Window and door locks not working...
Results 1 to 11 of 11
    Jul 2011
    Montreal Canada
    38
    Hi guys,
    So I'm the new owner of a b5.5 passat, but its got 3 problems I'd like to fix, so I'll be making 3 thread.
    The second problem is that my window and electric locks on the rear driver's side door do not work anymore. I bought the car with this problem, but to my knowledge, both stopped working at the same time.
    And help would be appreciated guys! Thanks in advance!
    Jr.
    Jr. is offline
    Jun 2011
    Texas
    95
    (ignore)
    Jr.
    Jr. is offline
    Jun 2011
    Texas
    95
    Congrats on your purchase!
    First thing: if you can open your trunk lid from the front, your fuse is probably okay. If you can't, then that fuse (38) could be shot.
    Next thing I'd check is that the electronics on that side are hooked up. You can take off the door card (insert) following the instructions here.
    Make sure everything is hooked in properly and we'll go from there.
  5. Remove Advertisements
  6. #4
    2nd Gear
    Jul 2007
    New York, NY
    47
    797
    are your carpets damp?
  7. #5
    Jul 2011
    Montreal Canada
    38
    ^Carpets are dry!
    Quote Originally Posted by Jr. View Post
    Trunk button in the front works well. I'll take the door card off tomorrow and see what's up, but I'm 99% sure everything is plugged in properly
  8. #6
    Jun 2011
    Philadelphia, PA
    242
    May also be the wiring that runs to that door. Check the hinge area.
  9. #7
    murdered out Jetta, er, B5 Passat mrgreek2002's Avatar
    Sep 2001
    '99 1.8T - Toronto
    34
    11,170
    CCM wiring is the culprit.
  10. #8
    Jul 2011
    Montreal Canada
    38
    This is what im thinking...im gonna check it out today and let you guys know what i find
  11. #9
    4th Gear
    Oct 2002
    Campbellsville KY US
    4,022
    since it's only 1 door, it's most likely a messed up wire in the rubber boot between the door and the B pillar. You can pull the boot back and have a look at the wires. If the wiring to the CCM is the issue, more often than not there will be more than 1 door affected.
  12. #10
    Mr. Bieber 1st place WaterFest 17
    May 2007
    Blue AWD Ricer, MA
    4,625
    Quote Originally Posted by soundguybob View Post
    True. but when the CCM starts to go it will effect one side at a time. As mine is currently the same, my driver side doesnt lock but I can push it down and it does.
    Its annoying... but not worth it to fix at this time
  13. #11
    Jun 2011
    Philadelphia, PA
    242
    If you can't see anything you can check continuity of the wires from the door connector to the corresponding CCM connector pin using a multimeter.
  14. Remove Advertisements
Human Verification
