How Do I Install the ECS Tuning H7 Bulb Socket Kit?
My ECS Tuning H7 Bulb Socket Kit arrived, but it came with no directions. At first, I couldn't determine how to release the connector on the original bulb socket, but I figured that out. (Pushing down and out on the end of the connector from inside the ring with a big screwdriver). Now I'm not sure how to remove the wires from the old connector to transfer to the new connector. Any guidance would be greatly appreciated. Thanks!
Update: I used the existing factory wiring connector with two of the three new parts and I have my low beams back.
Troubleshooting background: I had moved the replaced H7 Bulb holder with current H7 bulb between the left and right headlights and the fault stayed with the location. Swapping the whole headlight assemblies between left and right had resulted the fault moving so I had a hunch that it was the socket I had to replace.
Here's a link to the part I'm referring to.
https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/h7-bulb-socket-kit/5k0941109c/
