Rod bearings next... - Page 2
Page 2 of 2 FirstFirst 12
Results 31 to 40 of 40
  1. #31
    Dec 2008
    richmond
    403
    take your time find accident one you will good to go ,, you in greensboro i went there couple times i puck motor for my audi s4 they have pretty nice junk yards there but here in VA specially one about 20 miles from me called PUCK -A-PART man theres is so many vw audis dealer... don't have thim that many , some time just wana cry when i see so many died vw's well just do what you think is right for you , but if you decide to do a swap just do it now save your self some $$$$
  3. #32
    Dec 2013
    Greensboro NC
    283
    Have to check out that place in Richmond I'm through there all the time. I work in Arlington. Ive got a volcano black A4 that used to be in Richmond. You probably have seen it before.
    This is my other project
  4. #33
    Dec 2008
    richmond
    403
    Nice rides , got anything to thim ? Having a trouble to post my rides
  5. Remove Advertisements
  6. #34
    Dec 2013
    Greensboro NC
    283
    A4 s got a k04 and a GIAC p-16 file, 2.5 custom exhaust and stg3 south end clutch. Corrados in the process of getting an AEB 1.8t with t3/t4 turbo and AWM management.
  7. #35
    Dec 2008
    richmond
    403
    Let me know if you will need an t3 t4 turbo I got one 50 trim .48 at hot side , I was about to use on my set up but my friend hook me up with gt3076r also have test pipe Evolution racewerks , for 1.8t
  8. #36
    Dec 2013
    Greensboro NC
    283
    Swapped out the cam chain tensioner and the rattle is gone when warm and at idle. Oil pressure at idle however has gone down to 10 psi. I really need to put a mechanical gauge on it because I am really doubting the readings from my newsouth electronic guage. Engine finally sounds normal and cam journals look great. No codes present.
  9. #37
    Jul 2008
    Chicago
    54
    16,471
    My newsouth gauge started reading low one day. I saw the needle drop and my butt puckered for the worst. I pulled over and reseated the connector at the sender and the readings went back up. (de-pucker)
    So you've replaced the tensioner twice now and the second one worked?
    Did you ever see any metal sparkles in the oil when changing it?
  10. #38
    Dec 2013
    Greensboro NC
    283
    No metal in the oil
  11. #39
    Apr 2017
    Silicon Valley
    31
    When the rod bearing failed in my Triumph GT6, the engine had been making a characteristic high-pitched whistle (that I could hear and my ex-husband couldn't because he'd lost his upper frequency hearing). Do the VW engines make any characteristic noise when the rod bearing is about to go?
  12. #40
    4th Gear
    Aug 2001
    Southern, AL
    55
    4,627
    Few people ever get to the rod/main bearings making noise prior to failure on water cooled VW engines as they've had oil pressure warning lights since the beginning (~'74).
    On top of that, I've owned ~14 VWs over 35 years and never had one with an oil pressure light issue until recently. Gonna look at all the bearings (esp. mains) on a PL 16V engine this summer trying to solve an oil press. issue between ~1,700 - 2,200 rpm. Light goes off at 2,200, then if engine speed drops below ~1,700, comes back on. It's one of those niggling issues that's been with the car the past 30K miles...
  13. Remove Advertisements
Human Verification
