My oil pressure light keeps coming on between 20 mph and 45 mph on my 2010 Passat 2.0 turbo. Oil pressure has been mechanically checked and new oil pressure switch has been installed. Engine runs fine. What to do ?
What engine speed (rpm) does the light first come on, then possibly go back off?
Typically, for a malfunctioning oil high-pressure switch, the warning light will come on around ~2,400 rpm and go back off around 2,600 to 2,700rpm.
It was the high pressure switch that was replaced (presumptively) given those road speeds. What pressures were you seeing and why was the original switch replaced?
One more thing...the warning light only occurs after the engine oil has warmed up, right?
rpm is around 2-3000 I think when it comes on. The low pressure switch was replaced and yes it does this when the engine oil is warmed up after about 20 to 30 minutes of run time. Only happens when running about 20 to 45 mph.
If the light comes on consistently at say ~1600 plus/minus 50 rpm then goes off at ~2050 plus/minus 50 rpm, that's a sign your high oil pressure switch is functioning correctly and you have other issues (excess rod or main bearing clearance(s) due to wear).
If you haven't owned the car since new, the P.O. may have run the car for ~15K - 20K or longer with the original oil fill.:crazy: I'm thinking a leased car needs receipts when it gets turned in to prove the leasee didn't pull this type of "stunt". Never leased, so I'm not sure about it.
From 99000 miles to 103000 miles I have spent close to 4000.00$ on this engine.(rear main seal,pvc valve,cam sensor,water pump,valve cover seal etc..)It seems like every time fix something then something else goes wrong. I don't trust the car any more. My mechanic is at a loss because we cant figure this light out. I will give him this info. Can I continue to drive the car as normal since I know it has good pressure?
I think you need a new mechanic.
I agree that it seems like you have a problem with low oil pressure.
After driving at least 20 minutes, what is the oil pressure at idle, 2,000 RPM, and 3,000 RPM ?
Well you need to get a better mechanic to check it after it has been driven at least 20 minutes.
Related Threads
Volkswagen Passat Forum
3M posts
158.6K members
Since 2002
