Timing belt hydraulic tensioner ??
Page 1 of 2 12 LastLast
Results 1 to 30 of 33
    Jun 2004
    california
    179
    Hi All
    This thing has got me stumped, i have replaced the hyd tensioner NTN four times because of rat tat noise coming from the tensioner/lever/pully returning them thinking they were defective...only on cold start ups for a few minutes. I have listened with a stetherscope so i know this is the place where the noise is. I am getting good at doing this job without putting the front end in the service pos...i have all the tools cam tool bar etc. I pre load the tensioner and all seems tight... seems the engine/belt/cams turning put a load on the tensioner and force the plunger down...could it be one of the camshafts tight in the journals. This all started around 120,000 , i did the belt job etc at 82k and no noise.
    One more thing, when removing the tensioner it takes no effort to return the piston an put the pin back in the hole
    2nd Gear
    Jan 2007
    NC - 02 1.8T Tip
    812
    You are talking about this guy, right?
    I have no experience with the V6, but on the 1.8T, but the tensioner should take good bit of effort and time to get to re-compress.
    Is the noise coming from the front of the engine, or the rear?
    2nd Gear
    Jan 2007
    NC - 02 1.8T Tip
    812
    oops, double post
  5. Remove Advertisements
  6. #4
    May 2006
    Abingdon, MD
    42
    23,180
    Never heard of that noise com,ing from that part. what you are describing sounds like a bad CHAIN tensioner at the back of the heads.
  7. #5
    Jun 2004
    california
    179
    Sorry guys i forgot...2001 2.8 V6....no its not the cam chain tensioners.....the noise is coming from the hydraulic timing belt tensioner %100.....as i said i used a stetherscope stuck in my ear lol... but i dont know why its doing this....has anyone else used the NTN tensioner. I dont want to pay for another tensioner from the dealer....on line $62 ..dealer $212....amaizing eh.
  8. #6
    Grinding Gears...gone fishing! ScottPassat2.8's Avatar
    Feb 2005
    Staten Is. NY GLX2.8
    50
    22,620
    it is the cam chain tensioner.they take a few to pump up.
    I have had 2 V6's and they all do it for the first few seconds on first start up.
    put the tools away and relax.
    the sound will travel up there. you can put it on an exhaust manifold and hear the same sound.
    there is no way in hell you have 4 bad tensioners.
    here is why... cam chain attached to cam, cam attached to belt, belt rides on well you guessed it.
  9. #7
    Jun 2004
    california
    179
    Quote Originally Posted by woodardhsd View Post
    Thanks....That is the same part for the v6..but the NTN ones i got did not have the part # stamped on it, none of them did.....all the on line suppliers sell this one..but after four....could they all be defects. Not much effort to de compress
  10. #8
    Jun 2004
    california
    179
    Quote Originally Posted by ScottPassat2.8 View Post
    Thanks Scott
    Yes on some morning starts, not every time i do get a little chain rattle for one second at morning starts, then no noise, coming down to 800rpm from 1000, then the tat tat noise starts...this noise is not cam chain..i know its hard to explain... tat tat it lasts until the tensioner finds its adjustments..
  11. #9
    4th Gear
    Apr 2007
    Greensboro, NC
    3,190
    How is the water pump? Bad bearings can cause the noise you hear.
  12. #10
    Jun 2004
    california
    179
    Quote Originally Posted by GSO_Passater View Post
    W/P Roller tensioners p/s pump..etc are all ok..
    Just wanted to add one more thing, when i get started on the teardowns, cold engine, i pulled the covers on the cam gears, the timing belt was always loose on the left side, turn the engine by hand and the belt tightened up after several turns on the crank pully..
  13. #11
    2nd Gear
    Jan 2007
    NC - 02 1.8T Tip
    812
    Quote Originally Posted by uksparky View Post
    If the BELT tensioner is as loose as you said it is in your first post, that's why the belt was loose when the engine was cold. If it's that loose, it's only a matter of time before you slip a tooth and bend valves.
    How loose is it exactly? Can you push the piston back in with just your thumb?
  14. #12
    he just thinks he's amazing. really. no kidding.
    May 2008
    San Jose, CA
    35
    3,780
    Blog Entries
    1
    How are you pretensioning the timing belt? Are you pulling the pin after you do the pretensioning, or before? If you do it right, the tensioner shouldn't pop out much at all when you pull the pin. The belt should always be tight.
