URGENT HELP!! Flashing dash lights...
Results 1 to 12 of 12
    Mar 2008
    Rexburg, ID, US
    32
    91
    Hey folks!!! its been a while since I've posted a question here, but this one I have no idea what it could be... My wife's 99' V6 is doing the following:
    When she is either driving or turning the engine on, the ABS, parking BRAKE and the OIL LIGHT start to blink and it makes a beeping sound for a while and then it stops. After a short while/driving the TRACTION CONTROL light joins the party and they all blink a few times and then it goes away.
    Electrical is not really my strength, so if anybody could help me out, even with the basics, I would really appreciate!!!
    Thanks in advance folks!!
    Grinding Gears...gone fishing! ScottPassat2.8's Avatar
    Feb 2005
    Staten Is. NY GLX2.8
    48
    22,620
    did you have a water leak recently or in the past?
    Mar 2008
    Rexburg, ID, US
    32
    91
    Hmmm...from the water pump area? not sure.... why?
  5. Remove Advertisements
  6. #4
    Overdrive
    Feb 2007
    Lehigh County, Pa.
    62
    11,826
    Can this be the infamous ABS module failure? Most of the symptoms are right. Do you get the STOP message?
  7. #5
    Feb 2005
    48
    22,620
    I meant inside the car, if the CCM gets wet then the problems start.
    It is a computer under the drivers side rug.
  8. #6
    Mar 2008
    Rexburg, ID, US
    32
    91
    Hmm... as far as I know, no STOP message, but the CCM getting wet could be a possibility... she took the mats out of the car and never put it back... just had the usual snowy winter up here in Idaho... so I could see the CCM getting wet... Is there a quick fix on that other then replacing it? :@
  9. #7
    May 2006
    Abingdon, MD
    39
    22,555
    being a '99, I'm leaning towards bad ABS module.
  10. #8
    Mar 2008
    Rexburg, ID, US
    32
    91
    Could the ABS module cause these other lights to go off though?
  11. #9
    Jul 2008
    Chicago
    54
    16,478
    Quote Originally Posted by JohanBaer View Post
    A bad ABS Module can cause the ABS light to illuminate and the BRAKE light to flash. It can also cause various other abnormal electrical behaviors. Sometimes part of the cluster stops working and sometimes it'll block vag-com from communicating with other modules.
    http://www.cheapabs.com/
    http://www.autoecu.com/audi/AudiRebuild.php
    http://www.modulemaster.com/en/index.php
  12. #10
    Mar 2008
    Rexburg, ID, US
    32
    91
    Ok... Thanks everyone for all the help... whoever thought of creating this forum should be made a statue or something... I'll check the sensors on the wheels and clean them up really nice and check to see if there's electricity coming out of PIN 15 on the ABS module connector... (module master suggests you do this...) and wait to see if this solves the problem, if not, I'll just send it in to get fixed....
  13. #11
    2nd Gear
    May 2002
    San Dimas, CA
    59
    817
    If you also can gain access to a VAG-COM system and have the codes read, if it has problems accessing the ABS module, (a communications error I believe is what it says), that's also a pretty sure sign the ABS needs a rebuild.
    Lots of posts on removing it to send to ModuleMaster or other rebuilder.
  14. #12
    Mar 2008
    Rexburg, ID, US
    32
    91
    Nice... Thanks man...I'll see if I can find somebody with a VAG-COM
  15. Remove Advertisements
Human Verification
