Pinch Bolt Removal (new method)
Page 1 of 2 12 LastLast
Results 1 to 30 of 34
Like Tree5Likes
Thread: Pinch Bolt Removal (new method)
    Nov 2003
    PA
    243
    After reading this excellent method from the info base ...
    PINCH BOLT REMOVAL made easy - pics
    ... here is a proposed method that may not require cutting the bolt with a dremel:
    UPDATE: AFTER READING EVERY THREAD ON THIS SUBJECT, I REALISED THAT THE METHOD I SUGGESTED BELOW IS NOT EXACTLY "NEW". IT SEEMS THAT PEOPLE ON THIS SITE HAVE ALREADY TRIED EVERYTHING ! IN PRACTICE, THE PROPOSED METHOD BELOW DID NOT WORK FOR ME. THE METHODS DESCRIBED BY JAY AND PZ WERE THE TECHNIQUES THAT ULTIMATELY WORKED. IF YOU ARE NOT REPLACING THE UPPER CONTROL ARMS, DO NOT USE HEAT, AS YOU WILL NOT BE ABLE TO GET THE HOUSING SLEEVE HOT ENOUGH WITHOUT COOKING THE RUBBER BOOTS (EVEN WHEN WETTING THEM DOWN TO TRY TO KEEP THEM COOL). WHAT ULTIMATELY WORKED IS A HEAVY DUTY AIR HAMMER (AVAILABLE AT "HARBOR FREIGHT TOOLS" FOR $15) AND KEEP APPLYING PENETRATING OIL. THERE IS ALSO A NEW TECHNIQUE I DISCOVERED THAT HELPED A GREAT DEAL. FOR THE BOTTOM LINE ON WHAT WORKS (WITHOUT USING HEAT) JUST READ THE POST 9 POSTS DOWN AND THE POST 16 POSTS DOWN. THANK YOU TO EVERYONE FOR ALL OF THE GREAT TIPS. WOULD NOT BEEN ABLE TO SUCCEED WITHOUT YOUR VALUABLE LESSONS ! )
    1) As always, pre-treat with penetrating oil (e.g., "parts blaster" or similar product). Spray at both ends of the bolt, and also spray in the grooves of the housing so that it can penetrate along the entire length of the bolt.
    2) As described in the info base write-up, place some washers in the grooves of the housing (but in both grooves), to prevent the housing from clamping down on the bolt when you are trying to remove it. The washers should fit snugly, but don't force the grooves open any further than they already are.
    3) Loosen the nut and unscrew it until it is near the end of the bolt, but do not remove it.
    4) Select a socket that fits the head of the bolt.
    5) Place the socket on the head of the bolt. (just the socket - nothing else)
    6) Place a c-clamp around the socket (at one end of the clamp) and around the opposite end of the bolt (at the other end of the clamp).
    7) Tighten the c-clamp unil it fits snugly, but do not apply brute force yet.
    8) Now continue to unthread the nut until its snug against the end of the c-clamp. This is to distribute the force of the c-clamp over the end of the bolt and also the nut as well.
    9) Being careful that the c-clamp remains in alignment with the bolt and does not slip, now proceed to apply brute force in tightening the c-clamp to force the bolt to move.
    10) Occassionally pause to spray more PB as the bolt moves.
    11) You will have to switch to a deep socket as the bolt comes out, and to use a punch (rod) to continue to push the bolt through.
    12) Even if you just get the bolt to move a 1/4" or so with this method, you can now get a clean shot at cutting the bolt head off and then proceeding with the procedure in the info base. This will also loosen the bolt and allow for better exposure to the PB.
    I tried this method the other day and it did not work. But I did not insert the washers as was recommended in the info base write-up. I believe this is why this method originally failed, and I plan on trying it again some day, but with the washers next time.
    If anyone tries this method, please let everyone know how it worked out for you.
    NOTE: AS MENTIONED IN THE "UPDATE" WHEN I ACTUALLY TRIED THIS METHOD IT DID NOT WORK. I USED A HUGE 18" INDUSTRIAL C-CLAMP AND IT ONLY ENDED UP DEFORMING THE BOLT. YOU NEED THE PENETRATING OIL AND THE INCESSANT VIBRATION PROVIDED BY THE AIR GUN IN ORDER TO BREAK DOWN THE RUST, AND EVENTUALLY THE BOLT WILL BEGIN TO FREE ITSELF. BRUTE FORCE ALONE WILL NOT DO IT. MORE DETAILS PROVIDED 9 POSTS DOWN.
