Hi Guys,
My VW passat B6 (2007) both rear calipers have failed. Rubber case has worn off and dust into the pistons making it very hard to retract fully. Because of this the car was slow to drive cause the brakes cannot fully retract after deploying and sort of holding on to the discs. So I went and purchased both calipers, new discs and pads. But I'm having a big problem trying to remove the bolt holding the discs in the rear. The bolt is sitting inside and it looks like this;
Is this some sort of special bolt? (I have one similar to this for my wheels so no one can steal them without the special bolt) and where can I get it? ebay?
Thank you very much for your help.
