best type of oil for a 30v v6?
Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By John_E
  • 1 Post By John_E
Thread: best type of oil for a 30v v6?
    Sep 2006
    Robertsdale/Troy, AL
    28
    107
    I searched Google and PW, but I didn't get any useful results. What is the best type of oil I need to put in my 2000 v6?
    5th Gear
    Oct 2004
    Encinitas CA
    5,190
    VW officially recommends 502.00-rated oil, which always means synthetic, generally 5W-40, although Mobil 1 0W-40 and German Castrol 0W-30 are on the list, as well. Although I suspect you can safely use any high-quality 5W-30 dino in cool weather, 10W-40 in hot weather, or 10W-30 year-round in coastal southern California, a 0/5W-40 synthetic will give you an unbeatable combination of cold start wear protection and high temperature stability. The V6 engine tends to leak a bit on lighter oils, such as 5W-30 dinos, particularly during your Alabama summers.
    Bravino likes this.
    Sep 2006
    28
    107
    Hmmm.... I was under the impression that only the turbo models needed synthetic oil to prevent turbo sludge?
  5. Remove Advertisements
  6. #4
    Grinding Gears...gone fishing! ScottPassat2.8's Avatar
    Feb 2005
    Staten Is. NY GLX2.8
    48
    22,620
    you can use regular oil with no problem at all.
    i change every 5k.
  7. #5
    Sep 2006
    28
    107
    Ballin'. I think I'll go with the 10-W30 year-round since it's never extremely hot or extremely cold here.
  8. #6
    Sep 2006
    28
    107
    oh, and will any regular autozone oil filter be fine to use for just normal everyday driving?
  9. #7
    Jan 2007
    Orlando
    229
    I live in Florida and use my 99' v6 to deliver pizzas. I use Castrol 10w-40 and a Purolator filter, change the oil about every 2-3 thousand miles. Never had one problem in the 15000 miles I've had it.
  10. #8
    Dec 2004
    00 V6 variant/06 4-m
    64
    2,139
    Quote Originally Posted by scottpassat2.8 View Post
    i change every 5k.
    thats what ive been using on my two vw passats w/ V-6
    w/ no problems one has 76000,the other 90000
  11. #9
    Dec 2004
    64
    2,139
    Quote Originally Posted by HCO2102 View Post
    same here
    thats what i use on my two passats V-6 motors in summer castrol 10w40 05w30 winter and purolator filters ,like i said one has 76000,other 90000 ,no problems using that and a 5000 mile oci
  12. #10
    nm+
    nm+ is offline
    5th Gear
    Jan 2006
    Minneapolis
    5,404
    Quote Originally Posted by dan79 View Post
    Use something good. Cheap filters tend to suck.
    Also while you probably "can" use dino juice, 5w-40s a bit thicker and will prevent some oil loss as well as just being better for your engine, esp on cold starts (remember for an enige, 80F is "cold")
    at least in my 02 manual, vw recommended 502.00 for v6s, btw
  13. #11
    4th Gear
    Jul 2006
    New Berlin, WI
    50
    2,572
    If you can swing the cost of full synthetic. Do it. Far superior oil in any condition.
  14. #12
    5th Gear
    Oct 2004
    Encinitas CA
    5,190
    With the 1.8T, synthetic oil is mandatory.
    With the V6 and most other normally-aspirated engines with decent-sized sumps, you can generally use dino oil on a tight change interval or synthetic on a longer change interval. The first owner of my son's 1996 Audi A4 2.8Q (the old 12-valve V6 workhorse) used 10W-30 dino on a 5k mi / 8k km OCI. We just pulled the valve covers at 80k miles / 130k km to replace the leaky gaskets (after 12 years, they were unsurprisingly brittle and hard), and the cams look quite clean, with just a light coat of varnish, but no evidence of sludge or gunk.
    Because our cars get lots of stop-and-go severe service city driving, I keep all of them on a 3k mi / 5k km OCI, using 10W-40 high-mileage Castrol GTX in the 2.8, 5W-30 Castrol GTX in the 2003 Dodge 2.4L DOHC, and Mobil 1 0W-40 synthetic in the 1.8T.
    Bravino likes this.
  15. #13
    RG3
    RG3 is offline
    Jul 2005
    100
    so far I always use 5W-30 synthetic Mobil1 or Valvoline Maxlife Syn n change every 2.5K
    10w-30 synthetic or 10w-40 synthetic is good for California ??
  16. #14
    2nd Gear
    May 2006
    Central Wisconsin
    682
    Quote Originally Posted by John_E View Post
    I'll echo that. The original owner of my B5 V6 used whatever-was-on-sale 5w30 dino oil with filters of equal quality. Oil change intervals were typically every 5k-7k miles, but 10k+ OCIs were not unheard of. Unleaded 87 octane was the norm. The engine is in good condition, though.
    Partly because I'm a more spirited driver--and partly because I'm a sucker--I use Mobil 1 0w40. I change it every 5k and use OEM oil filters. The temperature in Wisconsin fluctuates by forty to fifty degrees daily. Summers peak at 110F, winters drop to -40F, and I can't anticipate which season my OCI will come. This is how I justify spending $45 for oil and a filter.
  17. Remove Advertisements
Human Verification
