For advertising info, email us!
Home Forums Passat of the Month Marketplace About Us
Go Back   Passat World Forums > Passat Discussion > Club B5 > B5 Information-Base
Register Blogs FAQ Members List Calendar Search Today's Posts Mark Forums Read
B5 Information-Base The most wanted B5 Passat information is gathered for you all in one section. Only the best, and most informative, posts can be moved here by the PassatWorld staff.
Reply
Thread Tools Search this Thread
  #1
Old 12-23-2008, 09:43 PM
GC Lionel Mandrake GC Lionel Mandrake is online now
for your entertainment...
GC Lionel Mandrake is on a distinguished road
Default Refinished the leather on my steering wheel
Thanks to some great advice from my good friend OEM+++Variant, tonight I finished refinishing my GTI 3 spoke steering wheel. I currently have a 20th AE wheel in the car, as the old GTI wheel had a lot of the old dye worn off across the to top, say from 10 to 2.
here's how I did it...
Here's the initial wear spot that literally ran from 10 to 2:
I used Feibling's Deglazer to take off the finish and some of the original dye. Not all the dye will come off, but the wheel looked very matte and was nice and smooth. Not really pic worthy as it's just rubbing on a solvent.
However, here's what it looked like after the deglazing:
I then daubed on normal Zelikovitz black dye with a lambswool dauber, wiped off excess, and repeated again.
Afterwards it looked like this:
Then I used a leather aerosol spray dye to help with a nice, even finish, but messed it up (sprayed too close). So I used 1600 grit to wet sand the orange peel off. Once perfectly smooth, I applied two coats of spray dye on the wheel, which gave it a perfect covering and finish. No pix of the spray process cuz it's impossible to spray and shoot at the same time, but suffice to say I sprayed in even coats from a distance of about 75cm.
I then applied three coats of Zelikovitz 'professional top coat' with a clean rag, rubbing it on, to seal the leather and give it a nice finish.
Thanks again Jay!
It'll be re-installed in January, when I put in a new shifter. Pix will follow.
  #2
Old 12-24-2008, 04:22 AM
fookie fookie is offline
Confused
fookie is an unknown quantity at this point
Default
I can't wait for the pix... I always wanted to see how this was done.
  #3
Old 12-24-2008, 06:42 AM
Pimped Wagon Pimped Wagon is offline
Pimped Wagon is on a distinguished road
Default
We want Photos! My car has the same issue with the steering wheel. You might make a lot of people happy
  #4
Old 12-24-2008, 07:01 AM
Default
Quote:
It's not that hard to do, nor does it take much time really. It makes it waaay easier to do it with the wheel off the car, but assuming you can mask the interior of the car (sheets would work well) it can be done, although not sure how easy it would be to spray dye on the back side, unless you just re-dyed the front only.
  #5
Old 12-24-2008, 07:20 AM
passaturbonium passaturbonium is offline
passaturbonium is a trouble-makerpassaturbonium is a trouble-maker
Default
  #6
Old 12-24-2008, 09:53 AM
StattlichPassat StattlichPassat is offline
StattlichPassat
Default
Interesting... does it just look new or does it feel like new as well? I need this done as well but don't want a dried-paint feel on my worn areas.
  #7
Old 12-24-2008, 10:02 AM
Default
Quote:
It looks and feels new. Will post pix but it's kinda hard to get a decent pic, since it's a shiney black, round surface. Using leather-specific products means it won't feel like dried paint. Hell, even before I put the clear top coat on, it felt like brand new OEM.
  #8
Old 12-24-2008, 11:11 AM
ButchHusky ButchHusky is offline
ButchHusky is on a distinguished road
Default
Interesting. The finish on the steering wheel in my Corrado is getting a little rough on the top, maybe some of the Zelikovitz professional top coat will do the trick.
edit: did you use satin or gloss?
Brian
  #9
Old 12-24-2008, 11:59 AM
Default
Pix added above. Finish is gloss, considering it'll get a lot of wear, allowing it to wear into a satin finish.
  #10
Old 12-24-2008, 12:51 PM
ccollantes ccollantes is online now
4th Gear
ccollantes is on a distinguished road
Default
Wow! Great write-up Johnny! Where'd you buy the materials?
