V6 Alternator Replacement
1 reading
81K views 18 replies 13 participants last post by  Rob.Achmann
#1 · (Edited by Moderator)
Well the alternator in my waggie decided to crap out on me so I decided to tackle this job myself as I do not have ~$1000 to pay a shop to do this. So without further ado...
DISCLAIMER:I am a DIY mechanic. This is merely a guide to help others in fixing their vehicle. Always use proper tools, equipment, and safety precautions before working on any vehicle. I assume NO responsibility in damage caused to your vehicle as a result of this guide.
First off you're going to need to figure out which alternator you need.. there are 4, yes FOUR different types to choose from.
Options are as follows:
90 amp Bosch system
90 amp Valeo system
120 amp Bosch system
120 amp Valeo system
The two different systems are NON-INTERCHANGEABLE.
I highly recommend calling a VW dealer and having them check you VIN to verify the system you need.
My 2002 GLX V6 required the 120 amp Bosch system
OK now we're ready to tackle this bad boy..
A basic metric socket set, screwdrivers, ratchets, and a torx 20-50 set will be most helpful in tackling this job.
Very initially remember to disconnect the battery.
I would recommend doing this job in stages and placing the nuts and bolts in ziplock bags labeled with what they pertain too.
I put my car on ramps but it's your discretion.
1.) First off you're going to need to remove the front bumper cover. Most of you know how to do this but for the "HOW-TO" sake lets show ya.
(I didn't have a plastic skid plate so I didn't have to remove one but removal should be pretty self obvious.)
2.) Start by removing the three phillips screws which hold the intake tube on the radiator support.
^^ You can see them here in a row.
3.) Next up you will need to remove the grill. First remove the two torx 25 screws at the top of the grill on either side. The latch assembly is a little tricky but with a flathead you can push the two tabs apart and the grill should pop out.
Credit to Swankmonkey for providing a little write up in case you need it. http://www.swankmonkey.com/vw/passat/2005/grill_install/
4.) Underneath the grill you will find 4 torx 25 screws which will need to be removed
5.) Next up you will need to remove the 4 torx 20 screws located on the inner fender wells of each side. Three are on the front of the well horizontally and the fourth is located at the top of fender well vertically.
6.) Lastly if they are so equipped, remove the grill inserts for your fogs and then your fogs themselves. 3 phillips screws hold them in. Also removed the bulbs from the back of your turn signal indicators. Don't forget there is one flathead screw underneath that holds the bumper cover.
7.) Helps to have a friend but you can by yourself slowly pop the sides out and pull the front bumper cover off and enjoy yourself and sip of tasty beverage.. :thumbup:
8.) At this point your car should look like this and now your ready to move on to putting the car in the "Service Position"
9.) Now that your car is here we need to remove the bumper brace..I don't know exactly what it is called but whatever. It has 5 Torx 25 that hold it in place.
Two on either side at the top where you removed the torx for the grill. Two on either side on the bottom and one in the middle neither the latch assembly.
Remove this and place somewhere safe with the rest of your goodies your removed.
10) Now we can go ahead and remove the bumper. Two 17mm bolts hold it on.
11.) Now we can go ahead and place the car in the "Service Position". This involves removing 4 bolts on either side of the vehicle which allows the front clip to slide out and forward about 6-8 inches. Before proceeding, Unbolt the power steering oil cooler line and outside temperature sensor from the front of the LC. Also, remove the small retaining clip that secures the temp sensor’s wire. (All this is located and the bottom of the radiator.)
12.) I purchased 4 1/4" carriage bolts to use as supports in place of the lock carrier(LC) torx bolts (Torx 45). I removed one LC bolt from the top and one from the bottom diagonal from one another and inserted the 1/4" carriage bolts for support on both sides. Finally your remove the last two bolts and carefully slide the whole front clip forward. You'll feel a little tension from the coolant hoses.
13.) Now comes the really fun part!! :thumbup:
Using the same 17 mm socket find yourself a breaker bar and relieve the tension on the serpentine belt tensioner and remove the belt out of your way.
14.) I found that there is a bracket which holds condensor lines I believe which run right in front of the alternator. getting under the car and removing this will help you.