    I slipped on the last T-belt I did and let the tensioner fully extend prematurely. It took a bench vice and 5 minutes to recompress it enough to reset the pin.
  15. #13
    Jun 2004
    california
    179
    Quote Originally Posted by TheAmazingDave View Post
    Dave i do it by the book... as with all the tensioners i pull the pin, the piston extends there is a lot of spring tension in that thing, i put the allen key socket in the tensioner pully..tension the belt, piston moves out....belt is tight between the cams/left/right . Turn the engine at the pully all is ok tight. When i did the replacements in the other tensioners i did the same thing with the allen key tool to de compress the piston, not a lot of effort......i did not need a vice..is everyone else using the NTN
  16. #14
    Jun 2004
    california
    179
    No its not that bad i would have bent valves if i could push it in with my thumb... .yes this is strange, when the engine is cold, cam covers off the belt is a little loose left side, tap tap engine running at idle...at normal temp belt is tight after engine is turned off restart hot no noise......so the tensioner has to get hot to work right.......yes every time i start on mornings ???
  17. #15
    Jun 2004
    california
    179
    Dave
    Oh crap wait ...i pulled the pin out and the piston shot out...then i pre tensioned the belt. But i did not compress the piston before i pulled the pin... and let it out slowly... is that my problem
  18. #16
    May 2008
    San Jose, CA
    35
    3,780
    Blog Entries
    1
    ^The last two timing belts I did with hydraulic tensioners, my V6 Passat and a V6 3000GT, the belt was pretensioned before pulling out the shipping pin on the tensioner by turning the off-center hub of the tensioner pulley until the correct torque was reached. Once the belt was pretensioned and the pin finally pulled, there was little movement of the hydraulic tensioner. In fact, on the 3000GT, it didn't move at all; the pin slid right out and easily slid right back in to the tensioner.
    If the tensioner pops out when you pull the pin, I'm inclined to believe it wasn't set up properly.
  19. #17
    Jun 2004
    california
    179
    Pulling the pin out, the tensioner piston came about half way out of its travel, then i pre tensioned the belt tight. I would say the pin was at half way out after a few minutes, belt was tight. I dont think i need to pull it apart to do the tension thing again. Its driving me nuts why its no problem when the engine is at normal temp?
    So you are saying that when the pin is pulled the piston does not extend much on the 3000GT....This problem started 47k after the last T belt job...so i replaced the timing belt and tensioner...replacing the belt was tight getting it on like the last time, so its the right belt...same part#
  20. #18
    Jun 2004
    california
    179
    [QUOTE=TheAmazingDave;2587437]^The last two timing belts I did with hydraulic tensioners, my V6 Passat and a V6 3000GT, the belt was pretensioned before pulling out the shipping pin on the tensioner by turning the off-center hub of the tensioner pulley until the correct torque was reached. Once the belt was pretensioned and the pin finally pulled, there was little movement of the hydraulic tensioner. In fact, on the 3000GT, it didn't move at all; the pin slid right out and easily slid right back in to the tensioner.
    If the tensioner pops out when you pull the pin, I'm inclined to believe it wasn't set up properly.[/QUOTE belt...
    This morning i pulled the left cover showing the cam and belt, i could push my finger on the belt/right side of cam going down to the W/P it moved a little bit and was not tight. I put a socket and bar on the crank pully, turned a few inches left and right..at this point the belt was nice and tight, so its working ok. It looks like when the tensioner is idle overnight, the pressure from the belt caused the oil to bleed down inside the tensioner, at that point the belt is not tight....(I took the old tensioner apart the see how it works...it has oil and a ball bearing valve) So i turned the key and started it up, at 1000 rpm the noise started, coming down to idle i used the stetherscope listening to the noise it sounded like one of those old morse code things tat..tat.. pause.. tat..until the noise disapeared just over a minute.Turned engine off belt tight.
  21. #19
    2nd Gear
    Jan 2007
    NC - 02 1.8T Tip
    812
    Not sure about the V6, but on the 1.8T, you have to pre-tension the belt using the tensioner roller BEFORE you pull the pin. If you don't pretension the belt, there's too much slack in the belt and tensioner can't take it all up.
    The same thing happened to me when I didn't tension the belt correctly. Depending on where the engine stopped in it's cycle, there was quite a bit of slack in the belt. Luckily I caught it in time and got it tensioned correctly.
    EDIT sounds like you did it right after all.
  22. #20
    May 2008
    San Jose, CA
    35
    3,780
    Blog Entries
    1
    The belt should not go slack at any time, even if sitting for a week.
