How long can I expect a water pump to last?
Results 1 to 28 of 28
    Lefties have rights, too!
    Apr 2001
    NY or MA???
    60
    15,663
    Hi,
    I've got a '99 1.8T with 86K miles. The dealer replaced the timing belt at 55K miles (under warranty). Can I expect the water pump to last another 24K miles until I have my timing belt changed again??
    What is the average life-span of a water pump theres days and how much does one cost?
    Thanks,
    Tom
    4th Gear
    Sep 2001
    Mayaguez, PR
    2,995
    Mine lasted 29362 miles and was replaced under warranty.
    Lisa Simpson
    Aug 2001
    Ddf, Germany
    15,044
    I'm close to Ricardo, 32K miles and replaced under warranty. Mine is coming out in the spring at ~60K since I only trust it for 30K.
  5. Remove Advertisements
  6. #4
    2nd Gear
    Sep 2003
    Fargo, ND
    541
    Well on TDI's I've seen some last 30k miles and I've seen some last up to 170k. Just depends how lucky you are. You might make it to the TB change, that's only 110k miles.
  7. #5
    Apr 2001
    NY or MA???
    60
    15,663
    Sounds like I'm running on a lot of luck.
  8. #6
    2nd Gear
    Sep 2003
    Fargo, ND
    541
    Yup. The good news is they USUALLY leak before they fail. :roll:
  9. #7
    Over 400K miles on my baby!
    Nov 2003
    Cross Roads, PA
    684
    Quote Originally Posted by Tom Parish
    149,000 miles here
  10. #8
    Aug 2001
    Granville, MA, USA
    18
    Mine was "weeping at 35K, but didn't replace it until 70K with timing belt.
  11. #9
    Nov 2001
    San Diego, CA -- Princeton, NJ
    3,172
    My water pump was running strong @ 77k miles when I changed my timing belt, water pump, and accessory belts.
    Took me and D-N-Tyke all day to swap that stuff, but saved me about $700 in labor charges. :-P
    The water pump cost like $75 if I remember correctly. I got it from ECS tuning.
    Anyway, it's hard tellin', but I'd say it will last through 100,000k if I were to bet money on it.
  12. #10
    6th Grade
    Feb 2003
    MO
    14,918
    If you'll just take a listen to your engine in a confined area such as a garage every so often, you'll be able to hear it going bad long before it causes any damage.
    Likewise, you'll be able to see the evidence of weeping long before it starts making noise, though this is not to say that they have to weep to make noise....
  13. #11
    Nov 2001
    3,172
    Quote Originally Posted by Sharky
    ..and be sure to OPEN the garage door when taking Sharky's advice.
  14. #12
    Apr 2001
    NY or MA???
    60
    15,663
    Quote Originally Posted by "SDPassat
    Or I could just hold my breath.
    Can anyone explain what sounds a water pump makes when it is going bad. Will they change as the engine speed changes?
    Tom
  15. #13
    6th Grade
    Feb 2003
    MO
    14,918
    Most often, it is a slowly (at idle) oscillating wow wow wowowowowo kind if noise. (Slower than most people think it would be, anyway.) Sometimes the wowow is kind of sandpapery, but it oscillates nonetheless.
    Yes, it will speed up as you rev the engine, but speed up too much and the wowow runs together and you can't hear it anymore.
    Also, remember that 1.8t pumps aren't run off the timing belt, so as long as you turn of the engine before it overheats from lack of coolant flow, you'll be fine.
  16. #14
    Jan 2004
    The Heart of the Sun
    2,373
    what does it sound like/ how hard to replace? Right now i got some sort of a very light tapping/clicking sound coming from the engine (1.8T with 1017xx mi, bought four thousand miles ago) down by the bottom pulleys and haven't had a chance to inspect it yet. Should I be worried?
  17. #15
    4th Gear
    Aug 1999
    Pacific Northwest
    2,663
    My water pump started leaking a little at about 50K, a little intermittent chatter developed at about 60K and I replaced it at 65K along with the timing belt and tensioner.
  18. #16
    Founder of the STFA
    Feb 2003
    Ohio
    8,667
    Like most water pumps, they usually fail after warranty expires and about 1,000 miles before you planned on replacing it.
    I've heard the approx 60,000 mile change with timing belt, etc is the best course to avoid an emergency repair.
  19. #17
    Jun 2013
    Connecticut, USA
    6
    I pushed mine on my V6 to 115K and I guess I got lucky. Would have been a mess if I had waited any longer. Manual says 105K and I have noted a few other parts breaking right on schedule. The real bummer is, my mech replaced it with a "good" kit, and I just had to do the whole thing over again as the replacement pump died after 20K miles. This time I got the Continental kit, which carries a 90K warranty, but not sure what that will get me if it happens again. The parts are almost incidental; the money is really in the labor.
  20. #18
    5th Gear
    Nov 2003
    Raleigh, NC
    39
    5,291
    Holy necro-thread Batman! This thread is older than my car!
  21. #19
    4th Gear
    Aug 2001
    Southern, AL
    55
    4,627
    Quote Originally Posted by sirwired View Post
    Not to mention the AEB water pump the OP refers to isn't driven off the timing belt. When you throw in the others (including those driven by the TB) which have both plastic and metal impellers...any discussion of How long a WP lasts becomes a train wreck since you're trying to compare apples to walnuts.
    Next week I'll be swapping a WP similar to the AEB (on an 89 Jetta GLI PL 16V - 120K miles on the WP) ..don't want to do thjs job in mid-December.
  22. #20
    Apr 2001
    NY or MA???
    60
    15,663
    Wow, I don't even have my '99 anymore. However, my W8 is now 9 years old with 136K miles and the water pump is still original.
  23. #21
    I break for old people
    May 2012
    Somewhere in Merica'
    7,549
    Quote Originally Posted by Tom Parish View Post
    6-Speed I hope?
  24. #22
    PZ
    PZ is online now
    Redline
    May 2002
    Grapevine TX. 01 4M
    53
    24,486
    Now it is doomed
  25. #23
    Apr 2001
    NY or MA???
    60
    15,663
    Quote Originally Posted by Bdubskii View Post
    6-Speed I hope?
    Of course!
  26. #24
    May 2012
    7,549
    Good man!
  27. #25
    Apr 2001
    NY or MA???
    60
    15,663
    Now it is doomed
    Paul, thanks for the vote of confidence. Hehe.
  28. #26
    Apr 2012
    Fond du Lac, WI
    154
    98 AEB - first timing belt done at 141K last year - original tensioner + water pump. Never had a problem with it.
  29. #27
    4th Gear
    Aug 2001
    Southern, AL
    55
    4,627
    ^ I'd take that chance with a WP...but not the TB.
  30. #28
    Wants to be TheFlipperGray
    Nov 2010
    Auburn, MA
    7,333
    Quote Originally Posted by Electron Man View Post
    I feel like timing belt failures as usually more associated with tensioners and water pumps, not so much the actual belt tearing or shearing by itself but rather a failed component doing the belt it. I wouldn't risk it on the original tensioners, but there's probably a lucky story like this for every group of horror stories - especially with an AEB having one less point of failure associated with the belt (the WP).
  31. Remove Advertisements
Human Verification