    Nov 2003
    PA
    243
    Below is the mcmaster.com part number for the hardened-steel hex coupling used in the original info base write-up. On my 2003 Passat V6 FWD ATQ, the pinch bolt is 10mm dia (M10) size. So this is the hex coupling that will fit the M10 bolt:
    Part # 93020A782
    Also, here's the part number for hardened-steel "fixturing" washers that will help if you put these under the hex coupling (you should grease these up too). These are actually SAE (american) 3/8" washers, but they fit better (less play) than the metric M10 washers and have a larger OD too.
    98029A046
    btw, a lot of people said they tried the method in the info base, but instead of using the hex coupling they used the nut that was originally on the pinch bolt, and that the nut/bolt stripped out. Others have already pointed out the importance that using the hex coupling engages a lot more threads to prevent stripping, and also that its better because the coupling is of hardened steel. So you really should use the hardened steel hex coupling and grease everything up good!
    Jun 2010
    Berrien Springs, MI
    111
    Or use Map + Oxygen torch and heat the bolt till it's pink. Then dump water on it. Has worked every time.
  5. Remove Advertisements
  6. #4
    Nov 2009
    Upstate NY
    4,120
    I tried something similar, but instead of a C-clamp I used
    from Harbor Freight.
    Did not work. Since I don't have a real torch, I brought it to a shop to have the bolt removed.
  7. #5
    Nov 2003
    PA
    243
    Thank you for the replies. I'm always hesitant to heat things because am worried it would weaken the metal, or damage the rubber boots. Should I be concerned about that, or is it not really an issue ? If I knew it wouldn't hurt anything, then I'd defintely just break out with a torch !
  8. #6
    4th Gear
    Sep 2002
    Yorba Linda CA USA
    4,308
    I've got California cars so this bolt has never been a problem for me, but I'm wondering if anyone has tried the chemical approach. It seems to me that the corrosion would respond to mild acid (hot vinegar or dilute HCL aka pool acid) better than a solvent or oil. Naturally you'd have to figure a way to damaging prevent drips.
  9. #7
    Nov 2009
    Upstate NY
    4,120
    If you're changing the upper arms (as I was) torching the boots isn't really an issue.
  10. #8
    Nov 2003
    PA
    243
    Good point. I'm going to be removing the pinch bolt as part of the procedure to replace the wheel bearings. Don't know if I'll be able to get it done without harming the upper control arm boots.
  11. #9
    Nov 2003
    PA
    243
    Today I tried the "new method" I posted at the top of this thread and it didn't work.
    I then tried an air hammer/chisel and that didn't work either.
    This is all after hitting it with PB about 4 times over the past 6 months, in anticipation of doing this job.
    The air chisel was a real small crappy one, so I might try a bigger one this weekend. If that doesn't work, then I'm going to try the method that was suggested in the info base. I'm just worried about cutting the bolt, because then there's no going back. I'm also not replacing the upper control arms, so I don't want to use any heat that could ruin the boots or cook the grease in the sealed joints.
  12. #10
    Nov 2003
    PA
    243
    Pinch Bolt Success !!
    Today I was finally able to get the pinch bolt out ! And in one piece no less.
    What finally worked was getting the bigger air hammer gun from Harbor Freight. They sell two models, and it was the larger "Super Duty" gun (for only $15) that worked. Definitely one of the best bargains in tools!
    You have to use a combination of two techniques with this air hammer gun:
    First, as Jay and PZ mentioned in other posts, you have to use the flat chisel bit inside the spaces (cracks, recesses) of the housing sleeve. But first you have to blunt the chisel edge, using a grind stone, so that you don't cut into the pinch bolt. I also formed a U-shaped notch at the tip, as was suggested. (this is so that the bit will conform the the pinch bolt and not cut into it or deform it too much) I also ground down the thickness of the chisel so that it did not expand the spaces of the housing too much, otherwise you can crack the housing (again, thanks for the great advice!)
