Expansion tank coolant leak
Results 1 to 6 of 6
    Dec 2007
    Kamloops, BC, Canada
    72
    30
    The 2002 Passat 1.8T had been leaking coolant from the expansion tank after shut down from a heat generating run. It seemed to be coming from the pressure release overflow tube at the rear bottom of the tank which had me start thinking bad to worst case scenarios - partially stuck closed thermostat, or defective water pump, or plugged radiator, or the worst of all cases, a blown head gasket or turbo. It turned out to be a very tight, small crack in the expansion tank on the bottom, near the overflow tube. No leak when cold, but with heat and pressure a drip or even spray.
    $50 for a new expansion tank, a 15 minute install, and the problem is solved. It turned out to be the best case scenario.
    Jun 2008
    Pittsburgh
    234
    How easy was it to change the tank ? Mine is discolored and I can't even see the fluid level.
    2nd Gear
    Oct 2009
    Socal
    668
    Very easy to replace.
    Dec 2007
    72
    30
    Very simple, three phillips screws, two hoses easily accessible, and one sensor plug from the bottom of the tank. It takes ten to fifteen minutes.
    Tor
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    53
    24,313
    When you replace it, make sure the inside of the hose is free of dried coolant. I would also use new clamps as the old ones can weaken over time.
  7. #6
    Jun 2008
    Pittsburgh
    234
    I see Parts Geek has them for $22 - maybe now I'll be able to see my coolant level.
  8. Remove Advertisements
Human Verification
