How to adjust the clutch ?
Results 1 to 11 of 11
    Dec 2003
    Boston, MA "Surely you can't be serious" "I'm serious and dont call me Surely"
    192
    Does anyone know if it is possible to adjust the clucth, it is grabbing really high. B5 98 1.8T
    2nd Gear
    Sep 2002
    raincity, wa
    761
    its hydrolic...so im gonna guess no. but that is just a guess, so free bump
    Dec 2002
    Grand Rapids, MI, USA
    40
    2,281
    I don't believe it is adjustable. It normally grabs pretty high. But if it is higher then normal I think you may be ready for a new clutch?
  5. Remove Advertisements
  6. #4
    Nov 2000
    Lordstown Ohio USA
    80
    106
    Like valvecovergasket said, the clutch is not adjustable since it is hydraulic. You might have a worn-out clutch. Have you bled (flushed) the hydraulic system, including the clutch every 2 years as the manual recommends? Do you notice clutch slippage or noise(s) when shifting?
  7. #5
    2nd Gear
    Aug 2003
    Houston, TX
    970
    Re: How to adjust the clutch ?
    Quote Originally Posted by Tabamoura
    By "grabbing high" I take it to mean you don't have to depress the pedal all the way to the floor to shift without grinding. If this is the case your clutch is in good shape. You have a worn clutch if it engages when you have to depress the pedal very close to the floor.
  8. #6
    Nov 2002
    Belmont CA USA
    199
    Hmm... intuitively I would think that a worn clutch would engage farther from the floor than it should.
    Anyway, I've read that the clutch engages really high (from the floor) on all manual passats. I don't care for it very much, but its a fact of life.
    I am curious if the dealership has ever flushed my clutch/transmission fluid. I've got my 40k service coming up in a couple of months, so I'll ask about it then.
  9. #7
    4th Gear
    May 2001
    Portland, OR
    3,184
    yup, mine engageous near the top. Has since day one.
  10. #8
    Nov 2000
    San Francisco Bay Area
    34
    I do believe it's one of differences in Euro and US specs. In Europe, clutch starts grabbing 20 mm from the floor.
    If you check MKIV forum on VWVortex, there are tons of posts regarding "grinding". If the clutch would be setup here to start engaging right above the floor, MKIV drivers will have their transmissions replaced on a weekly basis.
    This is just a guess. [Flame suit on] After driving in Europe for a while I personally find US clutch setup horrible, but that's just me. [Flame suit off]
    Cheers, GreenG60.
  11. #9
    Dec 2003
    192
    The clucth works fine , no noise, it engages pretty good , no slliping, but it is toooo high,, this is my first passat and i did not know if that was normal.
    But since i cannot adjust it, i will have to deal with it.
    Thanks guys
  12. #10
    2nd Gear
    Dec 2003
    LA, Tarzana
    44
    871
    Oh, you just need to get used to it. I, for one, love it when it grubbs at the very top, just the moment you touch it. And it is a sign of a clutch in a good shape, AFAIK. I remember, when I first test drove new (then) Jetta IV (Bora) after driving Cabrio with clutch on its last breath, I killed engine like 3 times, because of how high it was engaging comparing to worn out one in Cabrio. Passat's clutch is similar to Jetta in feel when compared side by side.
  13. #11
    Dec 2002
    Havre de Grace MD
    464
    engages very late in the pedal travel, but it has to be on the floor to start the car.
  14. Remove Advertisements
Human Verification
