What brand and type of brake fluid should I use?
Results 1 to 24 of 24
    Feb 2009
    Londonderry, NH
    41
    My 2001.5 GLS V6 5-speed needs new rotors and pads. I purchased 4 Meyle rotors (fronts and rears) and Mintex pads. When I change the rotors and pads. I also want to bleed the brakes. I've been reading that VW recommends Super DOT4 brake fluid. This is expensive and more difficult to find. Is Super DOT 4 really necessary or can I use a good DOT 4? What do you guys use in your passats? (brand and type) Thanks,
    - Dave.
    P.S. - Also, what is the best way to proceed with brake fluid changing/bleeding when replacing front and rear rotors and pads?
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    53
    24,573
    Valvoline Synthetic brake fluid is available at many parts stores and works great. I use about .75L for a full change with a power bleeder.
    For bleeding, remove as much old fluid as possible from the reservoir, then refill and start with the RR, LR, RF, LF and then the clutch. A power bleeder is much faster if you can get your hands on one.
    Nov 2004
    V6 4 Mo
    1,071
    Dot 4 is necessary, the brand not so much. I have been eyeing the ATE blue fluid for my next change since I will be d*mned if I can see the clear stuff in the Passat reservoir. The downside is that you will not see the discoloration of the fluid as it gets contaminated so you have to be diligent about changing it. I think it is illeagal in FLA for that reason.
  5. Remove Advertisements
  6. #4
    Feb 2009
    Londonderry, NH
    41
    So is it ok to use DOT 4 rather than Super DOT 4? It seems that VW specifies Super DOT 4 which is much more expensive and more difficult to get. Also, how much does a power bleeder cost and where can I find one? Thanks,
    Dave.
  7. #5
    4th Gear bass_lover1's Avatar
    Jun 2004
    NPR, FL
    3,038
    Quote Originally Posted by ddicosmo70 View Post
    Dave.
    IIRC I used Valvoline DOT 4 fluid, at least I think that was the brand it's been about two years since I did it (time to go again!), so I don't remember exactly, but otherwise I haven't had any issues with it.
    Go to your local parts store and buy some speed bleeders, PN 12706, you might have to order them, they're like 10 bucks for 4.
    They're one way check valves so you can bleed the brakes by your self, push the pedal and fluid comes out, release and the valve closes so no air gets into the system.
  8. #6
    Jun 2006
    UK
    248
    There is no such standard as super DOT 4, it's just a marketing buzzword like 'heavy duty'.
  9. #7
    Resident a-hole knowitall
    Mar 2007
    eastern CT
    86
    15,692
    I am a fan of Castrol GT- LMA Brake Fluid its the only fluid that i have found not to boil during an auto-x and the only stuff that i didnt have to bleed every 3 track days cause the fluid went to shit after super heating it, mostly cause i was so hard on the brakes they were smoking front and rear sometimes when i got done
  10. #8
    5th Gear
    Mar 2006
    montreal, quebec
    6,263
    Quote Originally Posted by snapdragon69 View Post
    Yes there is super dot 4 or dot 4 plus+,
    I buy Pentosin from my local parts guy for 10 bucks a liter.
  11. #9
    Lefties have rights, too!
    Apr 2001
    NY or MA???
    60
    15,663
    X2 for Valvoline!
  12. #10
    Nov 2010
    Colorado
    35
    33
    standard No. 116
    Quote Originally Posted by corradog60stage4 View Post
    This is the .gov page on Motor vehicle brake fluids.
    Standard No. 116; Motor vehicle brake fluids. - Federal Motor Carrier Safety Administration
    I did not see anything about "super" or plus(+).
  13. #11
    Oct 2011
    Brooklyn, CT
    127
    Get a power bleeder. One of the best car maintenance purchases I ever made. Once you pressurize the system, you can sit at the bleed valve and wait for the new fluid to arrive, then close the valve. Done.
  14. #12
    Apr 2001
    NY or MA???
    60
    15,663
    And very easy to find.
  15. #13
    Ray
    Ray is offline
    2nd Gear
    Oct 2003
    San Antonio, Tx
    52
    878
    Sorry to revive an old thread, so if I'm reading this right I should be okay using Valvoline for $5 a qrt instead of Pentosin for $24?
  16. #14
    4th Gear 2002GLXV6's Avatar
    Nov 2010
    Raleigh, NC
    3,074
    Quote Originally Posted by Ray View Post
    Yes, the Valvoline will work just fine. I prefer the Pentosin, but that's just a personal thing I guess. Who is trying to sell Pentosin for $24 a ltr? That's crazy! It should be around $12-13.
  17. #15
    Ray
    Ray is offline
    2nd Gear
    Oct 2003
    San Antonio, Tx
    52
    878
    thats what the guy over the phone at oreillys quoted me
  18. #16
    Nov 2010
    Raleigh, NC
    3,074
    He must have looked up the wrong thing. They can order it in $13.99 ltr only takes a day.
  19. #17
    2nd Gear
    Nov 2005
    Ellicott City, MD
    66
    876
    I also use the Valvoline Synthetic. My local Advance Auto Parts carries it and it's only like $7 or $8 per liter.
  20. #18
    Apr 2015
    NW
    70
    Quote Originally Posted by bass_lover1 View Post
    I am not sure what the length of the original bleeder screws are, but I have used the 12706 speed bleeders before and have had massive leaking issues due to not being long enough when tightened down. 12709 is a longer bleeder screw, being 35mm. 12706 is only 33mm. Again, not sure how long the original bleeder screws are but if anyone has trouble, its because the screw isnt long enough to seal.
  21. #19
    Ray
    Ray is offline
    2nd Gear
    Oct 2003
    San Antonio, Tx
    52
    878
    So I dropped the small round yellow cap into the engine bay somewhere and can't see it to retrieve it, can I buy it somewhere by itself?
    Sent from AutoGuide.com Free App
  22. #20
    2nd Gear
    Aug 2011
    Westerville, Ohio
    737
    Your VW dealer and our friends at ECS Tuning sell it as a separate part, but it's not inexpensive. One from a junk yard, perhaps?
    Volkswagen Passat B5 FWD 1.8T Braking Master Cylinder - 6N1611349B - Brake Reservoir Cap - ES#403799
  23. #21
    Ray
    Ray is offline
    2nd Gear
    Oct 2003
    San Antonio, Tx
    52
    878
    If I drive the car with out it, will it suck air into the system?
  24. #22
    5th Gear
    Nov 2003
    Raleigh, NC
    39
    5,298
    Well, brake fluid dissolves paint, so if some sloshes out, that would be bad.
    Also, you'll need to do a complete flush unless you live in a very dry part of the world, as brake fluid rapidly absorbs water from the air.
  25. #23
    Ray
    Ray is offline
    2nd Gear
    Oct 2003
    San Antonio, Tx
    52
    878
    I got it at a junkyard and I didn't drive car with out and it was out for a day only, it should be okay right?
  26. #24
    6th Gear
    Feb 2013
    Bendigo, Australia
    8,317
    Yes
  27. Remove Advertisements
Human Verification
