Fluid changed
Results 1 to 14 of 14
Like Tree2Likes
  • 1 Post By Tomvw
  • 1 Post By indebt
Thread: Fluid changed
    Jul 2015
    merica
    181
    Fluid changed
    My vw has been nickel and diming me lately, the last thing i want todo is replace more shit... i was going to a turkey baster fluid flush on both brake and PS. Never done a brake flush with a clutch car, and tips?
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    6th Gear
    Feb 2013
    Bendigo, Australia
    7,998
    Flush the brakes first, then flush the clutch.
    Use a pressure bleeder.
    RoosterEggs likes this.
    Dec 2015
    Detroit, MI
    155
    ^ ^ ^ This.
    You can get a basic pressure bleeder (w/ a German-style adapter) for $50:
    Tools Volkswagen Brake Tools
    Jul 2015
    merica
    181
    Quote Originally Posted by Tomvw View Post
    I was going to flush the brakes using a turkey baster sacking old fluid out put new in, pump brakes 3-4 times and repeat... never heard of this pressure bleeder, what does it do? Also how do you bleed the clutch, I figured they were in the same system
    Sent from my SAMSUNG-SM-T817A using Tapatalk
    Jul 2013
    Minnesota
    34
    261
    Quote Originally Posted by indebt View Post
    Absolutely get a pressure bleeder, it attaches to the reservoir and forces fluid through. It makes bleeding the brakes and clutch a cake walk. Use the turkey baster to remove the old fluid from the reservoir before you attach the bleeder and you will have less fluid to force through the system. The clutch is on the same reservoir, with the pressure bleeder attached and pressurized, crack open the bleeder on the slave cylinder just as you would do on a brake caliper. If I remember correctly, the slave cylinder bleeder can be reached from the top by moving the coolant expansion tank.
  7. #6
    Dec 2015
    Detroit, MI
    155
    Turkey baster is still step 1 - suck out as much old fluid as possible. Then fill the reservoir (& the bleeder), and push new fluid thru the system.
    The pressure bleeder does just that - it pressurizes the brake system (to 15-20psi), and pushes fluid thru for you. All you need to do is open & close the valves. Once you use one, you'll wonder how you ever got by without it.
    The clutch hydraulics are actually independent of the brakes - it just happens to share the same fluid source (reservoir.)
  8. #7
    Jul 2013
    Minnesota
    34
    261
    Quote Originally Posted by cuppie View Post
    I absolutely love my pressure bleeder. Mine happens to be a powermotive one; the same as in your earlier posted link. I actually bought the adapter to use it on my 2004 GMC sierra when I couldn't get the ABS block to bleed the old fashioned way. It worked great.
  9. #8
    Mar 2013
    Northern CA
    190
    unlike the brake calipers, the clutch bleed port is made out of plastic, so back it out gently. try without using tools first. do not mash it or push it sideways.
    see post #2 for the sequence.
    FYI, the feed to the clutch line is further up the brake fluid reservoir by design.
  10. #9
    Nov 2004
    V6 4 Mo
    1,070
    No reason to touch the power steering unless you have an issue.
  11. #10
    Jul 2015
    merica
    181
    Quote Originally Posted by KDXClark View Post
    Wouldn't not changing cause an issue?
  12. #11
    PZ
    PZ is offline
    Redline
    May 2002
    Grapevine TX. 01 4M
    53
    24,313
    Not that I have ever seen from multiple owners over a long term.
  13. #12
    Nov 2004
    V6 4 Mo
    1,070
    It won't cause any problems as long as you use the right fluid and get the air out. It would just be at the bottom of my to do list with the other issues you are dealing with unless there is something going on with it.
  14. #13
    Jul 2015
    merica
    181
    Well its was cheap and easy, might aswell before something happens... as of right now, all i need is new pcv system, valve cover gasket (again), and brake fluid flush...
    I used chf 11s
    That was before, and it was 100% green after a liter of the fluid, so im happy.
    twowagens likes this.
  15. #14
    Jul 2015
    merica
    181
    Actually i think thats after? Haha, phone sucks
  16. Remove Advertisements
Human Verification
