For advertising info, email us!
Home Forums Passat of the Month Marketplace About Us
Go Back   Passat World Forums > Passat Discussion > Club B5 > B5 Garage
Register Blogs FAQ Members List Calendar Search Today's Posts Mark Forums Read
B5 Garage The specific technical and "how-to" help forum for the B5 Passat. Have a detailed technical question? Post it here.
Reply
Thread Tools Search this Thread
  #1
Old 01-09-2007, 01:44 PM
3rdtime 3rdtime is offline
3rdtime is on a distinguished road
Default CEL with P0010 (Camshaft Position Actuator ABank-1 Circuit Malfuntion)
As stated in thread title, I was blessed with a CEL yesterday evening. The corresponding code is P0010, with a description of "Camshaft Position Actuator ABank-1 Circuit Malfuntion."
I recently changed my timing belt. Could this be related? Did I mess up the sensor when I was disassembling the front of the engine and cleaning everything with brake cleaner? Hopefully I didn't drown the sensor or something stupid like that.
Does anybody know if this is easily remedied by installing a new sensor? Or am I faced with something much worse like installing a new camshaft? I tried searching, but there was very little in the forums related to this specific code.
  #2
Old 01-09-2007, 03:31 PM
TwoManyPassats TwoManyPassats is offline
4th Gear
TwoManyPassats is on a distinguished road
Default
That's the solenoid in your cam chain tensioner on the back of the engine. Did you have that much overspray? Check the resistance. It should be between 10 and 18 ohms.
  #3
Old 01-09-2007, 10:08 PM
Default
Quote:
Dammit. I realized this as I drove home today. I was confusing the tensioner with the hall sensor. Cripes. Should I even bother testing it if the CEL is on? I mean, obviously the car already thinks it's bad. Grrrr... And if I do test it and find out (confirm, rather) that it's bad, is there anything I can do to bring it back to life? Or am I then faced with buying an entire new tensioner?
Good God. Just looked up the part #: $340 + $6.62 for the necessary gaskets. Not to mention I'd need a $40 valve cover gasket too. Oh brother.
  #4
Old 01-10-2007, 04:06 PM
Default
Bump for more info. I drive ~100 miles/day and don't want to do any more damage than I may have already done.
Thanks in advance.
  #5
Old 01-10-2007, 04:56 PM
4th Gear
Default
Unless you are hearing rattling from the chain, I think the only thing you'll lose is performance. What was the resistance reading?
  #6
Old 01-10-2007, 07:55 PM
Default
I've lost some performance. And I suck. Have not yet had a chance to check resistance on the unit.
I can't say I've noticed any chain rattle. Even if this part fails completely, I'll still be pretty much where I am today, correct (a small loss in power, an illuminated CEL)? In other words, the chain isn't gonna just let go and destroy the engine somehow, right?
Sheesh. When it rains it pours with Passats. Until 2 weekends ago I was freaked out about driving with so many miles on my original TB and tensioner. Now I have this mess to work out I miss my Jetta.
  #7
Old 01-10-2007, 08:08 PM
pete1 pete1 is offline
5th Gear
pete1 is an unknown quantity at this point
Default
If you aren't hearing any cam chain noises, I think there is a very good chance its just a loose/dirty connector. Spray the connectors with electronics cleaner when you check the resistance.
Also, if the resistance is out of spec, try exposing some of the wiring and testing directly... you may only need to replace the connector.
  #8
Old 01-10-2007, 08:14 PM
4th Gear
Default
Imagine a football with the exhaust cam on one end and the intake cam on the other and the chain going around the football longways. The football is the tensioner. Push the football up and the exhaust is advanced and the intake is retarded. Push down and the opposite happens. This is what the solenoid does.
  #9
Old 01-10-2007, 08:27 PM
5th Gear
Default
^^^Yup. ...and only on WOT in first gear from a dead stop, IIRC.
  #10
Old 01-10-2007, 08:45 PM
Default
Got it. So with an effed up solenoid, the chain remains in one place as opposed to doing anything to the timing.
I will check the resistance as soon as I'm able, as well as give the area a good cleaning. Hopefully it's gunk and not a dead solenoid.
Thanks guys. I appreciate the help. At least I can ask questions here without being accused of being a noob every time I speak (ahem, vwvortex, cough, cough)
  #11
Old 01-10-2007, 09:37 PM
4th Gear
Default
Noob!
  #12
Old 01-10-2007, 11:06 PM
Default
Nice.
Seriously though, thanks for the insight and assistance. It's much appreciated. I'll post a follow-up once I can find the time to figure out exactly what's going on back there.
  #13
Old 01-11-2007, 10:35 AM
5th Gear
Default
Let us know how things turn out!
also, I may have missed it, but what is your model year & engine? post your engine code too, if you know it (AEB/ATW/AUG/AWM/AHA/ATQ...)
  #14
Old 01-11-2007, 11:52 AM
PZ PZ is offline
Overdrive
PZ is on a distinguished road
Default
Hey noob , since his profile says 01 B5 1.8T, I am betting on an AUG or AWM. The VVT started with them anyway.
