet plastic fitting the hose goes over. by break i mean split along the joint. I couldnt get the hose to go all the way flush so there is like 1/8th of an inch exposed and its leaking. When I get a chance in the next two weeks I an going to pull the hose, clean the fitting, apply some epoxy to the outside and let it cure for 24 hours then put the hose back and see if the coolant leak stops.
    Other issues with her:
    Liftgate actuator is shot, going to snag one from the scrap yard and replace it. I already took the dead one out.
    Horns are shot....I was trying to find the problem from an electrical source...and i couldn't find anything...then i poked my head under the bumper....there might be about 30% of each horn remaining due to rust.
    BIGGEST issue, is that it was having its ABS kick on anytime you hit the brakes. So i said fuck it and lets clean the ABS sensors, since every video shows its like a 10 minute job at best. it took over 4 hours to get them out.....Now i have an ABS light on with no codes....some searching has shown that it might have been brake fluid level (which was low) and that was topped off, but still only ABS light and no codes. I also tried the disconnect the battery and pull the fuse, but still light.
    I do know that the battery was plugged in when we pulled and cleaned the sensors.....I dunno if this has f$#ked me.
  15. #13
    Feb 2019
    Vermont
    84
    Solved
    Just as a heads up, I hit the contacts with with some MAF cleaner and the code disappeared.
  16. Remove Advertisements
    Similar Threads
    1. 0-60 2002 GLX 2.8L V6 ATQ Engine
      By Mikey319 in forum Volkswagen Passat B5 Discussion
      Last Post: 09-18-2015, 06:20 PM
    2. Replies: 2
      Last Post: 06-15-2015, 11:01 AM
    3. Replies: 2
      Last Post: 06-13-2015, 09:19 PM
    4. Ignition Issue - 2002 2.8L V6 GLX 4Motion
      By hermandrew in forum B5 Garage
      Last Post: 11-09-2012, 03:34 AM
    5. Ignition Issue - 2002 2.8L V6 GLX 4Motion
      By hermandrew in forum Volkswagen Passat B5 Discussion
      Last Post: 11-09-2012, 03:33 AM
