The rear doors do not open
Results 1 to 4 of 4
    Nov 2010
    Milan Italy
    2
    Hi, I am a new user of this forum!!
    A few days ago the rear doors do not open, so I checked if the cables were broken in the bellows, between the frame and doors. In fact, on the left side door cables were broken and the lock sometimes does not lock up or unlock the door. I fixed the cables in the bellows and everything worked again perfectly, but now the right side door is stuck and does not open, even with the lever inside. It is blocked! I examined the cables in the bellows, they are stripped, but they are not broken. But the lock remains locked. I can close all the doors from inside with the button, or outside with the key, but when I open the back door right, does not open, I do not hear any noise. I only use the keys, do not use the remote control. Does anyone have any idea? Thanks for the help in advance. Edoardo
    My car is a Passat Wagon (TDI 1998)
    Moderator Extraordinaire
    May 2000
    San Angelo, TX
    54
    13,784
    This thread may help you: Another Door Lock Problem
    Original Club B5 member: 16 Golf 4 & missing my 99 B5 & 08 R32
    Nov 2010
    Milan Italy
    2
    Rear door lock, impossible to open it manually
    Many many thanks Urlik , I found in this link useful information in order to remedy the malfunction. But now my problem is to open the rear door which is locked and I can not open it because after the last close with the key the lock device will not unlock more. If I can not open the door I can not remove the cover of the door. Thanks again, Edward
  5. Remove Advertisements
  6. #4
    May 2000
    San Angelo, TX
    54
    13,784
    Will it unlock after you disconnect the cable from the outside door handle?
  7. Remove Advertisements
Human Verification
