Running lights not working
Results 1 to 6 of 6
    May 2008
    4
    First off I want to thank everyone for the good information i have retrieved so far.
    I have searched through the forum and I had a few questions. Currently my 2001 passat has no running lights.
    Don't work:
    Tail lights
    license plate lights
    front marker lights
    Work:
    head lights hi/low
    blinkers/side markers
    break lights
    Using the forum I understand that it could be a fuse but which one?
    also relay 173 or it could be the headlight switch.
    I have checked all the fuses and they all seem ok. Above relay 173 there was a 20 amp fuse(hidden) that was blown what is this to? pulled out the relay and put it back in. Do relays go bad often? or am i better off looking that the headlight switch? lastly if it is the head light switch that is bad should i still get voltage to the fuse(which ever one it is) or will there be no power cuz the switch is no good.
    Thanks for the help
    sorry for the long post
    Dec 2004
    00 V6 variant/06 4-m
    63
    2,139
    Quote Originally Posted by barnjeff View Post
    Don't work:
    Tail lights
    front marker lights
    Work:
    head lights hi/low
    break lights
    Thanks for the help
    the only thing relay 173 is for are the DRL,s(daytime running lights)low watt low beam
    http://shakti.trincoll.edu/~sritchie...use_panel.html
    May 2008
    4
    Yes, Thank you I was doing some more playing around and noticed that my DRL low beams still worked when i pulled the e-break. I found a simple diagram for the relay and saw what was going on.
    Is there anything else I should check before i buy a new switch?
    one person told me that if my dash lights still work that it isn't the switch. are the dash lights and the tail lights, plate lights on the same pins?
  5. Remove Advertisements
  6. #4
    4th Gear
    Mar 2007
    Toronto, Canada
    2,847
    When you pull off your fuse cover it should have a diagram with the numbers
    Fuses
    Arrangement in Fuse Panel
    Fuse colors
    30 A
    green
    25 A
    white
    20 A
    yellow
    15 A
    blue
    10 A
    red
    7,5 A
    brown
    5 A
    beige
    3 A
    violet
    Fuse arrangement in fuse panel, behind instrument cluster, left
    Fuse Arrangement In Fuse Panel
    Fuses from S24 to S44 are identified with additional prefix 2, in wiring diagram.
    Example: Fuse S40 on fuse panel is listed as S240 in wiring diagram.
    Fuses:
    1
    Heated washer nozzle
    5A
    2
    Turn signal system
    10A
    3
    Light for glove compartment, air
    conditioning, selector lever
    5A
    4
    License plate light
    5A
    5
    Instrument cluster, heated seats, cruise
    control test plug, air conditioning
    10A
    6
    Control module comfort system
    5A
    7
    ABS
    10A
    8
    Automatic headlight beam
    adjusting, telephone system
    5A
    9
    Heated Mirrors
    10
    CD changer unit
    10A
    11
    Cruise control by automatic transmission
    5A
    12
    B+(battery positive voltage) for on
    board diagnostic (OBD)
    10A
    13
    Brake lights
    10A
    14
    Comfort system
    10A
    15
    Instrument cluster, automatic transmission
    10A
    16
    ABS/ASR
    10A
    17
    Navigation
    10A
    18
    Right headlight, high beam
    10A
    19
    Left headlight, high beam
    10A
    20
    Right headlight, low beam
    15A
    21
    Left headlight, low beam
    15A
    22
    Parklight, right
    5A
    23
    Parklight, left
    5A
    24
    Wiper system
    25A
    25
    Fresh air blower, recirculating
    control air conditioning
    30A
    26
    Rear window defogger
    30A
    27
    Rear window wiper system
    15A
    28
    Fuel pump (FP)
    15A
    29
    Engine control
    20A
    30
    Sunroof
    20A
    31
    Back-up lights, cruise control,
    15A
    32
    Engine control
    20A
    33
    Cigarette lighter
    15A
    34
    Engine control, injectors
    15A
    35
    Trailer socket
    30A
    36
    Fog lights
    15A
    37
    Radio system, telephone system
    20A
    38
    Comfort system
    15A
    39
    Emergency flasher system
    15A
    40
    Dual horn
    25A
    41
    ABS
    25A
    42
    free
    25A
    43
    free
    10A
    44
    Heated seats
    30A
  7. #5
    Apr 2010
    1
    No Running Lights SOLUTION
    I own a 2004 Passat, and encountered the same problem as "barnjeff".
    Bottom line:Running lights/Parking lights (noticed these terms are used interchangeably), went out in front, back, as well as the lights over the license plate. The solution was to buy a new switch.
    The switch was $40 at autopartswarehouse.com and it was received in less than 48 hours!
    Add'l info: Before buying the switch, I tried to troubleshoot myself. I checked all of the fuses; all were good. I checked the connector behind the light switch; good. I even whipped-out the multimeter and some other electrical gadgets to ensure current was flowing where need be to all the fuses, and even punctured the insulation of the wire which controls the running lights (GREEN with RED tracing). All were in good working order, thus it had to be the switch. So, crossed my fingers in hopes that it was the answer and it was.
    Good luck, folks!
    Katy
  8. #6
    Nov 2011
    Minnesota
    3
    Quote Originally Posted by Katydid View Post
    Good luck, folks!
    Katy
    Katy, which switch did you replace? I have the same problem. Do you have a link?
    Thanks!
    -David
  9. Remove Advertisements
Human Verification
