k03 turbo rebuild specs
Results 1 to 7 of 7
    Jun 2010
    SEPA
    190
    Hey all,
    I'm installing the 1.8t AEB out of a Passat into my mk1 1984 rabbit.
    I got a turbo rebuild kit for it, because there is a little axial shaft play (1/16" about) and there is 130,000 on the turbo.
    I have a mechanic friend helping me rebuild it (he has rebuilt turbo's before, so i trust him, he knows what he's doing).
    He asked me to find out what the torque specs are for the compressor bolt. Anyone have a list of the torque specs for a turbo rebuild or maybe instructions that include them?
    Thank you for any help in advance.
    May 2010
    South Africa, East L
    152
    rebuild kit should specify.
    Jun 2010
    SEPA
    190
    Rebuild kit came with parts but no instructions. I emailed the company to ask for specs, but figured I'd post here and see any responses in the mean time.
    anybody?
  5. Remove Advertisements
  6. #4
    Apr 2007
    Jerseys Finest
    1,244
    call up Gpop shop in Cali, they sell rebuild kits, as well as sell KO4 hybrids etc
    G-Pop Shop
    Ph: 479-751-7966
    OR just PM slappy dunbar
    EDIT: whoops, thought you said KO4 haha either way, both of those should be able to answer
  7. #5
    Dec 2001
    Shelton, CT USA
    60
    1,416
    I am not aware of rebuild kits containing a replacement turbo compressor wheel/shaft. That's beyond a simple seals and bushings rebuild. So any axial play you have now is likely to be a result of shaft wear in addition to bushing wear.
    Rebuild will give you better seals and extend end of life. But a worn shaft is a worn shaft regardless of the quality of rebuild.
    Good luck.
  8. #6
    Nov 2009
    Westchester Cty, NY
    53
    179
    When the turbo is off the engine and not filled with oil, even a new one will have radial (side to side) play. If you can pull it axially (in and out), then your thrust bearing might be worn. The bigger question is what do you plan to do about re-balancing it once its assembled?
  9. #7
    Jun 2010
    SEPA
    190
    Quote Originally Posted by theNofJboy View Post
    G-Pop Shop
    Ph: 479-751-7966
    Hey, thanks for the info! I gave them a call and they helped me out.
    In case anyone else is interested:
    OEM spec is 28 in/lb and if it's a right handed thread, add another 1/4 turn. If it's a left handed thread, turn it another 1/8 turn.
    Quote Originally Posted by slappy_dunbar View Post
    I think that the new bearings will fix the axial play and it needs new seals anyway. I'd hate to put it on and have a seal fail after a few hundred miles.
    As for balancing, i was under the impression that as long as I don't scrape the fins agains the housing and I mark the fins in relation to the shaft that it does not need to be rebalanced. Am i wrong?
  10. Remove Advertisements
Human Verification
