Jumper Cables Crossed Up - Hope This Helps Someone
Results 1 to 12 of 12
Like Tree6Likes
  • 1 Post By ElkRiverVWGuy
  • 2 Post By VAGguy
  • 1 Post By sirwired
  • 2 Post By ylwagon
Thread: Jumper Cables Crossed Up - Hope This Helps Someone
    Mar 2017
    Elk River, MN
    4
    Ok, I realize I'm opening myself up for some ridicule, but here goes ...
    My son's '03 Passat 1.8T sat all winter and the battery was dead, so I went to jump it with my daughter's '05 Escape. And yes, I made the bone head move of mixing up the cable connections on the donor vehicle! Luckily we didn't have an exploding battery, but the Escape ran like crap afterward and the Passat would crank but not start. (A battery disconnect and reconnect on the Escape reset the ECM and luckily everything was fine. Whew!)
    Wading through the forum here, it did not sound good for the old Passat! Visions of troubleshooting obscure electrical issues with ECU, CCM, TCM, relays, fuses, coils, etc, etc, etc about gave me nightmares.
    So, here's what I found and how I fixed it:
    First - I had the battery tested and charged.
    Again, the '03 AWM would turn over but not fire, so I pulled a plug, and tested for spark - nothing.
    I checked all of the engine-related fuses in the interior fuse panel again and they all looked good. (28, 29, 32, 34, 43)
    Next, I plugged in my OBD scanner and got an error indicating it couldn't connect.
    Now getting pretty mad at myself for the dumb mistake!
    Read some more forum posts about similar 'cranks but won't fire' problems and someone suggested checking the ABS fuse #7 because that apparently supplies power to 28 and 29 and maybe others? Pulled it out and it looked fine at first glance, but ohm'd it out and sure enough it was blown. Replaced that and the old boy fired right up!
    Everything seemed good, but the Monsoon radio was dead. Tried the pulling fuse 37 and resetting the radio, but that didn't fix it, so I pulled the radio quick and found the 10 amp fuse at the back was blown. Replaced that and the radio came back to life.
    All is good for now! (Fingers crossed)
    So ... if you hook up the jumper cables backwards on your B5, pound your head against the wall for being so dumb, and then check fuse #7.
    Let the ridicule commence!
    Joelio likes this.
    May 2015
    WA
    84
    I would say that we've all done it at least once. In my case, I was hooking up a battery charger.
    Hooked it up and plugged it in, but had reversed the leads. Fortunately, it blew the positive lead apart with no harm done to either the car or the charger.
    Whew!
    Sent from the 7th Galaxy.
    2nd Gear
    Feb 2013
    Oakland, CA
    817
    Mistakes happen, that one could have been more serious, but fortunately, sound like everything is fine.
  5. Remove Advertisements
  6. #4
    Jan 2017
    Andover, Minnesota
    119
    Thanks for posting, this info for sure will help someone out later on. Good fix and sounds like you dodged a bullet and not having to to the electrical song and dance and replace things. Where is the MAIN fuse on this beast, the 120 amp one?
    TomK
  7. #5
    May 2006
    Abingdon, MD
    39
    22,529
    Thanks for sharing. We generally aren't the type to rag on someone unless it is really deserving. In your case, it was just an accident. It was fixed and you wanted to help others that may have had the same problem. We thank you. There are many new or inexperienced (in cars) owners that may make the same mistake or at least have the same symptoms.
    Again. Thanks for sharing. This will help someone, I'm sure.
    Iowegian and TheRustySuper like this.
    Glutton for Punishment: 13 CC Sport Plus, 04 Passat 1.8T GLS Variant, 99 C-Red Passat 1.8T (crushed)
  8. #6
    5th Gear
    Nov 2003
    Raleigh, NC
    39
    5,291
    It bears noting that the new compact lithium jump boxes have reverse-polarity protection. Really, if I was fitting out a new car today, I wouldn't even bother buying jumper cables; those lithium jump boxes are superior in every way; more compact than even cables (much less a lead-acid jump box), don't require a donor car, hold charge for a year or so, and can even be used as a portable cell phone charger, because Why Not.
    mjmorrill likes this.
  9. #7
    Mar 2017
    Jacksonville
    37
    28
    It takes a big person to help someone learn from their mistakes
  10. #8
    Sep 2015
    Raleigh, NC
    46
    1,341
    No bashing from me. It happens. Has happened to me a few times and luckily nothing bad has happened. I made a post a month or 2 ago about the portable jump packs like sirwired mentioned above.
    I jump a lot of stranded motorists and have always had the big long cables and decided to try one of the jump packs by NOCO and it has worked like I needed it to many times over. It has been worth the $100 bucks and has reverse polarity protection so hooking it up wrong is impossible.
  11. #9
    4th Gear
    Sep 2002
    Yorba Linda CA USA
    4,251
    Quote Originally Posted by ElkRiverVWGuy View Post
    Fortunately, with occasional exceptions, that is not the environment at Passatworld, which is why I participate here and not other Passat sites.
    TheRustySuper and jjpark like this.
  12. #10
    Nov 2006
    North California
    32
    Quote Originally Posted by sirwired View Post
    Very true!
  13. #11
    Mar 2017
    Alberta Canada
    3
    Just wanted to pass on some gratitude for this info. There's an abandoned Passat where I work that hasn't run for about 1.5 years. Turns out that this was the exact issue.
  14. #12
    Apr 2017
    Silicon Valley
    31
    I noticed Costco has a sale on the Lithium jumper packs and thought about getting one. I have a larger lead-acid battery jumper module from Harbor Freight that I bought primarily to run LED lighting at craft fairs (but it's come in handy for jump-starting, particularly before I got the Passat and I didn't want to get a new battery for the Sentra before selling it to Cash for Clunkers).
    I think I'll get one while they're on sale at Costco this month (about $50) now that I know they work so well!
  15. Remove Advertisements
Human Verification