  23. #21
    Jun 2004
    california
    179
    This is your problem. You're going it backwards. You have to pretension the belt, then pull the pin
    Thanks.....I just want to get this right...you are saying.. pull it apart again...compress the tensioner with the pully...put the pin back in....pre tension the roller putting pressure on the tensioner....pull the pin...let the piston come out slowly until the belt tensions....then tension the belt.
    Or are you saying pre tension the belt tight with the roller, then pull the pin..i dont understand what you mean ...you say..if you dont pre tension the belt, there is too much slack in the belt etc.
    Every time i replaced the hyd tensioner the belt was tight...i de compressed the tensioner, pinned it.. removed the three mounting bolts, changed the tensioner, pulled the pin....then tensioned the belt with the pully...the belt was tight.
    This all sounds crazy....after a run today checked the belt..it was nice and tight....engine warm perfect ...but in the mornings things change....if i use a tool to turn the crank back and forth...this tensions the belt...tat tat for a minute or so....if i dont do this tat lasts for about three minutes. So tell me i have a bad tensioner
  24. #22
    Nov 2009
    Upstate NY
    4,164
    I think they are saying you have to tension the belt with the pulley first, THEN pull the pin.
  25. #23
    Jun 2004
    california
    179
    Quote Originally Posted by zak99B5 View Post
    Thanks...i will pull it apart at the weekend and do it that way....and let you know the results...
  26. #24
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    56
    25,824
    The V6 does not have an adjustable pulley like the 1.8T. You pull the pin, then tighten the cam pullies. The install sounds good, but every V6 tensioner I have seen takes quite a bit of pressure to compress. I don't know why they would all be bad, but I would try an INA one as ECS sells them for $67
    Are you sure there was not an extra washer left behind the tension roller? I had that happen once as it was stuck to the block and caused the exact same problem. I have also seen a bad tension roller that "stuck" when cold and did the same thing.
  27. #25
    2nd Gear
    Jan 2007
    NC - 02 1.8T Tip
    812
    Looking at this a little more, pre-tensioning the belt on the V6 appears to be a little different than on the 1.8T. I apologize for the confusion. Now, I'm leaning towards the fact that your tensioner is bad.
    Edit-PZ beat me too it. The tensioner rollers are different between the 2 engines. The manual does state something about pre-tensioning the belt on the V6, but the two PDF's I've seen contradict themselves so I won't bother to post anything from them.
  28. #26
    Jun 2004
    california
    179
    I decided to pull it apart again today i am getting good at this....compressing the tensioner was like cutting through butter, no pressure needed...put the pin in, put the pressure on it with the roller, let the piston come out nice and slow.....crap it has no resistance, i could push the piston up and down like there was nothing inside this thing. I pumped the piston up and down until it started to get hard to compress, then tensioned the belt.....all back together started up ...no noise great.....one hour later started tat..tat...tat......(yes there is a washer behind the lever...i replaced the lever the other week (third tensioner).
    So i have gone through four NTNs they are junk...i will try and get an INT.
    Thanks for the help guys
  29. #27
    Jun 2004
    california
    179
    Every where i have looked no one has the INA i looked at ECS and its NTN like everwhere else
    Can anyone help me find one of these...
  30. #28
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    56
    25,824
    ECS had both listed. Make sure you check the 2nd or 3rd page under timing.
  31. #29
    2nd Gear
    Jan 2007
    NC - 02 1.8T Tip
    812
    It's at the bottom of this page: http://www.ecstuning.com/Volkswagen-...ing/Tensioner/
    Here it is:http://www.ecstuning.com/Volkswagen-...sioner/ES1672/
    Not sure what this means, but if you look close, you can still see NTN on the top between the two bolt holes.
  32. #30
    Jun 2004
    california
    179
    Here it is:
    If you look close, you can still see NTN on the top between the two bolt holes.
    Yes i can see the INA logo but the so called INA in the picture is NTN...Plus both are the same part number.....i dont want NTN i have tried four so far...at the moment i am searching for this part.
    Update
    I contacted a parts Firstvwparts.com and found the dealer part NTN tensioner with the part # stamped on the tensioner plus the three audi rings. This is the same part i used 47k miles ago....so i hope this a better quality part and will fix the problem the other NTNs had no part # or rings .....cost $136 plus shipping...same part at the stealership $312 plus tax
  33. Remove Advertisements
