VAG.com for a Passat
Results 1 to 19 of 19
    Sep 2009
    Hudson, Wisconsin
    41
    Is there anything such as a list of features for a B6 Passat that can be changed with a VAG.com?
    I.e daylight running lights, number of blinker impulses for lane changing, etc.
    I have no clue which factory settings can be changed. Would somebody here please enlighten me a little?
    Jul 2008
    A Cardboard Box
    13,868
    Quote Originally Posted by Hudsoner View Post
    I don't know if there is a list, but some things you can/have to do
    1) enable HID's if you add them on through an aftermarket kit, not like on the b5/5.5's where you just pull a relay.
    2) Alarm chirp adjustment
    etc
    The only list that I can think of would probably be in a Bentley manual, or I am sure there is a list floating around if you google it, although it may not include everything.
    Sep 2006
    Vernon, NJ
    1,535
    www.ross-tech.com has a page with most of the various things that can be changed. Every now and then, someone discovers a new thing.
  5. Remove Advertisements
  6. #4
    Dec 2005
    Midlo, VA 04/S4
    2,486
    Blog Entries
    1
    1. Auto windows up and down feature with the remote including sunroof.
    2. Seat belt chime - off
    3. DRL - off
    4. Disable windshield washer alarm
    5. Changing the Honk Flash when locking or unlocking the car.
    6. Clearing CEL's
  7. #5
    Sep 2009
    Hudson, Wisconsin
    41
    Quote Originally Posted by NEWMAN'SOWN View Post
    etc
    Thabks for the tip, and here is the result:
    http://www.ross-tech.com/vag-com/cars/index.html
  8. #6
    Whats Up Doc MicBicPic's Avatar
    Feb 2008
    Washington
    40
    2,766
    rear fog.....
  9. #7
    Dec 2005
    Midlo, VA 04/S4
    2,486
    Blog Entries
    1
    Change the time to 24:00 style - aka Military time
  10. #8
    Dec 2008
    Space
    156
    Can you change the light output percentage so you can run DRLs with aftermarket HIDs?
  11. #9
    Sep 2009
    Hudson, Wisconsin
    41
    Wjhat would one have to do to get those LED's (as seen in this forum) to be used as daylight running lights? (besides from buying the LED strips and gluing them to the vehicle)
  12. #10
    Sep 2006
    Vernon, NJ
    1,535
    Quote Originally Posted by munnarg View Post
    yes you can.
    I'll dig up a screenshot I made for the 'tex
    under central electronics
    Presumeably, the Dec should be set at 100
    I made my fogs as the DRLs... so I wouldn't have to worry about flickering from DRLs
    Emergency Brake Light Flashing works. Had it go one during one commute...
    Bit 4 is if you want to make the fogs function as DRLs. I did.
    Bit 5 is if you want the fogs to work with high beams
  13. #11
    Jul 2008
    Nova Scotia, Canada
    130
    Do you mean the S5 look headlights? Install new eadlights, turn on "scanadanavian DRL" in Vag Com and disable fog and low beam as DRL. The Scandanvian setting turns on all of the marker or parking lights.
  14. #12
    Jul 2008
    A Cardboard Box
    13,868
    OP, just so you know, the correct title is VAG-COM as in Volkswagen Auto Group Computer, not www.vag.com, which I am assuming is some kind of strange porn site...
  15. #13
    Jul 2008
    Nova Scotia, Canada
    130
    Also, to note, the program from Ross Tech is now called VCDS.
  16. #14
    Dec 2008
    Space
    156
    Quote Originally Posted by Dark_Helmet View Post
    yes you can.
    I think I should have asked it this way. Can you use your HIDs as DRL and change the light output to 100%? From the screen shot you provided, can't I just uncheck the box for Bit 0?
  17. #15
    Jul 2008
    A Cardboard Box
    13,868
    I think you may be a bit confused. When you are enabling HID's, you have to turn off the DRL's, because if you don't, you will kill your HID's as there is not enough power for them. So if you have HID's, DRL's are no longer applicable in your application. Do you understand what I mean?
  18. #16
    Sep 2009
    Hudson, Wisconsin
    41
    Quote Originally Posted by angelico View Post
    I was thinking more of those separate LED Strips. I have adaptive curve lights (or what ever the official VW name is), and I want to keep them. and my fog lights.
  19. #17
    6th Gear
    Jun 2006
    Bklyn NYC
    9,416
    i have my HID's with DRL's so there on all the time except when i press e-brake button .... put the % to 100% and enabled HID without shutters..
  20. #18
    Sep 2009
    Hudson, Wisconsin
    41
    Hello VAG Com experts. Soembody here on the forum wants to sell me a new aftermarket VAG Com hex can usb with vcds 805.2 .
    Would this work with my 2008 Passat? Is $100 shipped an Ok price?
    Any advise would be very welcome.
  21. #19
    Mar 2008
    Minnesota
    35
    199
    sounds like a good price. That interface will work with b6
    but
    from Ross tech FAQs http://www.ross-tech.com/vag-com/faq_3.html#3.10
    3.10 Can I sell my VAG-COM System to someone else?
    You can sell the Interface, but the software license and support are not transferable.
    If you have a "dumb" interface and the purchaser wants the full-function version, he will have to register as a new user for $99.
    All of our Current Interfaces act as "dongles" for VAG-COM, so the software should be fully functional on any PC that meets our requirements. However, we only provide support to the original purchaser. If you purchase a second-hand "dongle" Interface and want to be a "registered user" and get technical support, you'll still need to pay $99 to register. 2nd hand owners of Ross-Tech Interfaces are not eligible for any of our Trade-In offers.
  22. Remove Advertisements
Human Verification