  #15
Old 01-11-2007, 11:53 AM
Default
2001 (B5) 1.8T AUG. And, like magic, the CEL has turned itself off. I did nothing but drive home and go to sleep last night. The VW fun continues
I still plan to clean everything up and give it a good squirt with Lubro Moly Electronic Spray. That should clear up any resistance issues. Then, if the CEL comes back or I hear suspect noises, I'll at least know it's a different part or problem.
I also plan to run a can (bottle?) of Liqui Moly Motor Clean through the engine next oil change. Here's what the company has to say about the product:
Motorclean. Dislodges sludge and lacquers to improve compression and reduce exhaust emissions. Great maintenance for chain tensioner systems and valve lifters.
Sounds like good preventive maintenance for the top end, chain tensioner, etc. I really like the Lubro Moly/Liqui Moly line.
http://catalog.etyparts.com/epcgetsp...ory1=LUBROMOLY
PS--130 posts and I'm still in "neutral?" Screw you guys, I'm goin' home...
  #16
Old 01-30-2007, 11:06 AM
furnace furnace is offline
furnace is an unknown quantity at this point
Default
*bump*
How did this turn out?
  #17
Old 01-30-2007, 11:20 AM
Default
Ran the MotorClean through before my last oil change (roughly 2k miles ago), then filled up with Lubro Moly 0 w40 and a can of MoS2 as usual. I also gave a number of electrical connectors a quick cleaning and spray with the Lubro Moly Auto Electric Spray (coil packs, hall sensor plug, CCT plug, throttle body connector plug, etc.). I went to Autozone and cleared the code. Haven't seen the CEL since.
Not sure if the tensioner was really going bad or what, but I have not observed noises or any other strangeness from the engine since the oil change. I drive ~100 miles/day and would pretty much immediately know if something was amiss. Thumbs up for the strength and durability of the AUG!
  #18
Old 01-30-2007, 06:03 PM
5th Gear
Default
Quote:
Ouch... Lazy me.
Um, IIRC, 1st gear starts at 500. Or was it 1500?
Good to hear the CEL went away!
  #19
Old 01-31-2007, 11:07 AM
PZ PZ is offline
Overdrive
Default
One good problem will get you into 1st gear. He is there now with 179 posts!
  #20
Old 01-31-2007, 11:30 AM
Default
Make that 180. Ha!
Thanks again for the help guys. So far so good with the CCT, CEL, etc. Anybody have any other acronyms they'd like to throw in?
  #21
Old 07-27-2008, 02:55 PM
DSIM DSIM is offline
DSIM will become famous soon enough
Default
What does this sound like? I recently got this code (P0010) and I have noticed a "growl" coming from somewhere that I attributed to exhaust rattle. I will be putting the car on jackstands tomorrow to check those out. Just wanted to know what I was in for before I got under there and found nothing.
As far as the sound it makes, I hear it when I start the car, but only for a few seconds.... and when I am shifting but only at certian RPM's. The car is an 02 AWM 1.8T manual transmission. I really dont have the 400 to fix this right now, how long can I go before this thing craps itself? What is likely to happen should this turn into something major? How difficult is it to change out the tensioner?
  #22
Old 07-27-2008, 04:49 PM
4MOTIONV6 4MOTIONV6 is offline
4MOTIONV6 is on a distinguished road
Default
[quote=DSIM;2065565]What does this sound like? I recently got this code (P0010) and I have noticed a "growl" coming from somewhere that I attributed to exhaust rattle. I will be putting the car on jackstands tomorrow to check those out. Just wanted to know what I was in for before I got under there and found nothing.
As far as the sound it makes, I hear it when I start the car, but only for a few seconds.... and when I am shifting but only at certian RPM's. The car is an 02 AWM 1.8T manual transmission. I really dont have the 400 to fix this right now, how long can I go before this thing craps itself? What is likely to happen should this turn into something major? How difficult is it to change out the tensioner?[/Q
YOUR CAM ADJUSTER IS LOSING PRESSURE AND MAY CAUSE ENGINE DAMAGE
IF NOT TAKEN CARE OF.
  #23
Old 07-27-2008, 05:41 PM
Default
Anyone have a part #? How hard is it to change the cam adjuster? Any idea on the price? I have the next 3 days off, so now would be the prime time to get it taken care of.
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Web www.PassatWorld.com
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Disclaimer: PassatWorld.com is an independent enthusiast website and is in no way related to the Volkswagen & Audi Group of Companies. Comments made in the PassatWorld.com discussion forum are the views of the respective poster and in no way represent the views of the web site’s owner or staff, therefore, PassatWorld.com is not responsible or liable for any content or claims made in such posts. Additionally, PassatWorld.com provides links to third party World Wide Web sites which it has no control over. PassatWorld.com is not responsible for the availability of such external web sites or resources, and does not endorse and is not responsible or liable for any content, advertising, products, or other materials on or available from such sites or resources.
