Error code P2181 Coolant system issues
Results 1 to 5 of 5
    Jun 2011
    Texas
    6
    I have a Passat 2006/2.0T with an error code P2181 (coolant issues problems). The Temperature gauge seems to be ok, at idle, stays around 190-200, when I turn the AC the big fan comes ON, but the small fan (in the radiator) doesn't come up at all. The error code P2181 suggests that I may have a bad CTS, it is not that expensive, I can replace it. The car has 94,000 and the CTS never has been replaced. Could a bad CTS prevent the high temperature fan from coming ON? I have not tested the fan, but it seems to me like an easy taks just to replace the CTS. Any other ideas?
    Jun 2011
    NC
    390
    You most likely have
    1) bad small fan
    2) failing thermostat
    Both are really common. When you have the t-stat out, replace the CTS that is in the pipe at the bottom of the housing. The other CTS is below the timing chain cover next to the battery. That is really easy to replace any time. The other one, not so much. Replace it while you are working right there.
    Sep 2008
    SW PA
    52
    I am having the same code pop up. Please keep us posted on what you did to fix it. Think I'll check the fan later and I'll let you know.
    Sep 2008
    SW PA
    52
    Fan works, looks like thermostat I guess. Stays at a pretty steady 200. ???
    May 2006
    Abingdon, MD
    39
    22,418
    The fan operation is controlled by the dual thermal switch in the lower Rad hose.
    Glutton for Punishment: 13 CC Sport Plus, 04 Passat 1.8T GLS Variant Manual swapped, 99 C-Red Passat 1.8T (crushed)
  7. Remove Advertisements
Human Verification
