For advertising info, email us!
Home Forums Passat of the Month Marketplace About Us
Go Back   Passat World Forums > Passat Discussion > Club B5 > B5 Garage
Register Blogs FAQ Members List Calendar Search Today's Posts Mark Forums Read
B5 Garage The specific technical and "how-to" help forum for the B5 Passat. Have a detailed technical question? Post it here.
Reply
Thread Tools Search this Thread
  #1
Old 02-19-2005, 11:12 PM
Panther 37 Panther 37 is offline
Panther 37
Default HOW TO: Remove Single DIN Stereo and Everything Else in that Console
It's really easy, you only need one picture.
All the tools you need is a #20 Hex Star and a thin screwdriver. The bezel that fills in around the climate controls (greenish) pops off. Behind it is 4 screws. Underneath the radio in the "mini-cargo" area as another 2 screws. Take the 4 screws (magenta) and it will pull out. Behind the climate controls 2 screws don't need to be removed.
  #2
Old 02-20-2005, 02:18 AM
D.Passat00 D.Passat00 is offline
the deal finder!
D.Passat00 is an unknown quantity at this point
Default
you must have an early model b5. in any event, you'll need the radio removal tool if you want to remove the radio alone.
  #3
Old 02-20-2005, 11:06 AM
Panther 37
Default
I tried inserting a removal tool into the radio an it would not fit up top. The clips for the stereo are on the side toward the bottom.
  #4
Old 02-20-2005, 11:20 AM
Tom Parish Tom Parish is offline
Lefties have rights, too!
Tom Parish is a trouble-maker
Default
You need two tools to remove a double DIN and four for the single DIN. Also, the tools for the single and double are dfferent.
  #5
Old 02-20-2005, 12:33 PM
the deal finder!
Default
you can make your own radio removal tool for the single din:
http://www.passatworld.com/forums/sh...center+console
  #6
Old 02-20-2005, 01:37 PM
Default
Don't be cheap and do it this way. I have seen HUs ruined using it. Spend the $15 and do it right. You will make a lot of friends loaning out your removal tools.
  #7
Old 02-20-2005, 02:42 PM
PlastikHeart PlastikHeart is offline
PlastikHeart
Default
I Removed and installed my own headunit no problem, if you get something from crutchfield they give you all the necessary tools
  #8
Old 02-20-2005, 04:49 PM
Panther 37
Default
Quote:
http://www.passatworld.com/forums/showthread.php?t=138187&highlight=center+console
My stereo set up is different.
< S E T U P >
Link . . . . . . . . .| My 99 Variant
Stereo . . . . . . .| Climate Controls
Coin Tray . . . . .| Stereo
Climate Controls | Coin Tray
  #9
Old 02-20-2005, 05:38 PM
the deal finder!
Default
Quote:
i've removed my radio at least a half dozen times with no problems using the tool. you shouldn't have any problems if you use it correctly.
  #10
Old 02-20-2005, 06:06 PM
Default
So it worked for you. There has already been another post today where it didn't work and he had to take the car to the dealer. Use the right tools
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Web www.PassatWorld.com
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Disclaimer: PassatWorld.com is an independent enthusiast website and is in no way related to the Volkswagen & Audi Group of Companies. Comments made in the PassatWorld.com discussion forum are the views of the respective poster and in no way represent the views of the web site’s owner or staff, therefore, PassatWorld.com is not responsible or liable for any content or claims made in such posts. Additionally, PassatWorld.com provides links to third party World Wide Web sites which it has no control over. PassatWorld.com is not responsible for the availability of such external web sites or resources, and does not endorse and is not responsible or liable for any content, advertising, products, or other materials on or available from such sites or resources.