    The goal is to get the blunt chisel tip to hit against the bolt and vibrate it to loosen the rust and get it unseized. You keep hitting it with penetrating oil too (in the housing slots) as you are doing this, and the vibration apparently helps work the penetrating oil in. Don't just go straight in horizontally; you also have to rotate the gun to hit it from the top and bottom, and all the possible angles in between. Just be careful not to f-up the rubber boots. Also, with the penetrating oil, you should try to get it inside the top of the slots. There's a little cavity at the back top of the slots that the oil can pool in.
    Secondly, you also have to use the air hammer on the end of the bolt as well. In order to do this, you use the pointed chisel bit (bull point). I also blunted this tip with the grind stone so that it didn't cut into the bolt metal. You need to keep the nut on about half way to create a "pocket" to keep the chisel tip riding centered on the tip of the bolt. Actually, at first I did not use the nut because I bought the 10mm (M10) hex coupling from mcmaster.com noted above. (see part number in posts above) This coupling gives you a deeper "pocket" to keep the bit centered. Just be sure that the tip of the bit is contacting the tip of the bolt. You don't want the bit to be riding on the ID of the coupling. Then later, as the bolt is finally coming out, you will need to switch to the nut because the coupling will eventually bottom out. Its also good to have this coupling on hand in case you want to use the method in the info base.
    btw, you also turn the car's steering wheel all the way to the left or right, depending on whether you are hitting the housing slots versus the end of the bolt.
    Just keep alternating between hitting the housing slots versus the end of the bolt. I'd say a good 5 minutes on one, then switch. Alternate every 5 minutes or so.
    I was about to give up and then, like a miracle, I noticed that the bolt head had finally moved about 1/8" ! I knew right then that it was "all over" for that pinch bolt !
    Then I would tap the bolt head back in using a regular hammer (because you cannot access the bolt head end with the air hammer), and then hit the other end with the air hammer again; this way working the bolt back and forth, and hitting it with penetrating oil all along. Then I was finally able to turn the bolt head using a six-point socket and a 3 inch extension. You have to be careful not to snap the bolt head off. Then using a box wrench, I worked the bolt head back and forth quickly, hitting the bolt with penetrating oil through the housing slots and at the bolt ends as well. It kept getting more freed up as I did this.
    Then I was finally able to "go in for the kill" with the air hammer at the bolt end. Then the nut bottoms out and you have to remove it and use a punch or another bolt and tap it out the rest of the way using a regular hammer.
    Afterwards, my ABS trouble-light was on. But luckily, I read here that the same thing happened to someone else, and its just a matter of pushing the ABS sensor back in. (The vibration from the air hammer allowed it to pop out a little.) I cleaned the ABS sensor up, as well as the sensor's well/socket. And then wiped the sensor down with WD-40 before pushing it back in. You rotate it back and forth using slight 1/4 turns as you push it in. When it bottoms out, you back it out about the thickness of a sheet of paper by rotating a 1/4 turn, and back again, as you apply a slight pulling force. You don't want to pull it out too much. Its just so that the axle inside does not rub against the end of the sensor as the axle rotates. But the end of the sensor needs to stay close enough to the axle inside in order to sense the axle's movement.
    Thanks again to all the great advice here. There's no way I would have been able to do this without having learned from all the great tips on this board.
    Someone said in another post that removing a siezed pinch bolt is like a "right of passage" for the B5 owner. I couldn't agree more. Anyone I told about this (friends, family, co-workers) would say "all that trouble to remove a bolt" ?? But its comforting to know there are many here who understand the signifinace of finally "bagging" the pinch bolt !
  13. #11
    4th Gear
    Apr 2007
    Greensboro, NC
    3,185
    Please do not forget the anti-seize compound when you re-assemble.
  14. #12
    Nov 2003
    PA
    243
    Yes, definitely ! Thanks !
  15. #13
    May 2008
    acton, massachusetts
    5
    penetrant and hammers and clamps and torches, oh my....
    this pinch bolt story has a succesful ending:
    I pre-read all the posts on pinch bolt removal pain, and after much back and forth with wrenches, and much kroil and much pb blaster, and some attempts to press the bolt out with slave nut and clamp, and blow torch and mankinds second greatest invention: the hammer and yes, even mankinds greatest invention, the bigger hammer: I opted to try the dremel cut method.
