Evap Emission Control System leak
Results 1 to 10 of 10
    Jun 2000
    Columbia, MD, USA
    48
    172
    Just went in for my 40K maintenance and was doing as much of it as I could myself. Part of that was scanning the systems for DTC's and I got one on the engine module.
    16826 - Evap Emission Control Sys: Small Leak
    I have cleared it and it showed back up after a weekend trip. I have tried making sure the gas cap is on real tight but still no luck. No engine light and the car seems to be running fine.
    So, anyone ever have this problem and was able to fix it themselves or do I need to make an appt with the stealership?
    -Tom
    Apr 2001
    Irvine, CA
    2,156
    Re: Evap Emission Control System leak (IMNewtMan)
    I would check the little rubber Y shaped hose on the top of the airbox. I was working on my airbox and the thing ripped with no force at all. It is part of the EVAP control system and runs about eight bucks at the dealer.
    Jun 2000
    Columbia, MD, USA
    48
    172
    I checked the top of the airbox. I didn't find anything loose or disconnected. I am not really sure about the Y shaped thing you mentioned though. I didn't see anything exactly like what you described.
    -Tom
    <![CDATA[I checked the top of the airbox. I didn't find anything loose or disconnected. I am not really sure about the Y shaped thing you mentioned though. I didn't see anything exactly like what you described.
    -Tom
    [Modified by IMNewtMan, 10:41 AM 10/15/2002]
  5. Remove Advertisements
  6. #4
    May 2000
    Denver, CO USA
    1,737
  7. #5
    Jun 2000
    Columbia, MD, USA
    48
    172
    Re: Evap Emission Control System leak (pipes)
    Pipes,
    I've added my info to the thread.
    No one else has had this problem with a successful outcome?
  8. #6
    May 2000
    Denver, CO USA
    1,737
    IM: I hear and feel ya
    On vortex, there is a thread about problems with 2003 GLS already..
    Interesting replies.
  9. #7
    May 2002
    Highland New York USA
    93
    i am also having the same problem. Didn't fix it yet though
  10. #8
    Aug 2001
    Janesville WI U.S.A.
    60
    186
    It could be your Evap Purge Valve. I've had mine replaced once, but last time I cleaned it and that cleared the CEL. This valve sits on top of the airbox(for V6s) and has two vacuum hoses and one electrical connection to it. I sprayed some carb cleaner into it from both ends and sloshed it around a little. HTH.
  11. #9
    Nov 2002
    Little Rock AR USA
    102
    IMNewtMan,
    Just wondering if you smelled gas when you started the car or at stoplights.
    Anyone,
    I'm having the gasoline smell problem right now and I'm trying to troubleshoot my entire EVAP system. I've looked at the purge control valve near the airbox and it doesn't seem to be a problem - at least not that I can tell. I start the car and don't smell any gas near it. But, it seems to be a part that fails quite often judging by the posts discussing the EVAP system.
    If the purge control valve fails to open, does it impact other EVAP components upstream of it? I thought maybe that if the system can't bleed out, a build up of pressure may cause a line to fail, etc.
    I haven't had a chance to look at the EVAP canister or the leak detection pump yet.
    I'm not seeing a CEL, just the gas smell.
    Any help troubleshooting this problem would be greatly appreciated.
    TIA
  12. #10
    Retired PassatWorld Staff
    Aug 2001
    Mahtomedi MN USA
    46
    6,165
    Also check the solenoid (valve for the evap system) on top of the airbox. It has a hose coming out of each end, and a 2-wire plug. Pull it off, and see if you can blow thru it. You shouldn't get any air thru. If you can, then that is very likely it, sans any other leak in the system.
  13. Remove Advertisements
Human Verification
