Brakes failed last night - crashed the car
Page 1 of 2 12 LastLast
Results 1 to 30 of 32
    Aug 2001
    Cape Elizabeth, ME
    19
    So last night I'm driving home from my office, and my car beeps at me and flahes the brake light. about a mile down the road I go to slow down at a light and the brakes are so weak that I plow directly into the back of a Toyota camry. Everyone was all right, but the front end of my car is wrecked. The hood looks as though it was tin foil. It is still drivable, but needs some major work. It was a little damp put, but not raining. The worst part - The camry had one little divot where my license plate screw hit it, thats it. My whole front end it gonna need to be reworked.
    ARGHHHHHH!!!!
    Sep 2002
    Philly, PA - BADDEST PASSAT ON THE BLOCK
    1,926
    did you reacently do work to the brakes, or they just failed
    and im sorry
    Aug 2001
    Cape Elizabeth, ME
    19
    re
    no, the brakes had been fine. i was gonna take it in today for an oil change, but everything else has been working normally. I've lost all faith in this car.
  5. Remove Advertisements
  6. #4
    2nd Gear
    Dec 2002
    San Francsico CA USA
    827
    Re: re
    Quote Originally Posted by bags307
    When was your last brake job on the car?
    Who does the service for the car? If its a dealer, when was the last time he did one?
    Also do you know what caused them to fail or what?
  7. #5
    Aug 2001
    Cape Elizabeth, ME
    19
    A local factor trained mechanic that has always worked on my vw's did it around christmas time. I'm not sure what did it yet. Im assuming that ita ha something to do with either fluid levls (which seems odd - i watch that stuff) or some failure to produce enough vacuum for the brake booster
  8. #6
    Aug 2001
    Stockbridge GA
    1,374
    You got any enemies? Hit anything recently possibly? Damage to a hydrolic line or fitting sounds possible under car. Did you try the emergency brake while trying to stop? This is a mechanical brake vs. a hydrolicly operated system. Emergency brakes almost always work. May have saved you in this case.
  9. #7
    May 2002
    Charleston, SC USA '98 GLS 1.8T
    9,668
    Even if it was a vacuum issue, there is atleast a good 3 pumps of the pedal before its totally out. The brake booster is ment to hold the vacuum for how ever long it takes and for safety, the booster holds enough vacuum in the boosterif the brakes do fail, to still allow you to stop the car.
    Im sorry to hear that this happened but hopefully you can find the issue and get things fixed.
  10. #8
    Aug 2001
    Cape Elizabeth, ME
    19
    no, but i should have. It just felt like I had very little power to the brakes. Usually our brakes are touchy if anything, this time they were weak as all heck
  11. #9
    May 2002
    9,668
    Maybe its your tires? Are (were) they in good shape? Keep in mind that damp roads, and heat are a VERY bad mixture, and cause alot of accidents. The heat will make the oils and debris on the road come to the surface after a slight, misty rain. That causes the surface to be slick, and can make stoping very difficult. I just hope that you werent on a cel phone, and had plenty of distance between you, and the car infront of you.
  12. #10
    Jan 2001
    Alexandria, VA
    1,026
    Re: Brakes failed last night - crashed the car
    <snip> my car beeps at me and flahes the brake light. about a mile down the road I go to slow down at a light <snip>
    Why on earth did you wait a mile? If the brake light flashes, you stop right then and there!!!
  13. #11
    Never forgets
    May 2001
    Charlotte, NC
    2,380
    Quote Originally Posted by VAB5
    Doesn't it also flash STOP! STOP! STOP!
  14. #12
    Feb 2002
    NJ
    40
    1,523
    If your brake booster failed you would have anextremely hard brake pedal. If the pedal went to the floor, then it's possible that a brake line burst, causing all the brake fluid to leak out, and in turn turning on the low brake fluid level light (same as parking brake light) on. As soon as the light came on, you should of pulled over. I'm sorry to hear about your accident.
  15. #13
    2nd Gear
    Sep 2003
    Fargo, ND
    541
    bags307-
    When the light came on you probably should have stopped then. Oh well at least you weren't injured.
    I'll willing to bet a brake line corruded due to the nasty northern salt. I had the same thing happen to a Chevy Berrata when it was like 5-6 years old. Brakes worked great until I pushed them to at a red left turn signal, and nothing. Went thru the intersection at about 40mph and managed not to hit anything. :roll:
    Hope you can get the car fixed up ok.
  16. #14
    Aug 2001
    Cape Elizabeth, ME
    19
    thanks guys. Its going to the garage tomorrow. I was able to drive it home, but it isnt right. It scard the hell out of me though, and made me question alot of things about the car. The CAMRY that I hit had a quarter sized scratch on his bumper, and my whole front bumper, grill, and hood are wrecked. WHatss up with that!!!?
  17. #15
    Aug 2001
    Cape Elizabeth, ME
    19
  18. #16
    Jan 2003
    1,533
    Maybe thats one reason to not doubt your passat. You hit a camery and its so ridgid that it doesnt do anything. Whereas your passat absorbed most of the impact (doing what it was designed to do). I doubt it was the car. Like others said, the second the brake light went on you should have stopped IMMEDIATLY. VW Put these safety devices on our cars for reasons. If people choose to ignore them when they go off then blame it all on the car, then there is nothing anyone can do :roll: Sorry if I sound harsh, just not a great idea to ignore the safety warnings that our cars give us. Think about what would have happened if there wasnt a car to plow into. You could have gone into the intersection, gotten hit from the side at 40+ mph. I guarentee you that you would need much more than a new bumper if that happened :sad:
  19. #17
    Aug 2001
    Cape Elizabeth, ME
    19
    i know i should have heeded the light, and you are right. But i am blown away at how much damage there was to the car. So now the next question is: Should I get some aftermarket stuff instead of the stock peices. ?