    This was not the path to success. I cut through the head side slot and the head came out instantly as hoped. The tail however wouldn't budge, even using lubricated washers and oiled threads on the coupler nut, the bold snapped cleanly off at the base of the threads. Not twisted, snapped. Do you like folks to us emoticons in posts? the one where I have a baffled and sad look would be right at this point.
    So I took out a drill and a small cobalt drill bit and a center punch and carefully drilled a hole through the center of the bolt. I bought some replacement pinch bolts and nuts, and cut one the bolts off cleanly below the threads to use as a driver. Then I drilled increasing larger holes as deep as I could for a couple of hours (did I say carefully?), trying between each bit to lubricate the remains and whack at it with the driver bolt and a hammer.
    At one point, about 60% of the diameter, I used the dremel to make a through cut an the thread end pinch slot. The short piece then came loose and I was able to pull it out. The longer center piece was stuck though and I continued to enlarge the drill bit size until I broke through the wall of the bolt. The remains drove out with little effort, and I am left with a perfect 2 inch long C shaped crescent of bolt. The outside of it is almost clean, with tiny corrosion spots only, but they were enough to freeze it in place forever. the next time I go to replace the upper control arms, I will start with the Dremel cut and pull method, but plan to again drill the bolt out.
  16. #14
    Nov 2009
    Upstate NY
    4,120
    Quote Originally Posted by paulacton View Post
    That won't be necessary, because you will have liberally coated the new pinch bolt with anti-sieze once a year as part of regular maintenance. It will slip right out.
    wormybeech likes this.
  17. #15
    Nov 2003
    PA
    243
    Glad it worked out for you. And definitely -- never seez !
    It does seem that its the center section of the bolt (between the two pinch slots) that gets jammed up. I was reluctant to try the dremel cut method because I did hear of the bolt snapping off in some cases.
    I'm convinced (per suggestions of Jay and PZ, and from my experience of doing the 1st pinch bolt last weekend) that its incessant vibration thats needed, switching between all different angles.
    Tomorrow I'm taking the day off from work and going to try doing the 2nd pinch bolt using the air hammer method again. But this time I'm also going to add a new twist to the mix:
    It would have been good to have been able to get an impact wrench on the end of the bolt and, with low to medium torque, cycle back and forth between forward and reverse. But the space was just a little too tight to fit the impact wrench. I do have an air ratchet, but if the bolt head does not turn, then the air ratchet just freezes up (does not have any "impact" action).
    So at Harbor Freight I just picked up a compact, palm-sized "butterfly" impact wrench for $25 minus 20% coupon. I can't wait to use this thing tomorrow. The butterfly lever will make it so easy to cycle back and forth between forward and reverse. I think this, together with the air hammer/chisel, is really going to break down the corrosion quickly.
    I'm also going back first thing tomorrow morning to get the "air hammer quick release chisel holder" for $6. This is needed for two reasons: First, the HF "Super Duty" air hammer (more powerful than the standard model) actually ends up dislocating the chisel retainer spring. I think this in turn causes the gun to stop working and just blow air (which does happen, but not sure if these are related). This quick change holder replaces that retaining spring altogether, and will hopefully also stop the tool from "hanging up". The second reason is that this quick release holder will make it so much easier to change back and forth between the bull nose point bit and the flat chisel bit.
    Another thing that occured to me is that when I was doing the first inch bolt last weekend, its possible that the upper control arm pins may have been lifting up and catching on the bolt. So tomorrow I'm going to make sure that these two pins remain fully seated. I guess I'll just push down on them now and then, or maybe tap them down with a hammer. If it appears that they are in fact lifting up and catching on the bolt, then I may have to strap them down to the lower control arms, using something like ratcheting tie-down straps.
    Will report back ...
  18. #16
    Nov 2009
    Upstate NY
    4,120
    To make sure the UCA pins are not holding the pinch bolt, jack up a little under the steering knuckle to take any weight off.
    I would also use the air hammer on the steering knuckle itself, between the slots, to help free up the bolt.
