B5.5 CAN Gateway Coding Tip
Results 1 to 6 of 6
    4th Gear
    Mar 2002
    Newburgh, NY AWM
    2,553
    So I was checking out the coding on some of the control modules in the Passat and came across the CAN gateway module. There was no pop-up bubble to help with the coding and so I went to the Ross-Tech website and looked up the possible coding.
    19 - CAN Gateway: -- KWP-1281
    Look at the last digit in the coding. Add the values for the options together to get the correct coding.
    0 - No available equipment
    +1 - Automatic Transmission
    +2 - ABS Brakes
    +4 - Airbags
    So, if you want to support Automatic Transmission, ABS Brakes, and Airbags, (add 1+2+4 = 7) = 00007.
    Interestingly enough, I have the AT, ABS Brakes, and Airbags, and thought the coding would be 00007, but upon inspection saw that it was coded as 00006, with the AT excluded. Why would this be? I would think I should just change it to 7 and just wanted to check here first.
    5th Gear
    Jun 2006
    Plano, TX
    29
    5,262
    Ross-Tech Typo?
    I wouldn't change it, but that's me. Although whats the worst that could happen, the car won't start?
    Overdrive
    Jan 2006
    Fargo ND
    32
    11,880
    Try changing it and see if anything happens recode it back.
  5. Remove Advertisements
  6. #4
    4th Gear
    Mar 2002
    Newburgh, NY AWM
    2,553
    Reasonable suggestions, thanks. If someone has a stored log from the last scan they ran on their B5.5 automatic on their computer, could they check to see what their CAN gateway is coded as? Thanks!
  7. #5
    Aug 2005
    Pittstown, NJ
    480
    Initial scan when I first got the VagCom. It's on an '05 Passat TDI, if that matters:
    Address 19: CAN Gateway
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 05311
  8. #6
    2nd Gear
    Nov 2002
    Wayzata MN USA
    859
    2003 GLS 1.8T 5M
    Address 19: CAN Gateway Labels: 6N0-909-901.lbl
    Coding: 00006
    Shop #: WSC 05314
    2002 GLX 4mo Sedan (Tip/V6)
    Coding: 00004
    Shop #: WSC 00028
    2003 was scanned 1 14 08 (when my coil pack died)
    2002 was scanned 11 02 07 (routine check up / oil change)
    God Bless Ross-Tech....!
  9. Remove Advertisements
Human Verification
