climatronic 256
Results 1 to 5 of 5
Thread: climatronic 256
    Nov 2012
    Louisville, KY
    77
    climatronic 256
    after doing a diagnostic test, error code
    256 00
    is popping up still.
    Ive looked and really not found anything on the website on what it is.
    4th Gear 2002GLXV6's Avatar
    Nov 2010
    Raleigh, NC
    3,074
    The code you have is actually 25b not 256. It is the Footwell/Defrost Flap Servo Motor. The following links will give you the info you need to convert climatronic fault codes and look up the meaning. Hope this helps.
    Climatronic fault codes (heater/window defogger blowing ice cold air)
    http://www.saunalahti.fi/~jues/Clima...iagnostics.pdf
    00603 - Footwell / Defroster Flap Motor (V85)
    00603 - Footwell / Defroster Flap Motor (V85): Faulty
    Possible Causes
    Wiring/Connectors from/to Footwell / Defroster Flap Motor (V85)
    Positioning Motor for Footwell / Defroster Flap Motor (V85) blocked
    Positioning Motor for Footwell / Defroster Flap Motor (V85) faulty
    Possible Solutions
    Check Footwell / Defroster Flap Motor (V85)
    See Measuring Value Blocks (MVB)
    Perform Output Test
    Perform Basic Setting
    Check/Repair Wiring and Connectors
    Check/Repair Obstructions or Blockage
    Special Notes
    Common HVAC Basic Settings Group(s) include 000 -or- 001
    Nov 2012
    Louisville, KY
    77
    Thanks! How do you access that part/area?
  5. Remove Advertisements
  6. #4
    Nov 2010
    Raleigh, NC
    3,074
    If you can just live with it. If not this will give you an idea of what is involved to gain access.
    It is #28 in the diagram below. You might want to stand on your head and see if maybe just maybe you can access it from the footwell on the drivers side. Got a kid with small hands?
    Footwell:defroster flap motor -V85-.jpg
  7. #5
    Nov 2012
    Louisville, KY
    77
    yea, ill just live with it lol.
  8. Remove Advertisements
Human Verification
