I wanted to adjust my hi/low s' up just a bit due to settling and I followed the instructions I found in a search
"For adjusting the low beams, there are 2 white plastic 6mm hex nuts above each headlight assemble. The inner nut next to the grill adjusts up and down....counter clockwise adjusts up /clockwise adjusts down.....the outer nut next to the fender adjusts left and right."
Now when I looked there I found the hex nuts and turned the inner one counter clockwise about a turn with no noticeable change on a wall 3' in front of the car. Does it take a lot of turning to get a noticable change? I didn't want to crank on it and wreck something. TYIA
I also am assuming there is only one adjustment for the hi & low together?
