Hand/Parking brake adjustment
Results 1 to 5 of 5
    Nov 2002
    West Midlands England
    5
    Since the dealer services my '02 1.8T, the handbrake doesn't seem to be fully releasing and is squeeling when at slow speed (handle only moves 2 clicks)
    Anyone know if it possible to adjust without another visit and if so where is the adjuster and how do I get at it?
    Cheers
    Andy
    May 2002
    back in Fairfax, Va.
    43
    261
    Did the dealer just do anything with the brakes like replaceing the rear pads? I had the same problem after swapping pads and not compressing the rear calipers because at the time I didn't know the trick.
    Sep 2002
    Philly, PA - BADDEST PASSAT ON THE BLOCK
    1,926
    The bently shows you how, i read it before i changed my pads, but didn't have to do anything with it. I can look later, if you dont have the bently. i will post later today what the bently says
  5. Remove Advertisements
  6. #4
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    53
    24,397
    Take it back to the dealer. To adjust the parking brake,you have to remove the
    heat shield under the center tunnel. The adjusters are under the back seat section
    of the tunnel. Unless you have a lift,it is not easy to work on.
    I know of one car that was stuck due to this. He pulled the brake handle hard several
    time to get the brakes to loosen. He probably streched the cable.
  7. #5
    2nd Gear
    Nov 2000
    Troy,MI 1999 GLS PASSAT 30V6
    773
    You have to retract the piston in the rear calipers if you put new brake pads on. But in general it wont be easy to put new pads unless you retract the piston and that should adjust your parking brake automatically.
  8. Remove Advertisements
Human Verification
