| Register | Blogs | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Club B5 Discussion area for the B5 Passat, production years 1997-2005. |
Thread Tools | Search this Thread |
#1
Well after a couple of years of oogling the Euro Westfalia Trailer hitch I finally got it and have it installed.
First of all I'd like to thank my fellow Club B5 member and my new buddy Geri in Austria who actually got me the hitch and did all of the leg work. Also thanks to Super Moderator pass-variant who inspired me to take the plunge! I have covered the wiring here: http://www.passatworld.com/forums/sh...d.php?t=208467 Pass-variant's photo's: http://www.passatworld.com/forums/sh...ight=westfalia For those that are interested, this hitch is only available in Europe and dealers and install info can be found here: http://www.westfalia-automotive.de/auswahl.htm The hitch cost me 222 euros and shipping was....too much . It weighs 52 pounds and even though I had it shipped though a courier that our office has an account with, it was still alot of money but I don't regret it. This hitch is truly an amazing piece of engineered metal. The install took about 2 hours.Waiting in Austria for a new home.... ![]() Packed up and ready to go....(thanks Geri!) ![]() 6 Bolts for the 4-Motion....torqued to 30Nm (~262 in/lbs.) ![]() Anchor plates for bolts 5 and 6.... ![]() The goose neck hitch..... ![]() Bumper removal started....(moderately documented in the Bentley Manual) ![]() Bumper cover removed.... ![]() Bumper off with side marker light wiring disconnected.... ![]() Bumper removal from inside trunk. Note the black cover that peels off the hole for bolts 5 and 6 on the 4-Motion. This is where the anchor plates were used on the underside above the mufflers. No removal of muffler or heat guards were required as indicated, as a maybe, in the installation instructions. ![]() Bumper out! ![]() The Westfalia fits like a glove! ![]() Sticker: ![]() Foam piece (as required in Westfalia install instructions) available from my local Canadian dealer for $22: ![]() Foam installed with a bit of extra hockey tape.... ![]() Bumper cover re-installed. View from underside....totally hidden! No cutting of any plastic on the bumper was required. ![]() Hitch installed.... ![]() Final pic..... ![]() Now it's time to go trailer shopping....
#2
Looks kinda like a really crooked... microphone.
Nicely done, what's the tow capaticity? |
#3
Nice work man!
#4
I suggest you put a condom on that thing before it gets into trouble.
![]() Nice work. Will it fit on a W8 variant? |
#5
What do you plan on towing?
#6
Quote:
x2!!
#7
Hi Dave,
so you finally got your hitch under your car, very good job! The Westfalia seems to fit very good, for me also first time to see the install. And it looks easy to do. Hopefully you can manage the wiring also, we have different plugs for trailer outlet. Now you can tow a tank, but beware of your clutch ;-) and yes, this hitch will fit to a W8 also cause the bodywork is the same. To be sure put off your rear bumper and compare with Daves pics. But like Dave told, shipping is cause of this heavy monster very expensive. Maybe someone is able to find a dealer who would like to import it. |
#8
Nice work.
#9
Quote:
#10
Quote:
Quote:
Quote:
Quote:
Quote:
Quote:
http://www.passatworld.com/forums/sh...d.php?t=208467 It wasn't hard after I learn the German shortforms. I summarized them on the wiring PDF I created. |
#11
Glad you finally got what you wanted and sorry I couldn't be any more helpful earlier.
Watch those kneecaps/shins when walking behind the car
#12
Quote:
#13
Hi, Excellent write-up, I have the same job to do on a 2002 Estate. On mine (UK spec) the black plastic floor over the spare wheel is full width and fits under the rear side trim on each side. Can I ask if yours is the same and were you able to remove the floor by flexing it.
Thanks in advance Bob |
#14
Quote:
I was truly put off by the hitches available here state side for the FWD cars, and wasn't willing to pay more for shipping than I would for the hitch to get it from overseas. So, I built my own. Using the technical drawings from the Bosal unit, and measurements taken from the car I crafted my own. I used 3/16 wall tube steel to build the main structure (2"x3" box tubing for the parts that go into the bumper mount pockets, 2.5"x2.5" box tubing for the cross bar, and 2.5"x.25" plate steel for the reciever drop.) I used a 1.25" reciever as well. All in all it is pretty much a class 5 hitch frame with a class 2 reciever on it. As soon as I can get the pictures off of my phone I will post what the thing looks like. The only visible part of the hitch is the reciever tube. It's not quite as cool as the removeable swan hitches, but it will suffice. I figure I have about $100.00 in materials, and about 3 hours of labor involved with building it. Way better than the $400 or so I was finding for one from England. |
#15
Hi, thanks for reply. The reason for my question is that I have bought an "add-on" wiring loom for the trailer socket. This is fitted with plastic connectors to just click into each rear light assembly so I have to get from one side of the car to the other, under the floor. I thought that the made up loom would save me time on wiring but according to the instructions supplied I need to remove all the trim from the rear door backwards on one side, in order to remove the floor panel. Just trying to save unnecessary work. Yes, I have the cutouts that you mention for the impact bar bolts.
I can understand US/Can owners not wanting to import towbars at the sort of prices mentioned, in the UK we have plenty of choice (for once!) Regards Bob |
#16
Quote:
#17
#18
Quote:
#19
Bump for update & new pic's....
Here's the chain bracket I had made up: ![]() Painted and installed with some minor bumper cutting (still completely hidden!): ![]() ![]() New custom utility trailer (www.miskatrailers.com) with 3500lb axle.... ![]() More pic's later when I get the floor stained, tie-downs installed, and get it loaded with firewood and lumber! |
#20
Very nice! How did you attach it...I can't figure it out going from pic #1 or #2.
#21
Quote:
#22
Quote:
![]() maybe his car is just happy to see him
#23
Quote:
#24
look at the first pick, the bracket is upside down, in the next pic its on the bumper and you can see 4 shiny nuts, those connet to teh two muffler clamps
#25
Quote:
Here's a couple of more pic's that might make it clearer... ![]()
#26
I get it now, in the pic before the bolts looked horizontal 4 in a row. Camera trick. I am really inpressed that you were able to come up with that design.
#27
I've been trying for a while now to get one of these tow bars in the US. First I tried Edworthy's in the UK. I ordered it on line and everything seemed fine. I waited a month and no tow bar. After several emails I was finally told that the priced quoted me for shipping was incorrect and it was going to be over $200 more!!!!
Lately, I tried contacting Westfalia directly. Here is their response. Dear Sir,I'm going to keep trying but the possibility now appears to be remote.
#28
Paul Jr. from PGPerformance in Canada can get it for you...around $560 or maybe a little more. Prob from 2-6 weeks depending on when they get their monthly shipment in.
#29
Quote:
Three things about this B.S. is that in Canada we are Metric but still use U.S. Imperial measurements for things like lumber and trailer hitches?!? |
#30
Doesn't 50mm = 2 inches? 2" is a standard ball size here in the US (along with 1 7/8" IIRC).
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