15.) There are two bolts which hold the alternator in place. One is a normal metric and the other is a torx 50. It would be helpful to have a buddy at this stage in the game. He should be underneath the car to brace the alternator. Remove the two bolts and allow the alternator to dip down so you can access the plug which attaches to the back of it. VW put another bolt to something else right above it so it's impossible to snag. Also remove the ground wire from the back of the alternator. I believe its a 8 mm
(moderator note - on my 99 B5, the lower bolt was a 13 mm and the upper was a large Torx, don't remember the size. the largest wire on the back of the alternator is not a ground - it's the power output lead, and it was held in place with a 13 mm nut.)
16.) My alternator was very snug in the mount and had to take some shots of PB blaster and persuasion :whistle: to remove the bad boy.
(moderator note: on my 99 B5, I had to use pry bars to get it to ease out of the upper bracket after the bolt was removed.)
17.) Once you have everything unbolted be prepared to play Houdini as you slide the alternator out being careful not to puncture the radiator.(You could drain the radiator and fluid to remove the whole front clip but who wants to spend and extra $40 on coolant!?)
(moderator note: on my 99 B5, the two refridgerant lines could be pushed down to help make room for the alternator, but it would not get enough room to be removed until I disconnected the rubber hose for the secondary coolant pump- it connects to a metal coolant line that runs across the front of the motor at the bottom - this will cause a good bit of coolant to drain.)
18. Once you get the alternator out go ahead and shout at the top of your lungs "I AM ALL THAT IS MAN!!!".. (that's what I did :p)
19.) Enjoy another tasty sip of beverage and take a quick break. Now it will take a little patience and fenagiling to get the new alternator back in.
20.) Once you have it back into place just remember the steps you took to get here and simply reverse.
After all said and done I started my car back up and allowed the battery to charge as I did the easy work of reinstalling the bumper, bracket, bumper cover, and grill.
Hope this is helpful and I'll try to revise it if I can scrounge up more pictures. Happy wrenching!!! :wrench::)
nice writeup, thanks.
my previous Bosch alternator work was to just replace the brush assembly, which was quite cheap compared to the alternator. but it was quick, simple and did not require removal. I wonder if that could be done on these units? what do you think? you have seen them, I have not...yet
#10 ·
I believe you cannot purchase new internals for the Valeo System.. However it is possible like you said for Bosch systems.. I will say that I don't think its possible to remove the back side of the alt. to replace the internals.. at least on a V6.. It's way to tucked in the bottom of the engine bay.. much like everything else VW engineered.. :crazy:
Damn, i always thode that putting the lock carrier to "service positions" was pain in the ass job to do, that's why been pushing it and waiting for summer to come... But seems relatively easy / quick thingie to do...
Btw, you know if the 120A altenators are equipped whit that free clutch ? For me the local "aftermarket dealer" that it specialized only to alternators has 6 different options for passat, 80A,90A,120A each whit, or whitout free clutch...
#14 ·
I just used this writeup as a basis for doing the alternator on my 99 B5. I can't speak for the B5.5, the secondary coolant pump hose has to be removed from the hard coolant line that runs across the front of the engine, or you won't be able to get the alternator out or back in place.
it's a tight squeeze. it is a good idea to have a couple of long-handled pry bars available to help force it off the top mounting bracket, as well as to tease it back onto the same bracket. I used my daughter as a helper, to push the upper bolt into place as I was prying it into position.
#15 ·
Thanks for this thread and to Jay and all for their input. I had to do what Jay did and lost about a galllon of coolant. Undoing the wire harness in the back was a pita. That and prying the generator out were the hardest parts. Once those two things are done, everything else is easy. The new unit slid in easy. Got a rebuilt one from www.thevwpartsstore.com. The updated Bosch part number is 038-903-018-FX.
#17 ·
90 amp Bosch system
90 amp Valeo system
Credit to Swankmonkey for providing a little write up in case you need it. Swankmonkey Racing's VW Passat TDi diesel
7.) Helps to have a friend but you can by yourself slowly pop the sides out and pull the front bumper cover off and enjoy yourself and sip of tasty beverage.. 👍
13.) Now comes the really fun part!! 👍
Hope this is helpful and I'll try to revise it if I can scrounge up more pictures. Happy wrenching!!! đź”§:)
