P0441 - Any possible link to...?
Results 1 to 26 of 26
    May 2009
    Frisco, TX
    50
    I have a recurring P0441 code...emission control system incorrect flow. This started happening shortly after I replaced the fuel filter. Is it possible that there is a leak somewhere in that hose that is causing the evap emission code? I don't smell gas or anything like that. I have had the purge valve replaced a couple of years ago, thought it unlikely that it's bad again. Also, the gasket on the gas cap seems OK, and I am always very careful to tighten it. Any thoughts?
    Sep 2008
    Ensenada, BC. Mexico
    486
    What about your SAIP? Do you hear it work while on cold start? Could be a broken pipemor something related to the SAIP. Also, check your kombi valve, if your saip is not working and it is full of water, your kombi valve should be changed.
    4th Gear
    Apr 2007
    Greensboro, NC
    3,177
    This is usually Gas Cap, Vacuum Lines, Purge valve.
    May 2009
    Frisco, TX
    50
    just ordered another Purge Valve...49 bucks. Will keep fingers crossed.
    Feb 2009
    Vancouver, BC
    56
    Could also be SAIP, combi valve(s)? My guess would be vacuum lines though. Cheap and easy to replace and usually need to be done anyway!!
  7. #6
    Sep 2007
    San Diego, CA
    2,116
    Quote Originally Posted by FriscoVW View Post
    Where for $49?
  8. #7
    Sep 2007
    San Diego, CA
    2,116
    Quote Originally Posted by iwill5.5 View Post
    IF vacuum lines would be running LEAN and poor MPG.
  9. #8
    4th Gear
    Apr 2007
    Greensboro, NC
    3,177
    Where did you get it for $49? Inquiring minds want to know.
  10. #9
    May 2009
    Frisco, TX
    50
    www.getcoolparts.com....$46.84. SKU # BSH076113
  11. #10
    4th Gear
    Apr 2007
    Greensboro, NC
    3,177
    Nice find!
  12. #11
    Sep 2007
    San Diego, CA
    2,116
    Indeed
  13. #12
    Aug 2009
    Camden, NC
    28
    1,229
    This happened to me too. turned out I had a quarter to 1/2 dollar size hole in my intercooler.
  14. #13
    May 2009
    Frisco, TX
    50
    Replacing the purge valve fixed it. Code gone, on to the next problem on the never ending list.
  15. #14
    Feb 2008
    Fairfax,VA
    14
    What passat you have?Does this BOSCH purge valve fit in 2000 GLX V6?
  16. #15
    May 2009
    Frisco, TX
    50
    I have a 2003 GLX with the 2.8L V6 (ATQ). I think the part is the same for all the V6's. But you should be able to look it up by model year to confirm that on the website. Or, just call the dealer parts department, they can confirm the VW part number for your car and you can search the website by that part number. Good luck.
  17. #16
    Thinks He is Slick
    Dec 2005
    6 low 3
    16
    4,483
    Why is the price for 1.8T $125.69 and 2.8 only $46 How much of a difference is this valve?
  18. #17
    May 2009
    Frisco, TX
    50
    You need to shop it around. Dealer wanted 137 bucks, found it online for $46. Depends on where you look. I found that it varies widely. Try getcoolparts.com.
  19. #18
    May 2009
    Frisco, TX
    50
    getcoolparts.com shows that this is the same part whether ATQ or AHA engine code. Should work on a 2000 GLX.
  20. #19
    Thinks He is Slick
    Dec 2005
    6 low 3
    16
    4,483
    I tried there and it showed $125, i searched for 1.8T tho not V6
  21. #20
    Feb 2008
    Fairfax,VA
    14
    Thank you,FriscoVW.
    I ordered purge valve from getcoolpart.com and replaced the faulty part just now.
    Hopefully P0441 code's gone forever
  22. #21
    2nd Gear
    Jun 2007
    Ca, North Bay Area
    705
    Is this Purge Valve hard to install? I have gone to several shops and replaced hoses of hoses and that P0441 still wouldnt go away. I just ordered mine from getcoolpart.com and hopefully it fixes it. Good thing I have similar car FriscoVW.
  23. #22
    Thinks He is Slick
    Dec 2005
    6 low 3
    16
    4,483
    Not hard at all.
  24. #23
    May 2009
    Frisco, TX
    50
    It's ridiculously easy. Takes less than 10 min. If you've changed your own air filter, you'll understand exactly what to do.
  25. #24
    Oct 2009
    2
    OK here's what I did and I have been P0441 free for 2,500 miles, (instead of the code coming up nearly every 300 miles). All i did was take the Purge Filter locatied on top of the air box, I disconnected the valve from the in and out lines, took pressurized air and shot it through for 20 seconds or so. put it back in and connected the lines. Also after every fill up I crank and torque the fuel cap to the best of my ability to get the tightest turn I can. Hope this helps because it did for me and its definately better than spending 80-100 dollars on a new purge valve. BTW I have a 2002 VW Passat 2.8 GLX non 4 motion 120,000 miles
  26. #25
    Oct 2009
    2
    you can also use a cadillac catera purge valve they are the same thing but for the bracket that is built into the Catera's valve which wont mess with installing it on a vw.
  27. #26
    Oct 2012
    Berlin New Jersey
    40
    36
    Parts Geek has the purge valve for 35 bucks for the 02 Passat glx 2.8.....I need one, can't shake the 0441 code.
  28. Remove Advertisements
Human Verification
