2003 passat b5.5 AWM
Control Module Part Number: 4B0 906 018 DP
Component and/or Version: 1.8L R4/5VT G 0003
Software Coding: 0016501
Work Shop Code: WSC 03158
2 Faults Found:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 002 - Lower Limit Exceeded
16683 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 002 - Lower Limit Exceeded
These are the codes that came up, anyone have any good ideas on what the problem is?
2 Faults Found:
