Radio Install Problem
Results 1 to 4 of 4
    Mar 2017
    Michigan
    4
    Question Radio Install Problem
    Hi All,
    Just bought a new-to-me 2001 Passat 1.8T. Was told by the P/O that it had a battery drain that would kill the battery in a few days. Well I'm pretty sure I found it. The car had an aftermarket head unit installed. I noticed that after I turned the car off and took the key out, there would be a faint static/white noise coming from the speakers even though it appeared the radio was off (couldn't make it do anything). I'm thinking this sound is my battery drain. Figured it was the crappy head unit so I ordered a cheesy $30 one from Amazon to replace it with. Installed the new one yesterday and amid other problems with it, the white noise when the car's off is still there! Could be the crappy new head unit so I'm getting a refund for it but they dont want it back haha. I now have a decent one on order. I'm pretty sure I wired it in correctly, I put the yellow memory wire to the stock harness and I have the radio power coming from the 75X bolt that comes from the ignition. I noticed that when I unplugged the connector that has the yellow battery wire going to the head unit, the sound goes away so something might be screwy with that. Anyone ever had this problem before? I've looked into this as much as I can and haven't come up with much. I've seen it could be a ground, bad amp (do these cars have amps for the door speakers?), or a bad head unit. I think I'll run the wire to a screw on the frame for a new ground and see if that helps me any. I really want to have a working radio in my car so any help would be appreciated!
    Thanks!
    2nd Gear
    Jan 2010
    NJ
    51
    501
    Did the car come with Monsoon sound? If so you will find the amp in the trunk attached to the rear deck on the passenger side (sedan) or in the driver-side rear panel after the wheel well (wagon). If so more than likely the amp is staying on after shutting the car down and pulling out the key. This is fairly common when installing an aftermarket radio. The way i solved the theproblem was by installing a relay that interrupts power to the amp triggered by the power antenna lead from the radio harness.
    Jul 2008
    Chicago
    54
    16,468
    1'st thing we need to know is what rreyes asked... Does this car have the Monsoon sound system or the standard system?
    If you leave the radio disconnected, do you still hear that white noise sound?
  5. Remove Advertisements
  6. #4
    Mar 2017
    Michigan
    4
    Hey guys thanks for helping, I've determined its an amp of some kind that failed - I didn't see the monsoon in the trunk but maybe there's one somewhere else. When I ran wires straight from the radio to the speakers, they work properly and make no noise after turning off. I bet it was the amp that was staying on after the radio turned off. So I'm just going to continue running new wire to the door speakers instead of using the wiring already there because there's obviously a problem.
  7. Remove Advertisements
Human Verification
