Rear brake piston tool
Results 1 to 22 of 22
    Jan 2009
    Hemet, CA
    241
    Does anyone know if this tool fits the rear brake pistons on a 2003 1.8T FWD? Harbor freight has the $30 caliper tool set for disc brakes with all the attachments but I would only use one attachment in the set every other year. This might be a nice alternative for only $6.
    Jan 2003
    Waterford CT USA
    27,780
    Blog Entries
    3
    can't see it at work. is it the squarish one that fits on the end of a ratchet? if so, don't waste the money - it doesn't work 95% of the time.
    the one from Harbor Freight goes on sale several times a year for $20.
    Jan 2009
    Hemet, CA
    241
    yes, that's the one. thanks for the info! exactly what I needed to know.
  5. Remove Advertisements
  6. #4
    Resident a-hole knowitall
    Mar 2007
    eastern CT
    4
    15,669
    yup the square took sucks, FYI you can rent the real tool from autozone or advance auto and when you bring it back you get all your money back as well.
  7. #5
    Jan 2009
    Hemet, CA
    241
    great, even better.
  8. #6
    murdered out Jetta, er, B5 Passat mrgreek2002's Avatar
    Sep 2001
    '99 1.8T - Toronto
    34
    11,170
    I got my tool from a local Canadian auto parts store for $15. It looks good and seems like a decent design but you have to be really strong to compress that piston, I tried my hardest but couldn't get it to budge 1mm. Is there a trick to doing it if your weak?
  9. #7
    Mar 2007
    eastern CT
    4
    15,669
    is it the cube one? or the other one?
  10. #8
    Sep 2001
    '99 1.8T - Toronto
    34
    11,170
    The other one, you have to turn the knob to make the piston go in but there is too much tension for me.
  11. #9
    Mar 2007
    eastern CT
    4
    15,669
    gotta ask the stupid question here, but you have the E-brake off right?
  12. #10
    Sep 2001
    '99 1.8T - Toronto
    34
    11,170
    I don't remember really but I think so, yes.
  13. #11
    4th Gear
    Mar 2002
    Newburgh, NY AWM
    2,553
    Did you open the brake fluid reservoir to relieve pressure?
  14. #12
    Sep 2001
    '99 1.8T - Toronto
    34
    11,170
    yeap
  15. #13
    2nd Gear
    Dec 2008
    MA
    29
    750
    i bought a brake set just like this one. it works awesome and i havent had any problems with it yet. is this similar to yours?
    http://www.northerntool.com/webapp/w...2035_200392035
  16. #14
    2nd Gear
    May 2008
    New Hampshire
    754
    I had pretty good luck with the square thing. I put a 6" extension and a ratchet on the side opposite the one which fits the brake piston, and I pushed the caliper in while turning. The piston went back in without any issue. I'm sure the other tool works fine as well, but the first time I did this I turned the brake piston with a pair of channel locks while pushing in. That was very awkward and didn't work as well as actually having the right (or nearly right) tool for the job.
    You may have a different experience if the piston is frozen or badly corroded, in which case you may need a rebuilt caliper.
    On the fronts, I use a big "C" clamp which puts a lot of force on the piston. The advantage of this is that it always goes in easily, the disadvantage is that you can miss when one of the calipers is sticky (like the last time I did my brakes).
  17. #15
    Aug 2009
    Asheville, NC
    28
    Quote Originally Posted by skennedy1023 View Post
    ECS Tuning has that same set for $37 or so. I just bought it and it works perfectly. I've always wanted one of these. Should have got it years ago and saved myself the aggravation.
    -Nick
  18. #16
    5th Gear
    Apr 2001
    puget sound
    52
    6,736
    needlenose pliers and a normal caliper tool takes forever, but works.
  19. #17
    Jan 2003
    Waterford CT USA
    27,780
    Blog Entries
    3
    Quote Originally Posted by fritznh View Post
    Quote Originally Posted by l5gcw0b View Post
    alternate tools sometimes work, but it depends on your rear calipers WRT the kind of shape they are in. the first time I did rear brakes on my Passat, I tried the ratchet tool to no avail. I couldn't apply enough force to make it work.
    considering the money you save by doing your own brakes (as much as a couple hundred dollars), I highly recommend spending a little of it for the proper tool. using the ratchet tool with the nubs (that may not align with the notches in the piston on the caliper) is a crap shoot - I prefer better odds.
    the amount you spend on the rear brake tool can vary widely, so take the time to consider how often you will use it to determine how much quality you think you have to buy. for me, its mostly for working on my own car (and I don't have to replace brakes all tha often), so the Harbor Freight $20 tool is perfect.
  20. #18
    5th Gear
    Nov 2003
    Raleigh, NC
    39
    5,264
    Bizarre heads-up about that Harbor Freight tool... the tool itself works great. However, the red ink they use to print the wrapper comes off easily and permanently stains semi-porous surfaces. Two years later, I still have pink ink-stains on the door to my garage and the handle of my fridge.
    SirWired
  21. #19
    Nov 2004
    Shorewood, Wisconsin
    38
    211
    I've had this one for about four years. Well worth it. I've used it on my VWs as well as my freind's Toyota.
    http://www.harborfreight.com/cpi/cta...emnumber=97143
  22. #20
    2nd Gear
    Sep 2007
    Miami, FL
    592
    Quote Originally Posted by wisch View Post
    +1
  23. #21
    2nd Gear
    May 2008
    New Hampshire
    754
    The Harbor Freight tools look really solid, but the only car I'd need them for is the Passat. Still, tools are always good . I've also got a Toyota, so it might come in handy.
    I've replaced the brakes three times (this is the fourth set) on my car. Ok, it has 180+K miles on it, but I've got 140K on my Ford and I've done the brakes once. Both cars have good brakes, but the German ones need to be replaced twice as often.
    Would the A8 brakes improve this? Anyone run those for a few years and have some experience they could share here?
  24. #22
    Jan 2003
    Waterford CT USA
    27,780
    Blog Entries
    3
    fritz, the Harbor Freight brake tool is solid.
  25. Remove Advertisements
Human Verification
