For advertising info, email us!
Home Forums Passat of the Month Marketplace About Us
Go Back   Passat World Forums > Passat Discussion > Club B5 > B5 Information-Base
Register Blogs FAQ Members List Calendar Search Today's Posts Mark Forums Read
B5 Information-Base The most wanted B5 Passat information is gathered for you all in one section. Only the best, and most informative, posts can be moved here by the PassatWorld staff.
Reply
Thread Tools Search this Thread
  #1
Old 02-25-2004, 08:23 AM
vwfool2000 vwfool2000 is offline
vwfool2000
Default 2 oil leaks found/fixed, clogged/cracked PCV valves (pics)
I've taken my car ('99 1.8T, Tip) in 3 times for some suspected oil leakage around the turbo and underneath the intake manifold. Each time the dealer wiped the parts clean and said they couldn't find anything. Well, it's gotta be coming from somewhere! After doing some research, I suspected that the PCV (positive crankcase ventilation) valves were leaking oil down onto the turbo and lower crankcase.
Here are the 2 pics from above the turbo. How can you not think that there is a leak somewhere?!?!?
Just above the turbo is one of the PCV valves. After I removed the valve, I saw the image below and looked inside the valve to find that it wasn't operational anymore. The rubber flap inside was soooo caked with oil debris that it wasn't moving anymore. I sprayed it with throttle plate cleaner and chunks of old oil came out. It was obvious that this is where the oil was coming out and running down the turbo onto the DV. Again, how can you miss this?
Here's a diagram of the parts that I checked and replaced.
The parts I replaced were:
#2, #5, #6 (<--pcv valve) in the diagram on the left
#20 (<--pcv valve) in the diagram on the right
Now on to the other side of the engine. Sorry I didn't take any pics of the driver's side underneath the intake manifold. There was a lot of slimy oil residue under there. I removed parts 2,5,6 and found there to be a lot of wet oil all around these parts and inside them too. Parts 2 & 5 pretty much fell apart while removing them. Part 2 had a large crack on the underside. I can assume that this is where the oil was dripping from.
In the pic above you can see the two valves above. The old one would stick open when you pressed on it. Not good.
The valve actually fits inside of the rubber T housing so you can't see it when you are looking down there below the manifold, next to the oil filter.
You can see all of the parts except for #2 here:
Once I took a look for myself under there, it was pretty easy to see where the oil was coming from. Everything was under 50.00 and took about 4 hours to do with testing and taking pics.
It even feels like I got some boost and responsiveness back! Let me know if you need any part numbers or tips.
  #2
Old 02-25-2004, 08:28 AM
PassatVariantPunk PassatVariantPunk is offline
4th Gear
PassatVariantPunk is an unknown quantity at this point
Default
Really great info! You should do a write up on the replacements.. would make a killer addition to the Info Forum.
Timely for me as well. Its nice to see whats going on.
  #3
Old 02-25-2004, 08:35 AM
vwfool2000
Default
Many requests for this so here it is.
part numbers list:
right diagram-
#20-- 034 129 101 B
left diagram-
#02-- 058 103 213
#05-- 058 103 247
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Web www.PassatWorld.com
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Disclaimer: PassatWorld.com is an independent enthusiast website and is in no way related to the Volkswagen & Audi Group of Companies. Comments made in the PassatWorld.com discussion forum are the views of the respective poster and in no way represent the views of the web site’s owner or staff, therefore, PassatWorld.com is not responsible or liable for any content or claims made in such posts. Additionally, PassatWorld.com provides links to third party World Wide Web sites which it has no control over. PassatWorld.com is not responsible for the availability of such external web sites or resources, and does not endorse and is not responsible or liable for any content, advertising, products, or other materials on or available from such sites or resources.
