My Passat has had an AC problem since I picked it up last month. Through the tips I've learned here, I was able to check the Climatronic codes and found error 313 which relates to outside air temp sensor.
So I got pissed off today that it wasn't working, as it has only worked maybe 8% of the time the last few weeks. I remembered how to access the diagnostic menu and all the temps looked good, except on diagnostic page 04, where the temperature displayed is -47 degrees Centigrade!
So, tell me if this sounds right. Even if I set it on full max cool, the compressor does not run. Is this because it thinks its below freezing outside, so it's just pumping in outside air? I'm thinking this is true since it will also switch from recirculate to outside air when it faults.
So again, will it cut the compressor if it thinks it's freezing outside, or do I have another problem along with this temp sensor?
Also, anyone know where the outside temp senor is? I think it may be in the HVAC intake ducting behind the glovebox, but don't know for certain.