  19. #17
    Nov 2003
    PA
    243
    HERE'S THE BOTTOM LINE ON WHAT WORKS WITHOUT USING HEAT (BUT HEAT IS INDEED RECOMMENDED AS LONG AS YOU ARE NOT TRYING TO SAVE THE UPPER CONTROL ARMS).
    Today I removed the second pinch bolt and it only took 20 minutes this time ! It was definitely as rusted in as the first one I did last weekend (that took 6 hours of experimentation to finally remove). These bolts had been exposed to 8 years of winter salt in PA and NJ.
    HERE'S WHAT YOU NEED TO HAVE:
    1) Air compressor capable of at least 4cfm at 90 psi.
    2) Air Hammer/Chisel Gun (get the "Super Duty" one at Harbor Freight for $15 and it comes with all the chisel bits you will need. Also get the "Chisel Quick Change Holder" that is a $6 accessory designed to be used with this gun. It turns this "okay" air hammer into an "incredible" tool.
    3) The hardened steel, 10mm hex coupling from mcmaster.com for $4. See part # above.
    4) A 16mm or 5/8" box wrench (or at least an adjustable wrench). btw, 16mm and 5/8" are about the same size; that's why you can use either.
    5) Some kind of penetrating oil. I made my own using a 50/50 mix of ATF (automatic transmission fluid) and mineral spirits. I also added a little acetone, MEK, and marvel mystery oil, but those ingredients are optional, and the acetone and MEK can harm paint and rubber. Pretty much any penetrating oil like Liquid Wrench should do fine.
    HERE'S WHAT YOU NEED TO DO:
    Pre-treat the pinch bolt between the pinch slots. Start doing every day for a week prior, if possible. Otherwise, just start applying the penetrating oil now. Also hit the ends of the bolt with the penetrating oil, but getting in the pinch slots is more critical, especially at the TOP of the slots so that the oil gets to the back of the bolt too. Throughout the procedure below, you keep hitting the area with penetrating oil about every minute or so.
    After the car is jacked up and the wheel is off, you take the nut off the pinch bolt.
    You are first going to use the air hammer with the flat chisel. But first you have to blunt/flatten the tip of the chisel using a grind stone. This is so that the chisel does not cut into the pinch bolt. Now, put this flat chisel bit into the air gun and lube the flats of the chisel tip. You are going to chisel into the pinch slots with this flat bit so that you SLIGHLTY expand the pinch slots back to their normal relaxed position. If you use the flat chisel bit thats supplied with the Harbor Freight air hammer, it will be the perfect thickness after you blunt the tip. Without too much trouble, the chisel tip will then contact (hit against) the pinch bolt, which is exactly what you want to happen. This way, the chisel tip will vibrate against the bolt and help break it free. You do this in both of the pinch slots. And as you do this, you hit it from all angles (not just coming in horizontally, but also from the sides, top and bottom).
    Then you switch to the bull-point chisel. But first you also blunt the point of this bit so that it will not cut into the bolt. Also, first grease the threaded portion of the pinch bolt. And then put on the 10mm hex coupling. Thread this coupling on all the way (but not tight). Then place the tip of the bit on the threaded end/tip of the bolt, and unscrew the hex coupling until it just starts to lift the bit off of the end of the bolt. Then screw the hex coupling back on about 1/2 turn or so. This is so that you are using the hex coupling to keep the bit centerted on the end of the bolt, but you do not want the hex coupling taking the brunt of the vibrations. Thats why you back it off about a 1/2 turn. Then you go at it with the air hammer for about a minute or so.
    Then repeat hitting the pinch slots with the flat chisel and hitting the end of the bolt with the point chisel. Keep alternating between these two methods and using plently of penetrating oil.
    Now here is a truly "new" method that seemed to really get the job done:
    You screw the hex coupling all the way onto the threaded end of the bolt. Then, using the box wrench or an adjustable wrench, you tighten the hex coupling and then loosen it. You keep doing this with 1/2 turns back and forth. What this does is it works the right side of the pincher back and forth and it is breaking down the corrosion. Keep hitting with penetrating oil. Just don't over do it with too much torque (up to 30 ft lbs at most).
    Then lossen the coupling and hit the end of the bolt and the pinch slots again with the air hammer one more time. Did I mention more p oil ?
