Engine turns over, but car won't start...
Results 1 to 11 of 11
    Dec 2003
    Fairfax - Virginia
    27
    My car wouldn't start this morning. It's a '99 VW Passat 1.8T (AEB).
    What I know:
    It's been parked since last wednesday evening (almost 5 days).
    The engine turns over, but it won't start.
    I checked the battery (only about 6 months old) and it's fine - even tried to jump start it.
    There are NO error codes (per VAG-COM); although this could be because I disconnected the battery and it hasn't had a chance to throw any CELs since.
    Did a TBA just to make sure that wasn't an issue.
    Yes, there is gas in the car; about a half tank.
    Replaced the spark plugs (noticed that they were slightly wet with gas, is this normal?)
    Can anybody point me in the right direction? What should I do/check next? Any/all help is greatly appreciated.
    Thanks,
    Phill
    4th Gear
    Apr 2007
    Greensboro, NC
    3,180
    Check the fuses? (numbers 5, 12 or 14 possibly)
    May 2006
    Abingdon, MD
    39
    22,534
    The plugs are wet because you have no spark but you are apparently getting fuel. You haven't moved it since, like started then shut back off?
    1. Try holding the gas pedal to the floor while cranking. This cuts off the injectors so you can clear out the cylinder of fuel.
    2. Check the fuses as said previously. Even if #14 still looks good, replace it.
    3. Check the ICM on the airbox. There are procedures on here for checking it.
  5. Remove Advertisements
  6. #4
    Dec 2003
    Fairfax - Virginia
    27
    Just cranked the hell out of it and it finally started. I saw another post from back in January 2009 about a similar problem and it was resolved in the same way.
    It turns out that my car has NOT been sitting for 4-5 days straight. My wife moved it from the garage to a parking spot on the road twice over that 4 day period. Could those extremely short trips be a cause for this behavior?
    Thanks everybody...
  7. #5
    May 2006
    Abingdon, MD
    39
    22,534
    It's called carwash syndrome. The cylinders flood when you do a cold start and then shut off immediately. Common. Just let it idle down for a minute or so before shutting off next time you just need to move cars around.
  8. #6
    Overdrive
    Feb 2007
    Lehigh County, Pa.
    62
    11,819
    I've noticed both syndromes with my 2000. Leave it for over a week, or drive if for less than a minute, and it doesn't want to start. I actually had a dream about this last night. The solution in both cases seems to be holding the pedal at or near the floor and letting it crank until it catches.
  9. #7
    Nov 2005
    Mass
    67
    223
    What this usually is deposits on the intake valve holding the valve off the seat!!! Use some topend cleaner. This is extremely common with todays gas.
    Dick Shine
  10. #8
    4th Gear
    Apr 2007
    Greensboro, NC
    3,180
    Quote Originally Posted by Dick Shine View Post
    Dick Shine
    Are you refering to Seafoam, Techron or something else?
    Doug
  11. #9
    Mar 2001
    York, PA, USA
    1,852
    Thank God for Passatworld info. You guys saved my bacon with this post. Who would have thought that holding the gas pedal to the floor would cut off the fuel injectors. And where is the sticky on carwash syndrome?? I had heard this was a problem in the past, but I had never experienced it. Now I have and now I know. Thanks again.
    99 V6 AHA 5 spd - engine cranked, but no codes, and no start. - Starts now!! Thanks PW.
    Carl III
  12. #10
    Sep 2014
    Macon, GA
    9
    I'm having a similar problem with my '98 wagon. When I left work, it fired up fine. When I went to go to work the next day, it would crank but no start. It's acting like it's not getting gas. Thought it was the gas filter, changed that. The fan clutch was broken, changed that, but not quite sure if that had anything to do with it not starting. Checked the spark plugs and they are all ok, although we did find there were cracks in the valve cover. Any more thoughts as to what could the problem be? Try to go easy, i'm not too familiar with lingo or where things are. This is all very new to me. This is my first time with a vw. Until i hear an answer this will be me.....
  13. #11
    6th Gear
    Feb 2013
    Bendigo, Australia
    8,280
    I have never heard of cracks in a metal valve cover, what exactly are you referring to ? (a pic might help)
    More info required.
    Get it scanned and post the codes.
    Start a new thread with all your details would be a better idea.
  14. Remove Advertisements
Human Verification
There are currently 3 users browsing this thread. (0 members and 3 guests)
