Check Engine Light (Fault Codes?)
Results 1 to 8 of 8
    Jul 2009
    Harrisburg, PA
    7
    I just bought this 2006 VW Passat 2.0T about a week ago and today the check engine light came on. Is there any way for me to find a fault code to maybe find out why?
    I had filled up with regular grade fuel (however I now completely filled the tank with 93 octane). I also checked the fuel cap but it doesn't seem to "click" when I turn it to the right. Just trying to see if I can find anything out before having to schedule an appointment at the dealer.
    6th Gear
    Jun 2006
    Bklyn NYC
    9,416
    you can go to AUTOZONE and have them use a OBDII scanner and see what the codes are for FREE.!
    write them down and post your results .
    Jul 2009
    Harrisburg, PA
    7
    Cool. I didn't know AutoZone could do that. Here's the fault codes they came up with:
    P2004
    P0642
    Is that bad?
  5. Remove Advertisements
  6. #4
    Nov 2007
    Columbia, SC
    237
    18436/P2004/008196 - Intake Manifold Flap; Bank 1: Stuck Open
    Possible Solutions
    Check Intake Manifold Flap
    Use Output Test
    Perform Basic Setting (Switch Ignition OFF between Output Test and Basic Setting)
    Special Notes
    When found in Engine: 2.0l TFSI
    Perform Basic Setting.
    Check TPL 2016420 (RoW)
    Check Engine Control Module Software Version, if necessary perform Update.
    Replace Intake Manifold Runner (V157) with updated part.
    17026/P0642/001602 - Sensor Reference Voltage A: Circuit: Low
    Possible Causes
    Control Module and/or Sensor Power Supply faulty
    Possible Solutions
    Check Control Module and/or Sensor Power Supply
    Special Notes
    Check Wiring from/to the following Components and Components themselves:
    Manifold Pressure / Boost Sensor (G31)
    Intake Manifold Tuning Valve Position Sensor (G336)
    Low Pressure Fuel Sensor (G410)
    Technical Service Bulletin for both Fault Codes...
    http://geocities.com/nfe100/Technica...137_P3138_.pdf
    This is a common issue on the 2.0t FSI engines. You should call your dealer to see if you have a required SW update for your car (should be the OY update). If you still have a warranty, then you should take it into the dealership and have them deal with it. Sometimes the Intake Flap motor corrects itself, if not, you're going to need to find some with a VagCom...perform the basic settings and see if that cures. If the CEL returns with the same codes after performing the basic setting, then you might need to replace the motor that controls the flaps.
  7. #5
    Apr 2007
    WSMR,NM
    1,044
    are you under the 50k for warranty see if they dealership will check it out and fix it
  8. #6
    Aug 2008
    TN
    174
    Dealer replaced my flap motor today under warranty. I have 26k on my '07. I had the check engine CEL that went away after wife tightened gas cap so I thought that's all it was, but since it was under warranty decided to bring it in anyway. Evidently the code was for the Flap Motor. Throttle response seems a little better as well, but I'm sure it's just psychological.
    Also had a parking brake CEL that occurred just 1x a few months ago. I turned engine on/off and CEL went away. DLR saw that code and replaced parking brake switch as well, under warranty. I asked if the replacement parts are 'new and improved' from VW and he said yes. This dealer has been a joy to work with.
  9. #7
    Aug 2008
    Chicago
    80
    just remember that if you dont tighten the gas cap a CEL won't show, it has a seperate light on your dash for that.
  10. #8
    Jul 2010
    2
    Ok, I have a 07 Passat 2.0T and I just stopped by the dealer due to the engine light coming on. Dealer says its the intake flap and its ok to drive. Well I'm hitting the road to head to Miami this week, for a 1500-2000 mile road trip. They say it will be fine, I worry, since they just replaced the cam and fuel pump follower two weeks ago and the battery suddenly went dead last week. Have only had the car for three weeks. Not feeling to good about owning a VW!
  11. Remove Advertisements
Human Verification
