how do you disable the check engine light
Results 1 to 30 of 30
    Aug 2008
    4
    The check engine light of my 99 passat wagon is on.
    I went to a mechanic the other day to fix an exhaust pipe. However the check engine light was still on when he fixed it. He scanned it and found an evap code.
    He cleared it with the scanner. When I went to fill up my car. I found that my gas cap was missing. I bought a new one, put some more gas in the tank but the check engine light is still on.
    How do I disable the check engine light without a scanner?
    Resident a-hole knowitall
    Mar 2007
    eastern CT
    4
    15,675
    autozone can clear it, or you can play the waiting game it will go off by itself after so long if the problem has been fixed.
    May 2006
    Abingdon, MD
    39
    22,534
    if the evap is the only thing that set it off, then it should go away in a few drive cycles.
    dang it!
  5. Remove Advertisements
  6. #4
    Mar 2007
    eastern CT
    4
    15,675
    haha your slow
  7. #5
    Dec 2007
    Oregon
    1,157
    The gas cap was completely gone?
  8. #6
    $t0rm1n n0rm@n
    Mar 2005
    Everywhere!!!!!!!!!!
    37
    8,184
    Sell the car...Best way to get rid of a CEL
  9. #7
    Oct 2006
    Scranton P.A.
    1,070
    Quote Originally Posted by erodriguez927 View Post
    Just disconnect the battery, and let it sit for a few minutes.
  10. #8
    May 2005
    5780 ft
    1,657
    electrical tape
  11. #9
    Jul 2008
    Toronto, ON
    27
    1,450
    Quote Originally Posted by vdubb3dan View Post
    x2
    if that doesn't work im pretty sure the majority of OBDII(on board diagnostic) allow you to clear all codes and you can pick them up at places like canadian tire (im from toronto)
  12. #10
    B5V
    B5V is offline
    2nd Gear
    Nov 2000
    San Gabriel, CA
    605
    Quote Originally Posted by titanium173 View Post
    A..whaaat????
  13. #11
    2nd Gear
    Mar 2004
    Mission Viejo, CA
    569
    Fix the problem that is causing the CEL....
  14. #12
    Sep 2006
    plano, tx
    29
    13,923
    Blog Entries
    5
    Quote Originally Posted by nibor82 View Post
    i wanted to say that earlier, but i felt it was TOO obvious.
  15. #13
    May 2006
    Abingdon, MD
    39
    22,534
    Um sorry you're so late to the game guys, but chances are the evap code and CEL was because he has no gas cap. IF that fixed it, the CEL should go away soon.
  16. #14
    Sep 2006
    plano, tx
    29
    13,923
    Blog Entries
    5
    wait, what?
    our cares actually give a damn about the gas cap?
    i've gotten about 20 miles into a drive and realized my cap was hanging out the door once. (no sleep.)
  17. #15
    May 2006
    Abingdon, MD
    39
    22,534
    I don't think the B5.5 throw a CEL for this. I'm pretty sure the b5's do.
  18. #16
    Jul 2005
    65
    1,317
    Quote Originally Posted by VAGguy View Post
    My B5 does - you are right. I left the gas cap hanging off once, and drove over 20 miles before the CEL came on. Replaced the cap, and CEL went off in a few minutes.
  19. #17
    Sep 2006
    plano, tx
    29
    13,923
    Blog Entries
    5
    stupid hydrocarbon emission crap...
  20. #18
    Feb 2003
    Hamden, CT USA
    44
    2,214
    Quote Originally Posted by sipes216 View Post
    Evap systems have been mandated in vehicles since the early '70s. My '73 VW still has it, though it's largely nonfunctional because the parts are impossible to find.
    It was quite simple back in the day. Vent line went to a charcoal canister in the fender, which then fed a charcoal canister in the engine compartment. Air from the cooling fan blew into the rear canister, which then fed into the air cleaner housing (on the dirty side of the cleaner).
    Now it's just a 3.5mm hose that vents out into the fender.
  21. #19
    5th Gear
    Mar 2005
    Dallas, TX
    41
    6,255
    I dont understand why a loose gas cap would trigger a cel when the gas cap has it's own light.
  22. #20
    Sep 2006
    plano, tx
    29
    13,923
    Blog Entries
    5
    because p0440 is a code for an evap emissions controll system failure.
    the gascap light is specifically for a noticeable loss of pressure in the gastank only.
    440 has to do with a lot of other components as well.
    it also triggers the light due to federally mandated emission standardized codes (the p series). the gascap light is something that came later to say "hey idiot, check your cap"
  23. #21
    Jul 2005
    65
    1,317
    Quote Originally Posted by bill1975 View Post
    I'm pretty sure my B5 does not have a gas cap light (2001 AUG). But I am sure a loose or missing gas cap will throw a CEL.
  24. #22
    5th Gear
    Mar 2005
    Dallas, TX
    41
    6,255
    The B5.5 does. I assumed all 98-05 Passats did.
  25. #23
    Feb 2003
    Hamden, CT USA
    44
    2,214
    2004 and up has a separate light for the gas cap. Prior to that, it's just a regular CEL.
  26. #24
    May 2006
    Abingdon, MD
    39
    22,534
    Quote Originally Posted by ctobio View Post
    x2 My little gas cap light dings a few times a year.
  27. #25
    5th Gear
    Mar 2005
    Dallas, TX
    41
    6,255
    Learn something new every day....
    The funny thing is, the light looks like a car with a giant screw going into it (the screw being the gas cap I guess)
  28. #26
    Feb 2003
    Hamden, CT USA
    44
    2,214
    Nah, the screw is the dealership...
  29. #27
    5th Gear
    Nov 2003
    Raleigh, NC
    39
    5,291
    I'm curious about this light in my '04... I'm going to have to leave my cap loose just for the heck of it. Never seen it before at all.
    SirWired
  30. #28
    May 2006
    Abingdon, MD
    39
    22,534
    Quote Originally Posted by sirwired View Post
    SirWired
    It might not come on right away. It may take a few miles. Funny, someone wants a dash light to come on in a VW....
  31. #29
    Self inflicted facepalm
    May 2007
    SLC
    1,447
    That's been my experience!
  32. #30
    4th Gear
    Feb 2005
    sloatsburg, ny
    33
    3,259
    Quote Originally Posted by SivNiz View Post
    electrical tape
    x2
    my old favorite way of fixing dash lights
  33. Remove Advertisements
Human Verification