  #11
Old 12-24-2008, 12:54 PM
Default
Quote:
Got them at Tandy Leather Supply.
  #12
Old 12-24-2008, 01:46 PM
cpark cpark is offline
cpark is on a distinguished road
Default
Wow!!!!!!
  #13
Old 12-24-2008, 01:52 PM
dutch-mountains dutch-mountains is offline
dutch-mountains is on a distinguished road
Default
That turned out great!
  #14
Old 12-24-2008, 02:26 PM
KnoxHotch KnoxHotch is offline
KnoxHotch is on a distinguished road
Default
wow... that's awesome! looks like a ton of work, but well worth it!
my oem 4 spoke wheel started feeling rough around the top such as you described and soon after it cracked right on the top and it's bugging me... maybe time to upgrade to a 3 spoke
  #15
Old 12-24-2008, 03:33 PM
mnflycaster mnflycaster is offline
mnflycaster is on a distinguished road
Default
That is great! Thanks for the pics!
Dang it... Now there is one more thing to do on the car this year...
I was just going to buy a leather cover... now I have to this!
  #16
Old 12-24-2008, 04:20 PM
Confused
Default
I've been looking for a write up of this for a while...thanks! Info-base forum material indeed!
  #17
Old 12-24-2008, 05:04 PM
mrgreek2002 mrgreek2002 is offline
murdered out Jetta, er, B5 Passat
mrgreek2002 is an unknown quantity at this point
Default
That's great Johnny. My stock 4-spoke wheel looks like your your wheel before you fixed it. Now I know what to do to it, if I ever want to put it back on the car. But I doubt I will ever put it back on the car any time soon.
  #18
Old 12-24-2008, 06:28 PM
Default
Glad I could contribute and help some other guys along.
It really isn't that hard to do, nor does it take a whole lot of work. I'd say from start to finish, not counting time for drying, it took maybe 40 minutes of work.
  #19
Old 12-25-2008, 08:41 AM
captainfantastic captainfantastic is offline
captainfantastic is on a distinguished road
Default
Well done John
Looks fine.
  #20
Old 12-25-2008, 10:18 AM
JayTheSnork JayTheSnork is offline
Super Stealth Moderator
JayTheSnork is a jewel in the roughJayTheSnork is a jewel in the roughJayTheSnork is a jewel in the roughJayTheSnork is a jewel in the rough
Default
canuck, that looks great. can anyone else say, "Info Base Forum?"
__________________
99 GLS, 2.8 V6, Leather, Cold Weather pkg, driven 120 miles/day, Mon-Fri
I has a sig!
  #21
Old 12-25-2008, 12:32 PM
20vvillian
Guest
Posts: n/a
Default
Sweet finish, now only if that worked on the door grab handles.
  #22
Old 12-25-2008, 05:00 PM
slobo7x slobo7x is offline
slobo7x is on a distinguished road
Default
damn that looks good man!! Wow, i may have to do this as well..
  #23
Old 12-25-2008, 05:17 PM
senseless1707 senseless1707 is offline
4th Gear
senseless1707 is on a distinguished road
Default
looks really good!! such a big difference!
  #24
Old 12-25-2008, 05:39 PM
sipes216 sipes216 is offline
sipes216 is on a distinguished road
Default
Quote:
does "go for it" sound close enough?
  #25
Old 12-25-2008, 06:45 PM
Default
I'd be honoured if it was moved there.
  #26
Old 12-25-2008, 06:53 PM
Default
Quote:
done.
canuck, now you are obligated to leave the pix on the pix hosting website for eternity.
__________________
I has a sig!
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Web www.PassatWorld.com
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Disclaimer: PassatWorld.com is an independent enthusiast website and is in no way related to the Volkswagen & Audi Group of Companies. Comments made in the PassatWorld.com discussion forum are the views of the respective poster and in no way represent the views of the web site’s owner or staff, therefore, PassatWorld.com is not responsible or liable for any content or claims made in such posts. Additionally, PassatWorld.com provides links to third party World Wide Web sites which it has no control over. PassatWorld.com is not responsible for the availability of such external web sites or resources, and does not endorse and is not responsible or liable for any content, advertising, products, or other materials on or available from such sites or resources.