    Now, you keep the flat point chisel wedged into the pinch slot that is closest to the threaded end of the bolt. (Or you can shove a thick washer in there. The slots are about 1/8" or 3mm wide.) The intention is that you are wedging something in there to keep the pinch slot from closing during this next step:
    After you have the chisel or washer wedged in the slot, you screw the hex coupling all the way on the threaded end of the bolt. Then, using the box wrench or an adjustable wrench again, you continue to tighten the hex coupling and then loosen it. You keep doing this with 1/2 turns back and forth. What this does is it works the bolt free at the center of the pinch sleeve where it is the most seized. You see, in the previous step you freed up the pincher near the threaded end of the bolt. Now, by wedging something in the crack, the force is transmitted to the center portion of the pinch housing sleeve. And you can go a lot tigher too (more torque) on the bolt because the pinch slot is being prevented from closing (flexing) too much.
    Continue to do this back and forth for a few minutes and using lots of p oil.
    Now, loosen the hex coupling and use the air hammer again on the slots and then on the end of the bolt again. More p oil.
    You should now miraculously see a small gap appear between the head of the bolt and the seating surface. In other words, the bolt will start to move ever so slightly.
    Keep oiling and keep at it with the chisel. Of course, when the hex coupling bottoms out, you will have to take it off and you can use the original nut to keep the chisel bit centered until that nut bottoms out as well. Then just use a hammer and a punch (or a thinner bolt) to tap the bolt out the rest of the way.
    As mentioned, use never-seez on the new pinch bolts.
  20. #18
    2nd Gear
    Jul 2003
    Calgary, Alberta
    47
    776
    Quote Originally Posted by bcking View Post
    Someone said in another post that removing a siezed pinch bolt is like a "right of passage" for the B5 owner. I couldn't agree more. Anyone I told about this (friends, family, co-workers) would say "all that trouble to remove a bolt" ?? But its comforting to know there are many here who understand the signifinace of finally taming the pinch bolt !
    Nah, more like a hazing than a right of passage, welcome to the club, someone should be along shortly to teach you the secret handshake (or maybe its to show you how to change the snub mount the easy way, or something).
    John
  21. #19
    Nov 2003
    PA
    243
    Cool! Much appreciated.
  22. #20
    May 2011
    New York
    13
    Just to add my recent experience: I used the "Cut the bolt head off" method. I didn't have the special coupler, so used a nut. Nut went on with spacer washers. Tightened and tightened until, lo and behold, the end of the bolt snapped off. Now I had a bolt with both ends missing. Hammered for another hour with a drift on the bolt. Nothing happened. Went to Harbor Freight and bought 2 sets of air hammer chisels. Went to work on the bolt from the end using the pointy chisel that came in the set (I ground the point off). Vibrated the thing with the split chisel. Went back and forth with each tool while squirting more and more penetrating oil. It worked!!! Kept driving it til the air hammer tool didn't fit , then used a drift and hammer, then finished with a hardened bolt. Took about 45 minutes. One trick I have to add: when using the split chisel on the joint, round off the corners of the chisel. It WILL slip off the fitting and hit your rubber bushings. Original Chisel:Sharp Chisel.jpg Chisel after GrindingGround Chisel.jpgGround Chisel.jpgSharp Chisel.jpg
    kdstrunk likes this.
  23. #21
    Dec 2014
    Lafayette, CO
    81
    Didn't work for me. The air hammer dug into the bolt and made the problem worse. I think I am buying a new steering knuckle but there is no rush because nothing is coming out of there anytime soon.
  24. #22
    Jun 2015
    Memphis, Tennessee
    55
    202
    I didn't have to much of a problem with the pinch bolt, I don't mean that it is easy but using a lot of liquid wrench, vibration with a hammer, moving the bolt back and forth no matter how little it is moving, more penetrating liquid wrench, more vibration, some beer, a lot swearing, some pushing with the rounded chisel or hardened bolt, more beer, some more swearing and when you feel the damn thing is coming out. You won't need to replace the steering knuckle and for doing so you need to take the pinch bolt out.
  25. #23
    Nov 2003
    PA
    243
    Good tips. Thanks for posting.
