How long does my radio stay on, after I turn the key off?
Results 1 to 19 of 19
    Mar 2010
    New Plymouth, NZ
    37
    111
    So, yeah.
    Key on, radio on.
    Key off, radio stays on.
    Key off, door open, radio on.
    Key out, radio turns off.
    How long will my radio stay on after I've turned the key off?
    I have a habit of parking my car in the garage and leaving the key in (but off) if I'm going out again later. But, how long does the radio stay on? At the moment I have to take the key out and put it back in again, to get the radio to turn off.
    I don't want it to flatten the battery or anything dumb like that.
    Does anyone know if the radio will shut itself off after a while?
    Thanks.
    Aug 2007
    Maryland
    47
    2,261
    It will shut off when the battery dies. Or you can pull the keys out.
    Mar 2010
    New Plymouth, NZ
    37
    111
    Really?
    Doesn't seem like a very good feature if it will just run until the battery is flat.
    Hmmm. Oh well.
  5. Remove Advertisements
  6. #4
    murdered out Jetta, er, B5 Passat mrgreek2002's Avatar
    Sep 2001
    '99 1.8T - Toronto
    35
    11,170
    I'd say 45 min to an hour. Mine does turn off by itself, I can verify that. But this is with the key fully removed. It gets annoying when your in the car actually listening to music and it turns off by itself.
  7. #5
    Over 400K miles on my baby!
    Nov 2003
    Cross Roads, PA
    684
    By not removing the key you are keeping the entire comfort module active. You will run down the battery for sure (speaks from experience). At the very least remove the key and set it on the seat.
  8. #6
    2nd Gear
    May 2006
    Central Wisconsin
    682
    If the engine is off, the key is not in the ignition, and you turn on the radio, then it will turn off after 1 hour to save the battery. This might also be the case if the key is in the ignition, but I can't say with any certainty.
  9. #7
    Mar 2003
    ABQ, NM - 1998 1.8t
    1,853
    I know it turns off after 20 minutes if you have the key out, and turn the radio back on. Not sure how long it stays on if you leave the key in... you might set a timer for 25 mins and go back and see if you're really curious. If it is still on, I would assume it is gonna kill your battery and just stay on all night.
  10. #8
    Mar 2010
    New Plymouth, NZ
    37
    111
    Hmmm, OK. Interesting.
    I might have to do a bit of an experiment over the next few days then - time periods ranging up to an hour I think.
  11. #9
    Apr 2005
    Az
    225
    20 minutes.
  12. #10
    Nov 2009
    WI
    30
    237
    If you don't pull the key it will stay on until the battery croaks... learned that one the hard way... more than once!!!
  13. #11
    Only the name lasts forever
    Jan 2001
    D/FW TEXAS...
    6,142
    If you insist on leaving the key in the ignition, just pull the key out and reinsert it when you turn the car off...
  14. #12
    May 2006
    Abingdon, MD
    40
    22,594
    Quote Originally Posted by VWGUY4EVER View Post
    this
  15. #13
    2nd Gear
    Dec 2008
    MA
    29
    750
    Quote Originally Posted by ferrari_chris View Post
    Really?
    Hmmm. Oh well.
    i actually really like this feature. when i pull up somewhere and i am waiting for people, weather its for gas or waiting for friends or family, i shut off my car and without my music stopping i can listen until i am gonna leave again. and turn my car back on without the radio shutting off at all. the only time it will shut off when i am starting is if the battery is worn down enough that it needs to use all the energy to start the car.
  16. #14
    Feb 2008
    Oklahoma
    198
    Mine shuts off after about an hour. I found out at the drive in movies.
  17. #15
    Dec 2009
    Montreal
    50
    I've got a solution for you, which im quite surprised no one thought of this one...once you've turned off your car, they invented a power button, press the power button and it will turn off your radio.
  18. #16
    2nd Gear
    May 2006
    Central Wisconsin
    682
    Quote Originally Posted by skennedy1023 View Post
    The company I work for has a Jeep Commander. If you're listening to the radio while you're driving, it will not automatically turn off until you've parked the car, turned off the engine, removed the key, and finally opened the door. I'm not sure if I like that idea more or less than the VW method.
  19. #17
    Mar 2010
    New Plymouth, NZ
    37
    111
    Quote Originally Posted by Pat_Passat_B5.5 View Post
    That's even more of a change in behaviour than pulling the key out.
    I don't like that at all.
    I didn't get a chance to do some timing tests this weekend. Hopefully I'll get a chance during the week.
    I do have good news on my side mirror though!
  20. #18
    Mar 2010
    New Plymouth, NZ
    37
    111
    A development!
    So, I started the timer last night.
    Checked at 20 minutes: radio still going.
    Checked at 30 minutes: radio still going.
    Checked at 45 minutes: radio still going.
    Checked at 58 minutes: radio off!
    I'll run the test again when I can - maybe tonight.
    I'll keep you posted.
  21. #19
    4th Gear
    Aug 2006
    Halifax, NS
    44
    4,240
    Someday a psychic interface will be invented for people like you...
  22. Remove Advertisements
Human Verification
