2002 Passat 2.8 V6 AT - Cyl 1 and Cyl 2 w/ Random Misfires
Results 1 to 7 of 7
    Oct 2005
    Issaquah, WA
    4
    Been fighting an issue with my 2002 2.8L V6. Consistently getting loss of power/hesitation when accelerating in low-RPM's <2000. Also when warmed up, my idle is rough and it sounds as if the card may die at times (never does). Finally a Check Engine Light came on and I scanned it with the VAG-COM. Getting random misfires in Cylinder 1 and Cylinder 2.
    No other codes.
    Any ideas? In reading other posts it sounds like I may need a new ICU/coil pack, although I haven't seen any specific posts pointing to misfires only in Cyl 1/2. Any other thoughts before I start throwing parts at? Is there a reliable test for the ICU?
    -Joe
    Jan 2003
    Waterford CT USA
    27,780
    Blog Entries
    3
    spray the coil pack with water at twilight while the car is running - see if there is a light show. if there is, that will tell you if you have bad plug wires or if the coils are breaking down. however, I'd also look into running some techron thru it - clogged fuel injectors on the V6 do occur more often in that motor than the 1.8T.
    4th Gear
    Sep 2002
    Yorba Linda CA USA
    4,165
    Because the 3-coil system on the V6 fires two plugs at once, ignition problems often affect two specific cylinders. Since cylinder 2 and cylinder 4 share the same coil, but you misfire on cyl 1&2, you may indeed have an injector problem instead. I recently had a cylinder 2 misfire on mine, and found that the misfire followed the injector. In this case I installed an entire set of matched, refurbished injectors.
  5. Remove Advertisements
  6. #4
    Jun 2004
    california
    178
    Jay is right, i noticed pulling up steep grades the engine would stumble a bit.... two bottles of techron with tank full of gas fixed the problem
  7. #5
    Dec 2008
    Westchester, N.Y.
    162
    Quote Originally Posted by uksparky View Post
    What kind of techron did you use? From what I understand there are several different grades of it. Like the one at Costco isn't as powerful, apparently.
  8. #6
    Jan 2003
    Waterford CT USA
    27,780
    Blog Entries
    3
    Techron is a trademarked product. I've only seen one kind...
  9. #7
    Jun 2004
    california
    178
    Quote Originally Posted by passat03wagon View Post
    Six pack Costco
  10. Remove Advertisements
Human Verification