  20. #18
    Dec 2002
    Grand Rapids, MI, USA
    40
    2,281
    Can you post pictures? Did your car dive under the Camry? Did the front bags blow? I am curious as to why you are suprised at the amount damage of to your car? I have seen several accidents where someone is rear ended and the bullet car has more damage then the target car.
    Having some pictures may help the rest of us better understand the damage.
  21. #19
    6th Grade
    Feb 2003
    MO
    14,918
    My Camry has been hit in back no less than 6 (SIX) times and the grand total of the damage is some scuffed paint on the left hand side where the lot porter at the last dealership hit it with an Audi.
    You should have seen the Audi.
    Hehe.
  22. #20
    Dec 2002
    New Market MD USA
    17
    How/why, would/did you drive your car after the warning light goes off for a brake problem, continue driving a mile, crash into another car because your brakes fail, sustain major damage to your car, then (are able to) drive it home?
    I just don't understand why you would question the car after it warned you that you had a break problem or why you would even attempt to drive it home after what you described?
    I am glad that the people in the other car and yourself are ok and didn't get hurt. I hope you get things figured out.
    Good Luck!
  23. #21
    6th Gear
    Nov 2000
    PA
    9,741
    What year was the Camry? Safety design standards have undergone a huge change in the past 10 years.
  24. #22
    Mil
    Mil is offline
    May 2003
    MD
    390
    Hey yo whuz the Dilio?
  25. #23
    Sep 2002
    NJ
    2,062
    That's sort of weird. I progressively lost all brake pressure during a 200 mile drive once, due to the rubber brake lines falling apart. But the car had over 200K miles and was 17 years old, and the brake lines were original. This just shouldn't happen to a relatively new car, even in salty conditions.
  26. #24
    Aug 2003
    Brooklyn, NY
    67
    Don't be too sure that the Camry you hit is without damage. Before we got our Passat we had a Camry (1991). It was hit from behind several times and there was always some sort of damage. The worst damage was when we were stopped at a stoplight on the West Side Highway in Manhattan. One car in front of me. In my rearview mirror I caught sight of a car that was clearly not breaking and headed right for us. The car hit us which sent us forward to hit the car in front of us, we bounced back and hit the car behind us again. My head hurt and a small piece of plastic that surrounded the ignition key area fell off. It appeared to be the only damage. We forced the guy to give us his insurance information (he was reluctant). We then went to the local police precinct and filled out an accident report. Lucky for us we did because we discovered, after taking the car in, that the underside of the car had shifted forward from the impact and it cost around $4000 worth of body repair -- paid for by our insurance. So, the Camry you hit, may or may not have suffered in this accident.
  27. #25
    Arj
    Arj is offline
    4th Gear
    Oct 2001
    Plano TX USA
    2,574
    Quote Originally Posted by JimboNmd
    I have to agree. What did you use for brakes on that drive home?
  28. #26
    4th Gear
    Jan 2003
    Sacramento, CA .... 2001 Audi A6 2.7T
    2,505
    Don't forget to let us know what caused the brake failure when you get the report from the garage! I think we're all curious about it.
  29. #27
    Mil
    Mil is offline
    May 2003
    MD
    390
    Quote Originally Posted by OneGuyInCA
    Yeah Me too? About the Passat being weak in the front end. I'm shocked about that cuz .. I've hit a wall once at just under 5 mph. (was really stupid how it happenned.. was on the phone and just as a rolled up to the parking spot i tapped on the gas instead of the brakes when i dropped my pen trying to scribble a number down) but anyway .. not a single line or sheet metal moved out of place .. all i had was just a little nick on the tag mount.
    Another innocent that i can vouch for about the structural integrity of the car is my passat was pushed really hard into a van that was in front of me when i got smashed in the back by a 8 ton flat bed .. again to my surprise only the tag mount was popped out of place but structurally not a line moved in examining the sheet metal alignment on the front..
    Needless to say the rear end quarters had to be replaced. It no fun getting rear ended.. especially when you see it coming and you look around and there's no escape root.. BTW the bastard was on his cell phone while driving that 8 ton tow truck .. isn't that ironic w/ my earlier self inflicted front end dinking with the wall. ( I was lucky not a scratch) .. Lesson don't talk on cell phones or answer phones while driving!!!!!!!!!!!!!! if you must pull off to the side of the road so you don't kill somebodies Beautiful Passat.
  30. #28
    2nd Gear
    Aug 2003
    Houston, TX
    970
    From the wrecks that I have seen, the rear ends of cars usually fair better than the front in collisions.
    Glad that you are okay and no one was hurt.
  31. #29
    4th Gear
    Aug 2003
    Milwaukee, WI
    2,913
    Any news on this???
  32. #30
    Apr 2003
    Cumming, GA
    374
    Most cars front bumpers are designed for aerodynamic purposes and not to take direct impact as well as the rear bumpers that are purely designed to absorb impact.... while the front bumper and hood are damaged, I bet the actual steel bumper hidden behind all the plastic is fine.
  33. Remove Advertisements
Human Verification