    Hopefully we won't have to go through that again. I keep mine coated with anti-seize now !
    aTOMic likes this.
  26. #24
    May 2002
    Hendersonville TN US
    53
    229
    Double any air hammer's power, free: Use an "anvil" behind what you're hammering
    +1 on the air hammer being indispensable. When working on a part that's not in a vise or on the ground (and being hammered downward), the force applied can easily be lost through movement of the part. A good analogy is to imagine a balloon on a string and a #2 Philips screwdriver. You could stab at that balloon all day and not pop it. Put it against a wall, though, and it would easily be punctured by even something relatively dull.
    I air-hammered for HOURS on one - until I could not hold the tool any more (haha, yes I have a big heavy tool), then I realized the bushings were absorbing the impacts. Got my BFH (10 pound sledge hammer), held its head against the steering knuckle/hub carrier opposite the air hammer, pulled the trigger, and the thing popped out instantly. If you don't have a heavy metal item laying around, a big rock works just fine (hence the "free" part).
    Whatcha gotta realize is there needs or be a firmly held part to hammer against.
    Also a nice carbide burr for grinding out remnants of the corroded-in bolts is worth its weight in gold (literally, almost, they're ~$40 for one with a long shank and end cutting, fine cut). Careful, though; on a die grinder they will eat through aluminum like it's butter. Also the carbide is brittle, so protect it by storing it in the tube it comes in, and don't drop it.
    Trivia on Kroil: if you're in Nashville, stop in their tiny factory off Thompson Lane; they love visitors and sell retail there. You might get to meet the inventor or his son (forget which one runs the place) No samples or t-shirts, though. If you're a Kroil fan, they have a funny newsletter (snailmailed) called "Genius at Work"; he writes whatever pops into his head, and they have specials (like buy a gallon, get two free aerosol cans - a lifetime supply). It's really geared toward the industrial user, but the formatting & graphics are retro cool without even knowing it.
    HTH your excellent post, bcking.
    -Tom
  27. #25
    Nov 2003
    PA
    243
    Quote Originally Posted by aTOMic View Post
    -Tom
    This makes so much sense from a physics point of view. Great analogy with the balloon. Will definitely keep this in mind going forward. Will be useful in many applications !
  28. #26
    Jul 2015
    Butler ohio
    36
    What I did; I knew heat was the only way and wanted to save the boots. I fabricated a sheet metal shield to fit closely under and between the ball joint pins. I think about 6" long? I bent this sheet metal upwards at about a 45 degree angle while keeping a sufficient space to place wet shop towels. While heating to a level to finally get any movement of the pinch bolt I had to switch out or replace the wet shop towels.
    Of course working PB Blaster and whatever methods I could eventually got the bolts out, Bead blasted the bolts, never seized along with new nuts, and cleaned the parent bore with a rat tail file.
    Clean any oil, grease, penetrating oil off the steering knuckle and give it a thick coat of paint to seal out moisture to prevent rust.
  29. #27
    Jan 2003
    Waterford CT USA
    27,854
    Blog Entries
    3
    oh, you poor SOBs! If I can't get the pinchbolt out and I'm changing control arms, I just cut the control arms off with a sawzall nowadays. Then I put the entire upright in a vice, and drill that pinchbolt right out - it's far easier.
    The angle required for a stock suspension is still set on the car, so the upper control arms are still on there - pull the entire shock/spring assembly after cutting the control arms off the upright, and replace 'em one at a time while matching the angle of the previous one.
  30. #28
    2nd Gear
    Jan 2010
    NJ
    51
    521
    Ahh, living in the Northeast where road salt is king.....
    The best way I've found to get the pinch bolt out is this Bentley video:
    Works every time for me.
  31. #29
    Jan 2003
    Waterford CT USA
    27,854
    Blog Entries
    3
    ...and most of us don't have access to the tool on the air hammer (at 1:50 in) that the video dude used the first time - I've seen that video many, many times. I have looked for that particular tool and can't find it. Suggestions?
  32. #30
    2nd Gear
    Jan 2010
    NJ
    51
    521
    I was able to get mine from a local place nearby but Sears has them:
    Sears.com
    JayTheSnork likes this.
  33. Remove Advertisements
Human Verification
