Well, it happened to me at only 55K and I'm sure it'll happen to you. The side to side motion in your Tip just seems to stop working and your shift handle just flops back and forth out of Auto & Tip. The dealer wants hundreds of dollars to fix or upwards of a grand to replace the shifter mechanism. Well I performed this repair in little over an hour and it actually took more time to take the pictures than it did to repair.
I wrote this in MSWord and converted it in a little free program called "Paperless Printer" to JPEGs. Check out the program as it also saves them to PDF, HTML, and a few others. I did this so you could save the individual pictures, print them on whole sheets and use them as a guide. I can convert them to most formats, and I'm sure Imageshack will won't host these forever, so if someone can host, say a PDF file, I can provide that as well. If the pictures come out as the dreaded "red X", then try refreshing or it may be time for me to rehost and your out of luck.
Feel free to ask questions or criticize. All I know is that mine now works and the parts came from 1stvwparts.com and I paid minimal amounts of funds ($11.00). Have fun.
