For advertising info, email us!
Home Forums Passat of the Month Marketplace About Us
Go Back   Passat World Forums > Passat Discussion > Club B5 > B5 Information-Base
Register Blogs FAQ Members List Calendar Search Today's Posts Mark Forums Read
B5 Information-Base The most wanted B5 Passat information is gathered for you all in one section. Only the best, and most informative, posts can be moved here by the PassatWorld staff.
Reply
Thread Tools Search this Thread
  #1
Old 06-22-2006, 07:37 PM
jeanluc jeanluc is offline
Superhero
jeanluc is on a distinguished road
Default How To: Replace 1.8t cam chain tensioner
How To: Replace 1.8t AWM cam chain tensioner
My car was having the following code show up. It usually would not cause the CEL to light.
16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
P0011 - 002 - Lower Limit Exceeded – Intermittent
The chain was very noisy; you could hear it rattling anytime the car war running.
The standard disclaimer applies – I am not responsible for damage to your car, person, property or pets. All common sense safety items apply here. This job has the potential to do expensive damage if done incorrectly. Pay attention to what you are doing. Having a friend present for a periodic sanity checks is recommended (saved me).
Parts Needed: (2002 AWM – Your parts list might vary):
058198025a – Valve Cover Gasket
863.590 – Tensioner Gasket
058 199 088E – Tensioner
Hose Clamps
Ice cold beer – English or German preferred
Tools Needed:
Metric Socket set
Torque wrench - inch pound or small foot pound
Metric Allen bits
Screw drivers
T-30 Torx Socket (for cam caps and tensioner)
Cam Tensioner Retainer tool 3388 – mine came with new tensioner
Razor Blade
Flange Sealant AWV 188 001 02
White out – for marking cam chains and timing marks
Getting Started
1. Set the timing marks to TDC on Cylinder #1. I found that I could “bump” the motor until I got is close and then use a wrench for that last few degrees.
2. Remove the upper timing belt cover and the plastic cover on top of the motor.
3. Remove coil packs and spark plugs (keep in order). Put paper towel in spark plug holes to keep debris out of cylinders.
4. Pull off or remove all items marked in blue
5. Remove all valve cover bolts (9 total) and accessory bolts. They are marked in red. Remove the cam position sensor (in front) and let it dangle by the wire.
6. Remove Valve cover and old gasket.
The main act:
1. Mark the timing chain. Clean the cam chain of oil where the timing marks are. Count out 16 rollers between the timing marks. Recount 16 rollers. Use liquid paper and mark the cams and chain at both the intake and exhaust side. Have your friend recount 16 rollers. Paranoia is good on this step.
2. Install the Cam Tensioner Retainer tool 3388, being careful not to over tighten. My tool came on the new tensioner, so I wrapper the new part in an old t-shirt and lightly held it in a vise. I then “borrowed” the tool to disassemble the old parts.
Here is how this works, we are going to remove the intake cam and leave the exhaust cam alone. We can then pick the intake cam and tensioner up as a unit and swing them up and out of the motor. This way we do not need to monkey with moving the front end to the service position or mess with the timing belt.
3. Remove oil splash guards. Using your T-30 socket, remove bearing caps 3 and 5 on intake side (red). Loosen bearing cap bolts on caps 3 and 5 on exhaust side (purple). Remove all remaining caps on the intake side and loosen remaining exhaust side bolts evenly. Remove the double bearing cap at front of engine. Put caps aside in the same order as installed. Loosen exhaust cam bearing cap bolts. Do not fully remove exhaust bolts or cam except cap number 1. Remove the cam chain tensioner bolts (4 total).
4. Lift the intake cam and tensioner together and swing them out of the motor. This is easier said then done. Patience is your friend.
5. Here is how it will look once you weasel the tensioner out.
6. Clean all gasket surfaces using a scotch brite pad or a razor if needed. Install the new half moon gasket under the chain tensioner.
7. Move your Cam Tensioner Retainer tool to the new tensioner. Install the new tensioner the same way the old one came out. Watch your timing marks. Double and triple check the timing. I had to install the tensioner twice because the chain slipped a tooth. Slide the new gasket under the tensioner and seat it on the dowel pins.
8. Clean all cam journals with a piece of clean t-shirt and oil them. I was scolded by atomicalex for almost omitting this step.
9. Install caps 2 and 4 on intake and snug 2 and 4 on both cams equally. Install remaining caps on intake cam and snug bolts all bearing cap bolts equally. Apply sealant to bottom of double bearing cap. Install double bearing cap. Carefully align cam seals at front of engine for proper seal. Torque all cap and cam tensioner bolts to 10 Nm. Remove tensioner tool.
10. Count 16 pins on the cam chain and verify the timing.
11. Reinstall the plastic splash covers over the intake cam.
12. Install new valve cover gasket and then install valve cover.
13. Install cam position sensor.
14. Reinstall spark plugs, coil packs, hoses, covers and other items.
Start the car. The tensioner will make noise until it fills with oil.
Crack a cold beer and enjoy.
  #2
Old 06-23-2006, 12:30 AM
dutch-mountains dutch-mountains is offline
dutch-mountains is on a distinguished road
Default
Bookmarked, this is great . Where's the part you needed six hands?
  #3
Old 06-23-2006, 04:19 AM
Superhero
Default
Quote:
Dropping the new part in for the second time. One person held the cam, one held the tensioner and the third held the chain firmly on the exhaust cam so it could not move.
  #4
Old 06-23-2006, 07:05 AM
PZ PZ is offline
Overdrive
PZ is on a distinguished road
Default
Nice writeup. I would replace the intake cam seal since you have it apart. Mine started leaking right after I replaced the cct gasket. It's only a couple of dollars.
I also added a touch of sealant to the exhaust cam rear cap, I would hate to have a leak after all of that work.
I gave a 5 star rating.
  #5
Old 06-23-2006, 08:15 AM
atomicalex atomicalex is online now
Lisa Simpson
atomicalex has a reputation beyond reputeatomicalex has a reputation beyond reputeatomicalex has a reputation beyond reputeatomicalex has a reputation beyond reputeatomicalex has a reputation beyond reputeatomicalex has a reputation beyond reputeatomicalex has a reputation beyond reputeatomicalex has a reputation beyond reputeatomicalex has a reputation beyond reputeatomicalex has a reputation beyond reputeatomicalex has a reputation beyond repute
Default
We did the Sharkey and put the white VW sealant at all corners on the VCG.
__________________
CB5/PW Admin and
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
, 02 Golf TDi, the Scirocket, and another 82 Rabbit Convertible
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Web www.PassatWorld.com
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Disclaimer: PassatWorld.com is an independent enthusiast website and is in no way related to the Volkswagen & Audi Group of Companies. Comments made in the PassatWorld.com discussion forum are the views of the respective poster and in no way represent the views of the web site’s owner or staff, therefore, PassatWorld.com is not responsible or liable for any content or claims made in such posts. Additionally, PassatWorld.com provides links to third party World Wide Web sites which it has no control over. PassatWorld.com is not responsible for the availability of such external web sites or resources, and does not endorse and is not responsible or liable for any content, advertising, products, or other materials on or available from such sites or resources.
