Clutch chatter
Results 1 to 8 of 8
Thread: Clutch chatter
    Sep 2015
    kentucky
    112
    Clutch chatter
    My car has started to develop a very annoying shudder on takeoff right before the clutch is fully released.
    The disk, pressure plate and throwout bearing have 20k on them and have been without fault since install ... the flywheel is the original dual-mass at 165k.
    What's everyone's experience with this ... am I in for a new flywheel at this point?
    Pa. Motor, trans and snub mounts and axles are new so I know it isn't some kind of weird vibration in the rest of the driveline.
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    53
    24,386
    Since the mounts are new, it does sound like a flywheel issue to me too.
    6th Gear
    Feb 2013
    Bendigo, Australia
    8,145
    Did this start when the axles were replaced ?
    Are the axles OEM ?
  5. Remove Advertisements
  6. #4
    5th Gear
    Nov 2003
    Raleigh, NC
    39
    5,264
    I agree that it sounds like it is likely the flywheel. Really, since the flywheel has the springs in it that would normally be in the clutch disc itself, a new flywheel should be part of a regular B5 clutch service (and be included in the kit.) The LUK flywheel is both an OEM part (or at least was in some cars) and is not prohibitively expensive from Amazon or RockAuto.
  7. #5
    I'm going through same issue now, with a v6. But to Tomvw question...I did have both front axles replaced at dealership with OEM rebuilt axles... 2 months later...clutch is fading fast with shuddering at launch.....Should I be concerned??
  8. #6
    Sep 2015
    kentucky
    112
    The axles I put in are OEM remans ... still had VAG inner joints; basically just outers are aftermarket.
    The car has had a shudder on first takeoff in the morning especially when it's wet out for a while but never all the time like it was wen I posted.
    The weird thing is that I haven't experienced it in a few days now so ... maybe some weird "one-time" thing? Who knows.
    Ps. I'm used to driving BMWs where the dual mass flywheels cost like 600 dollars so I never bothered even looking when I did the clutch.
  9. #7
    6th Gear
    Feb 2013
    Bendigo, Australia
    8,145
    Maybe some oil got on the clutch during assembly and is now burning off, see how it goes.
    Oil on the clutch plate will cause shuddering and will be more pronounced with moisture present.
  10. #8
    May 2011
    MD
    160
    Hmm, have similar issues but thought it was User error. If I engage the clutch quicker, the shudder doesn't happen; and only in first gear from a stop. But with 225k on the ATQ motor, I'm wondering if this could be a failing crankshaft seal. I do plan to replace the clutch in another 10k or so; be interesting to find out what's going on in there.
  11. Remove Advertisements
Human Verification
