2007 Passat 2.0T MIL P2181
Results 1 to 3 of 3
    Nov 2012
    US
    3
    Hello everyone,
    I have a 2007 Passat 2.0T with a CEL. Here's the description of the code + freeze frame info:
    1 Fault Found:
    008577 - Performance Malfunction in Cooling System
    P2181 - 008 - Implausible Signal - MIL ON
    Freeze Frame:
    Fault Status: 11101000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 105914 km
    Time Indication: 0
    Date: 2012.11.03
    Time: 05:44:12
    Freeze Frame:
    RPM: 2081 /min
    Load: 61.9 %
    Speed: 104.0 km/h
    Temperature: 75.0°C
    Temperature: 8.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 14.097 V
    I have searched here and on GIS, and found conflicting information. I did the AC on while cabin fan set to 1 test, and found both radiator fans not turning on. I ran the engine for a while and both fans come on during high speed. I also tried clearing out the code thinking having the AC on could cause the error code (since it's getting quite chilly nowdays), but the light came back on after a couple of days.
    I'm leaning towards the fan control module, but some posting indicates that it's a separate module, while others claim that it's built into the fan assembly. Some posts suggest CTS (Temperature sensor), but I haven't found any link between CTS and the low speed fan mode. Also, there's a talk about there being two CTSs in the car, one near the firewall, and under the car.
    Is there anyone here who can help me figure out what could cause the low speed fans not to kick in when AC is on, and if it's ever related to P2181 code? I have one CTS ordered as it's the easiest part to replace, but I have a feeling that it might not be the root of the problem. Could thermostat cause low speed fan not to kick in? The car doesn't overheat, nor the freeze frame indicate any temperature issue (and I've also verified that the high speed fans kick in). Also, is there a relay that controls the low speed fans?
    Thanks in advance!
    Nov 2012
    Melbourne FL
    8
    I have a 06 2.0T as well. Having the same issue...p2181. I clear it and it comes back 2-8 days later. It will reset (ie, no CEL) after a while. But FF data is stored. What part # did your order and where did you get your sensor? My temp does not fluctuate and my heat works just fine.
    my FF data:
    Parameter Description Results
    DTC for which Freeze Frame was Stored P2181
    Fuel System 1 Status Closed Loop
    Fuel System 2 Status Not Supported
    Calculated LOAD Value 19.61 %
    Engine Coolant Temp 161.60 °F
    Short Term Fuel Trim - Bank 1 -1.56 %
    Long Term Fuel Trim - Bank 1 11.72 %
    Engine RPM 1,840.00 rpm
    Vehicle Speed Sensor 22.37 mph
    Ignition Timing Advance #1 Cylinder 32.00 °
    Intake Air Temperature 75.20 °F
    Air Flow Rate Mass Air Flow Sensor 1.35 lb/min
    Absolute Throttle Position 17.65 %
    Time Since Engine Start 910 sec
    2nd Gear
    Jan 2010
    Edwardsville, IL
    669
    My car is blowing this code now, and its been slow to warm all winter. My guess is that the thermostat needs to be replaced.
  5. Remove Advertisements
Human Verification
